gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Mon Jan 12, 2009 6:27 pm Post subject: |
ME TOO steph split with my loot also ...beware if he is up and running again.
i am still waiting for someone to offer the oil lines i need...i could buy it either with the cooler or without.i also need all the fitting to have it work not just the lines. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Alex6373 Samba Member
Joined: August 05, 2007 Posts: 882 Location: Vancouver Island,B.C.
Posted: Mon Jan 12, 2009 6:46 pm Post subject: |
Now i know why he did not respond to me as i am still waiting .... guess i will have a go at finding local fittings and lines.... |
kotsengkuba Samba Member
Joined: October 31, 2008 Posts: 11 Location: Lomond, AB
Posted: Wed Jan 14, 2009 10:31 pm Post subject: |
what is the exact size of the input and output openings for oil lines of a bypass filter and the vintage style full flow filter (like the one in denzels)?
i do have a vintage filter that i want to use but don't know if it's for full flow or bypass. don't know what fittings to buy.
some pics of the filter.
thanks,
mark _________________ 1966 Beetle
1975 Brazilian Beetle |
thomaskaefer Samba Member
Posted: Wed Jan 14, 2009 10:44 pm Post subject: |
Why not measure the in- and outlets of your filter by yourself? If you have all sizes (and a detail picture of the srewsize I possibly can help.
I also need to know if its a metric thread of the screw or what kind of thread.
Kind Regards
Thomas |
Shorrock Samba Member
Posted: Thu Jan 15, 2009 8:14 pm Post subject: |
I have this old vintage spin on oil adapter and use to have some pictures and info on it but for the life of me no can find. Can anyone help? Thanks, Howard
Posted: Fri Jan 16, 2009 6:13 pm Post subject: |
I found the manual of my filter. It says it has a 1/8" NPT inlet and outlet hole.
It also has a .06 restriction orifice. So i think this is for bypass apllication. So is it the same fittings as of the fram?
Thanks,
Mark _________________ 1966 Beetle
the.fordhams Samba Member
Joined: February 11, 2004 Posts: 471 Location: Charlotte, NC
Posted: Sat Jan 24, 2009 6:01 am Post subject: |
I must have one of Stephs last made oil line sets I bought about 2 years ago and I have not fitten them yet. Oil lines and cooler complete.
Mr OK - do you want to repop them or do you have a set alreay you could er reproduce?
AL _________________ 63 OG Turkis Bug project
65 OG Safari Beige Notch
65 OG Pearl SO42 Patina
67 SO42 welding project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender |
FrankRam Samba Member
Posted: Tue Jan 11, 2011 8:59 am Post subject: Exact size F3P Filter insert cartridge |
OK, I would love it if someone can give the link to purchase the exact size insert cartridge that goes inside the Fram F3P filter? (Yeah, it's blue).
Thanks! |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13960 Location: Southampton U.K.
Posted: Tue Jan 11, 2011 1:33 pm Post subject: Filter Cartridge |
Thanks John -
It also turns out that the Hastings LF130 would also be an equivalent filter. |
BUGBOY1976 Samba Member
Joined: August 21, 2004 Posts: 278 Location: Australia
Posted: Wed Jun 15, 2011 3:53 am Post subject: |
Is anyone making the lines now? or does anyone have details of the fittings. |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Mon Jun 27, 2011 2:32 am Post subject: |
BUGBOY1976 wrote: |
I have the same question. I've been recommended to go to my local hydraulic hose supplier and get them made up - if I do that I still need to know the hose diameter I need please. Are the inlet and outlet hoses actually different bores, or is there just a restriction at one end to control the flow? If I'm using a bypass filter and Okrasa style cooler is htere anything else I need to take into consideration please? Does anyone have a source for og style braided hoses?
Cheers,
Dave |
Braukuche Samba Member
Posted: Mon Jun 27, 2011 7:06 am Post subject: |
bally wrote: |
BUGBOY1976 wrote: |
Cheers,
Dave |
I got mine from Steph about six months ago. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Flavio Samba Member
Joined: May 14, 2008 Posts: 414 Location: Madeira Island, Portugal
Posted: Sun Oct 30, 2011 3:33 am Post subject: |
Yes. You must add the extra oil if you want it at your usual dipstick mark. If I remeber well it's 250 cc more (about 1/4 quart more, converting liters to quarts ?).
Just put the normal 2.5 liters there, start the engine for one or two minutes. Stop it and verify where is the oil in the dipstick. Add more oil to get the normal level . For me, normal, is just half distance between the 2 marks.
Hope this helps. |
Posted: Sun Oct 30, 2011 10:51 am Post subject: |
Flavio wrote: |
Hope this helps. |
Full is to the top line on the dipstick,if you're half way you're always running your engine a half quart low _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse" |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Flavio Samba Member
Posted: Sun Oct 30, 2011 12:41 pm Post subject: |
Yes, that's what I do. Just half between the two marks.
Another thing is that you must have a restrictor in the oil bypass filter Inlet.
With it (restrictor) beeing 1 mm / 1.5 mm, my engine has about 7 psi hot idle with 10w30 oil. |
Posted: Sun Oct 30, 2011 11:18 pm Post subject: |
Flavio wrote: |
Hope this helps. |
about how much total oil do you add? _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
Flavio Samba Member
Posted: Mon Oct 31, 2011 4:13 am Post subject: |
Not sure but probably 3 liters. When just changing the oil it takes about 2.3 liters, because some of the oil, obviously, remains in the filter can and also in the lines.
I prefer a low/midle level than full. When full, sometimes when at high way speeds, I have a small portion of oil leaking from behind the crank pulley. |
