jj14u2c2 Samba Member
Joined: March 21, 2008 Posts: 125 Location: St. Paul, MN
Posted: Tue Jan 13, 2009 7:40 am Post subject: BEDLINER |
I'm doing the bedliner as well. I put it on the entire pan and all of the suspension too. I'm using Grizzly Grip liner. It comes in about 20 colors. My Baja will be run on gravel roads, so I won't have to worry about rocks chipping the paint.
Your's is is really looking good. |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Tue Jan 13, 2009 7:55 am Post subject: |
I'm stealing that hood solution btw, looks simple clean and effective. [/code] _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Tue Jan 13, 2009 1:17 pm Post subject: |
where in WA are you?
ive noticed that the roll on bed liner does last better than the expensive spray one stuff. i have some rolled on my car and i was worried about it fading like some of the truck beds ive seen but so far its still as good as the day i rolled it.
and i dont know why i just noticed this but your rims look like faucet handles ive never seen those rims before. _________________ never forget 1-31-07 |
corradolvr Samba Member
Posted: Tue Jan 13, 2009 2:01 pm Post subject: |
I'm in Puyallup. I talked to you once before a couple of months back. I got the rims randomly. Not really sure what kind they are. I may just have to test how strong they are. _________________ My Build Post
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= |
Posted: Tue Jan 13, 2009 5:37 pm Post subject: Bed liner |
Looks great. Glad to see I'm not alone. I'm doing my Baja in total bed liner as well. I’m using Grizzly Grip bed liner because it comes in about 20 different colors. I've already done the entire pan top and bottom, and the complete suspension too. I will be using my Baja to do gravel road runs, so I don't want to worry about the constant beating by stones chipping paint.
I was initially going to use the Safari Tan color because it’s the same color as the mud on the gravel roads in Minnesota. After finishing the pan though, it looks a little pinkish instead of just tan. If Grizzly Grip can't mix it with less of a pink hue I will be going with the Dolphin gray on the body. I used Canary yellow on the bumpers, and suspension.
I'll also do the underside of the fenders so the stones won't cause the spider web, or star cracks in the fiberglass.
Http://www.grizzlygrip.com |
Posted: Tue Jan 13, 2009 5:45 pm Post subject: My Pan |
This is the pan I did.
You can get a UV blocker from Grizzly Grip so the finish doesn't chalk or fade, also a clear gloss over coating.
damquick1 Samba Member
Joined: October 25, 2008 Posts: 266 Location: PENNSYLVANIA
Posted: Tue Jan 13, 2009 6:21 pm Post subject: |
that stuff looks excellent...I'm on the research now!
looks like I may go with it! |
notsofastEddie Samba Member
Joined: February 27, 2008 Posts: 286 Location: Free Home, Georgia
Posted: Tue Jan 13, 2009 8:11 pm Post subject: |
sweet, now that's the ticket! Once I get past my rehab (tore my rotator cuff, fixin' to have surgery) that's what I'm going to do my bug with. Yea! _________________ '72 super baja |
turbobug Samba Member
Joined: June 30, 2007 Posts: 12 Location: scotland uk
Posted: Tue Mar 03, 2009 6:25 am Post subject: |
i like the look of the baja
what rear kyb shocks are on your baja the beetle ones or the bus ones |
Posted: Sun Apr 12, 2009 10:26 pm Post subject: |
got some new stuff done. I'm not going to weld the cage in yet. The top is welded but not the bottom. I used 1/8th plate for the feet and also 1/8th for the plates on the underside. Eventually I'll weld in the bottom, probably when I switch to a 1 piece front.
I also beefed up my tie rods. Welded some tubing on. Notched to bottom of the passenger side to clear the frame head.
My little gem of a steering wheel. It's not too small.
enumclawbmx Samba Member
Joined: February 24, 2009 Posts: 39 Location: washington
Posted: Sun Apr 12, 2009 11:16 pm Post subject: |
awesome build man!!
puyallup huh im out here in enumclaw wher do you get all you parts from? local? _________________ GO GO GO |
Posted: Sun Apr 12, 2009 11:22 pm Post subject: |
I pretty much order all my stuff. I go to mouse meat for most of my stock parts. They have a lot of used stuff and are pretty cool about sharing info. I'm hoping to have my car driving in a month or two, but that might be wishful thinking. _________________ My Build Post
Posted: Mon Apr 13, 2009 12:17 am Post subject: |
just awesome |
ngneer Samba Member
Posted: Mon Apr 13, 2009 7:47 am Post subject: |
Nice build. Words from an ol fart, u keep referring to yourself as young, STAY in school, do GOOD, an shoot for the stars, DON"T settle for just, average. Again nice car, keep the updates comin! |
Posted: Mon Apr 13, 2009 1:29 pm Post subject: |
where you plan on takin the lil guy when you finsh her all up ??
im looking for places to go when i finish mine aswelll _________________ GO GO GO |
Posted: Mon Apr 13, 2009 1:57 pm Post subject: |
thats a good idea man !!
im about to partake in a pan swap then i'll be ready to ride
however i do have to bust up some super beetle suspension if you catch my drift haha _________________ GO GO GO |
Posted: Tue Apr 14, 2009 7:47 am Post subject: |
ngneer wrote: |
Thanks for the encouragement. It looks like you're and engineer. I just got accepted into the St Martin's engineering program in Olympia WA. I don't have a choice. I have to succeed my fiance is in a "only 5 people get in" graduate program in genetic bio chem or something like that. She's a wiz. _________________ My Build Post
GhiaBateman Samba Member
Joined: August 11, 2007 Posts: 702 Location: Epsom, NH
Posted: Tue Apr 14, 2009 9:55 am Post subject: |
lookin' good, I like the bedliner idea more each time i look... but we'll see. now i have a question: why did you notch your tie-rod modifaction and not just take a BFH to the framehead a couple times? a small dent to the frame head seems better than making you strength mod weak with a notch... anyway keep building and keep the pics coming. _________________ (o=|=o) Life before play... Damn! it's gonna be awhile. |
