Midwest aircooled Samba Member
Joined: June 19, 2001 Posts: 326 Location: St.Louis, MO
Posted: Tue Feb 03, 2009 7:56 pm Post subject: 17" x 7" porsche twists on a '66... need spacing h |
I'm wanting to run 17 x 7 porsche twists all around on my '66. I'm looking at the boxter front wheels, with I believe a 52mm offset if I remember. I'm fine with the drum brakes, so I was planning buying the porsche pattern drums for CIP. I have a stock width beam and stock short axle setup out back. Will I need spacers anywhere, or?? Will I need to narrow the beam to get them too look right? I'm not worried about tucking the wheels up in the fenders, but I would like them even or just inside the fender...
Thanks for any help.
Jason _________________ 1972 Bug 2332cc turbo, all under the decklid and 400+ rwhp, street driven!
Featured in Hot VWs Dec 2010
1957 Oval window Rag, Cover car, summer issue Volksamerica Magazine
Midwest Air-Cooled & Machine
Facebook.com/midwestaircooled |
Posted: Tue Feb 03, 2009 8:03 pm Post subject: |
Also does anyone know what the original application was for the 5 lug ball joint porsche pattern drums, or the rear porsche pattern drums? Its says they are german, are they buying them that way or drilling them from blanks?
Thanks,
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
Posted: Tue Feb 03, 2009 9:30 pm Post subject: Re: 17" x 7" porsche twists on a '66... need spaci |
vwjunkie53 wrote: |
Jason |
You will need a 2" narrowed beam up front and either long axles or a 3/4" spacer in the rear.
I just did something similar to my Super but I also did it to a 59 beetle. Your tire will stick out a half inch in the front and the wheel will bottom out on the spring plate in the rear. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
Posted: Tue Feb 03, 2009 9:38 pm Post subject: |
Wow thanks for the info, someone who knows what they are talking about!
The beam thing is no big deal, but i really didn't want to tear out the trans and change that crap all over. What would be the lesser of two evils: the spacers or run a set of adapters? I'm not really that fond of either one, but this is just a stock engine daily driver.
Thanks for the help and suggestions,
Posted: Tue Feb 03, 2009 9:46 pm Post subject: |
vwjunkie53 wrote: |
Jason |
You can always do disc brakes and we can make bolt patterns exactly the size you need.
Posted: Tue Feb 03, 2009 9:59 pm Post subject: |
Believe me, if the budged would support it, I would be calling you up for a set. I know your disc setups are high quality. As I said though, the stock drums are just fine for the daily driver with a stock 1600 single port. At the moment my play money is going towards rebuilding the turbo engine in my '72. New alum block, Pauter rockers, and a new Barry Grant carb to name a few things have put a pretty big dent in the play fund!
Do you sell spacers that will work with the drums? After looking around a bit, I think that would be my best bet.
Thanks,
julioseizure Samba Member
Joined: October 01, 2006 Posts: 39 Location: Redmond, Wa
Posted: Wed Feb 04, 2009 1:30 am Post subject: |
I'll just chime in and say I put 17x7 cup IIs on the front of my 66 last weekend. I'm not getting any rubbing and I didn't have to narrow my beam but I also converted the front to discs at the same time. _________________ ---
66ish bug, 1776cc
http://parallelroads.com
http://myspace.com/rickmolloy |
Posted: Wed Feb 04, 2009 12:00 pm Post subject: |
well if anything the discs are a little wider than the redrilled drums will be. I may just try putting them on there and see how they look. Anyone have a source for nice spacers for out back?
Posted: Wed Feb 04, 2009 2:42 pm Post subject: |
vwjunkie53 wrote: |
Thanks,
Jason |
So you are building a turbo motor and keeping the stock brakes?
Do not install spacers with something that is going to twist like your set up. Get a direct bolt set up. _________________ TheSamba members-only discount - Samba24
Posted: Wed Feb 04, 2009 6:59 pm Post subject: |
No the turbo setup is in my '72 street/stip car. The porsche wheels are for the '66 I have. Like I said, daily driver with 1600 single port power. I doubt I'll be twisting anything off with that thing!
itHaKa Samba Member
Joined: February 20, 2008 Posts: 254 Location: Argentina
Posted: Mon Feb 16, 2009 1:56 pm Post subject: |
im pasting an email from Alan
http://www.manxgallery.org/gallery/album95
" The wheels were repro 17x7.5 with ET52 - all the guards are stock - i had to narrow the ball joint beam 80mm (using cb performance discs and dropped spindles). With a standard beam the wheels fit under guards but had very limited turning circle. i therefore had to run the narrowed beam and 20mm spacers each side. The rear had swing axle (short axles) with cb performance discs and he had to run 35mm spacers to stop the wheels from hitting the spring plates. i think a different offset rim would have fitted better " |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Apr 26, 2022 6:59 am Post subject: Re: 17" x 7" porsche twists on a '66... need spacing h |
Here is for anyone in the future wanting to put the 17x7ET55 porsche twist rims on their vw.
With a 2 inch narrow beam, the outer lip of the rim will sit .1 inch narrower than stock.
_________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Fri Oct 07, 2022 12:35 pm Post subject: Re: 17" x 7" porsche twists on a '66... need spacing h |
Has anyone had twist or alloy wheels narrowed RECENTLY. Looking for a location and approximate cost. |
