corradolvr Samba Member
Posted: Tue Apr 28, 2009 4:31 pm Post subject: |
joescoolcustoms wrote: |
I really like how you are tieing the rear bumper into the cage. Got me thinking... |
Thanks. It'll be a little more beafed and need to be tweaked a little, but I think it's a solid and simple approach. _________________ My Build Post
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Tue Apr 28, 2009 4:36 pm Post subject: |
bently book puts all torque specs at the end of the chapter, so its on a page or two, its about the only thing in the book that is well organized, nice when you are doing something you already know how and just need torque ref.
I also recommend you disassemble clean and reassemble the carbs. Its not done right unless you did it. and write down all the jet and vent sizes for later tuning purposes. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
JohnSawyer Samba Member
Joined: October 07, 2006 Posts: 142 Location: San Diego, CA
Posted: Wed Apr 29, 2009 10:55 am Post subject: Paint |
Even if you have a carpet kit, I'd probably bedliner the whole interior pan.. Prevents rust, and deadens noise...
The car looks really good - I like the kids seat mounts. You might consider mounting their seats higher so they can see out, though...!
On your exposed metal (roll cage, seat mounts, bumpers), I'd use Rustoleum Hammered. It looks great if you don't brush it too much. I repainted my front beam after wire-brushing most of the paint off and you don't see any imperfections... |
Posted: Mon Jun 22, 2009 11:34 pm Post subject: |
Thought I'd update the build, nothing significant but a few pics of the motor and the cage. I integrated the BMW 3 series seat belts and got my MST serp system. The MST serp system is of the best quality I've seen. Very nice .
My seat brackets (copied some others, Neanders I think, Thanks).
I know the pictures are not the best but the finish on the cage turned out really good. Notice the beer . May or may not be the best inspiration. _________________ My Build Post
Posted: Tue Jun 23, 2009 11:09 pm Post subject: |
anybody know where I can get weber IDF 40 gaskets? Between the carb and intake. I need four of them suckas. For some reason my guy just says he'll work on it but never gets them. _________________ My Build Post
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Tue Jun 23, 2009 11:21 pm Post subject: |
corradolvr wrote: |
anybody know where I can get weber IDF 40 gaskets? Between the carb and intake. I need four of them suckas. For some reason my guy just says he'll work on it but never gets them. |
http://www.mooreparts.com/store/product/524/AC000553/ _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Posted: Tue Jun 30, 2009 7:39 pm Post subject: |
I just found that having some Scat tins, some stock tins, and some China tins is not a good idea. A grind here a snip there......and it fits!
I'm also having a bit of trouble getting my serp kit to line up right. The alt pulley is way in compared to the crank pulley. Is there shims that I can put behind the alt pulley on the alt shaft? I got some but they only fit behind the fan. _________________ My Build Post
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Wed Jul 01, 2009 8:31 am Post subject: |
Also not to mention that those aftermarket shrouds put out way less cooling then a stock shroud.
i'm having similar issues when i put some aftermarket scat cylinder tins. it seems the provisions for the fan shroud (which don't even line up 100% with each other), are a bit farther back. i had to bend the tins, and cut them, and beat them, just to get them to fit. also the fan likes to grind like crazy. I have to periodically kick the fan shroud to get it to stop grining, due t the awkward angle the cylinder tins are holding the shroud. its a stock shroud, and the only aftermarket thing are those damn cylinder tins. Never again will i buy afterarket tin. When i do get the stock tins back on, i'll prolly cut them up to use for scrap metal (cause they are kind of thick). I don't want anyone to end up with that shit.
Anyhoo, enough ranting, lol . looking awsome. Keep the pics commin. _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Wed Jul 01, 2009 8:46 am Post subject: |
corradolvr wrote: |
I'm also having a bit of trouble getting my serp kit to line up right. The alt pulley is way in compared to the crank pulley. Is there shims that I can put behind the alt pulley on the alt shaft? I got some but they only fit behind the fan. |
if you take your pulley off there are a bunch of shims in between the pulleys and behind it. you adjust these to set the belt tension on a stock pulley. so if you bought your alt new and that serpentine system probably doesn't use them, then you need to order a set of these to get the pulley set up without any runout.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-9197 _________________ never forget 1-31-07 |
neanders Samba Member
Joined: November 12, 2007 Posts: 1146 Location: Spokane, WA
Posted: Wed Jul 01, 2009 8:51 am Post subject: |
Looks good!! I like those seats! You shoulda got the heated ones, it gets COLD up in this part of the country. What part of WA are you in? _________________ It's mine now and I want a BAJA!!! |
tundrawolf Samba Member
Joined: February 24, 2009 Posts: 1384 Location: RIP Mishomi my friend. I will always love you.
Posted: Wed Jul 01, 2009 9:44 am Post subject: |
How much have you spent in bedliner? |
Posted: Wed Jul 01, 2009 11:50 am Post subject: |
The Scat tins seem to fit well, and work good with the stock cylinder tins. The China tins are the ones with the miss cuts, and unaligned bolt holes.
RLAP those shims look like they are the same ones I already have. Where do they go? on the alt shaft right behind the pulley? I just need to move it out from the alt. The shims I have are big. The shims I have appear to go in right behind the fan in the shroud. _________________ My Build Post
Posted: Wed Jul 01, 2009 12:35 pm Post subject: |
corradolvr wrote: |
RLAP those shims look like they are the same ones I already have. Where do they go? on the alt shaft right behind the pulley? I just need to move it out from the alt. The shims I have are big. The shims I have appear to go in right behind the fan in the shroud. |
do the ones you have, have flat spots in the center hole? _________________ never forget 1-31-07 |
Posted: Wed Jul 01, 2009 1:00 pm Post subject: |
those are the ones that go between the pulley halves on a stock alt pulley. they go around the collar on the inner half, which in turn goes arounf the alt shaft. so its obviously going to be bigger then the alt shaft. do they sell shimms that go behind the alt pulley to push it out? you said it was way in. bout how much? like 1/4 inch, 1/8 inch, etc? is the strap tightened down all the way? _________________ 1974 Super Beetle: Custom resto in progress
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
DONT Samba Member
Joined: October 19, 2006 Posts: 338 Location: Gilbert, AZ
Posted: Thu Jul 02, 2009 2:36 pm Post subject: |
corradolvr wrote: |
Does anybody have a serp kit that they have already aligned? I think lotrat has the same serp kit I do. |
PM him on STF. |
shawn813 Samba Member
Posted: Fri Jul 03, 2009 11:33 am Post subject: |
I've been watching this build. You are doing a great job! I too am thinking about using bedliner. |
BugZyla.com Samba Member
