indianpeaksjoe Samba Member
Posted: Fri Feb 09, 2024 1:46 pm Post subject: Re: What did you do to your Beetle this week? |
Rome wrote: |
I haven't looked into this thread for a few months... Excellent photo! |
Thanks! I started a thread in the Readers Ride forum https://www.thesamba.com/vw/forum/viewtopic.php?t=787660
Also, this week I trimmed the gas line, I made it too long when I replaced it last year. I think it was too close to the exhaust header and getting vapor lock when I parked it. But maybe not, I'm guessing here
-Joe _________________ Adventures in owning a 66 beetle |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9788 Location: Oregon
Posted: Sun Feb 11, 2024 5:01 pm Post subject: Re: What did you do to your Beetle this week? |
Took a weekend trip to the Oregon coast this weekend.
The drive out was uneventful.
The drive back home? Very eventful.
After traversing three 1000Ft. plus mountain ranges.
The JavaGreen's engine lost power and I was forced to leave the car at a filling station 17 miles from home.
Thankfully Xevin was following behind me. He gave me a ride home and I returned to pickup the beetle and drag it home via the tow bar.
Oh well. It was a twenty year old engine with god knows how many miles on it and really poor service from the previous PO's.
I actually expected the engine to fail on the outbound leg of the trip.
Good thing I have an engine on the stand, just for this car. It's almost ready to go! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
OldSchoolVW's Samba Member
Posted: Sun Feb 11, 2024 8:31 pm Post subject: Re: What did you do to your Beetle this week? |
Working through my electrical “to do” list …
Installed a hard start relay. Since it’s a 6v system I decided to keep the routing short and wiring fat. With this in mind I went to the extra bother to put the relay next to the battery and run a new ignition “start” wire (50) alongside the tunnel. Used 10 and 12 gauge wire. (Some will say this is overkill, but I already had it and thought it certainly wouldn’t hurt … especially with a 6v system.)
Locating the relay under the rear seat put it in a less hostile environment than the engine compartment or alongside the starter and kept the wiring runs short.
_________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
brass gears Samba Member
Joined: October 21, 2013 Posts: 72 Location: Calgary,AB
Posted: Sat Feb 17, 2024 10:36 am Post subject: Re: What did you do to your Beetle this week? |
Installed Sapphire I radio in my beetle. Finally got that hole filled.
Thanks to samba member Gary Haberman. Works perfectly.
_________________ ‘70 transporter
‘ 64 beetle |
Posted: Sat Feb 24, 2024 8:42 pm Post subject: Re: What did you do to your Beetle this week? |
I adjusted the valves and went for a fun cruise.
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9830 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Feb 25, 2024 4:35 am Post subject: Re: What did you do to your Beetle this week? |
Beautiful image.
Are you a professional photographer ? |
Posted: Sun Feb 25, 2024 7:25 pm Post subject: Re: What did you do to your Beetle this week? |
iowegian wrote: |
Beautiful image.
Oh the smile on my face right now I am not, I’m a computer nerd, but I love taking photos.
Thanks so much.
62RagTopBug Samba Member
Joined: April 10, 2022 Posts: 12 Location: MidMichigan
Posted: Sun Mar 03, 2024 5:06 pm Post subject: Re: What did you do to your Beetle this week? |
Todays project completed!
Changed both of the fender turn signal seals, light housing and installed the LED bulbs.
Posted: Wed Mar 20, 2024 7:40 pm Post subject: Re: What did you do to your Beetle this week? |
I installed this little glove box pull from Project Therapy, I was having a heck of a time getting the glove box open. Solved and looks good to boot.
Posted: Wed Mar 20, 2024 7:52 pm Post subject: Re: What did you do to your Beetle this week? |
Also went for a cruise.
Posted: Wed Mar 20, 2024 8:19 pm Post subject: Re: What did you do to your Beetle this week? |
indianpeaksjoe wrote: |
Project Therapy has some fun stuff on their website. I spotted a magnet/decal I want to buy.
https://project-therapy.com/ _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu Mar 21, 2024 6:26 am Post subject: Re: What did you do to your Beetle this week? |
67rustavenger wrote: |
https://project-therapy.com/ |
I might have included the spark plug gap and firing order magnets in my order...
They look nice on my tool box
Posted: Sat Mar 23, 2024 8:11 pm Post subject: Re: What did you do to your Beetle this week? |
Replaced the original fuse panel on my '63 with an ATO blade style fuse panel from Torque Resto. It was pricey compared to an OEM style replacement panel, but it is very well made, has a terminal configuration that is identical to the original, is a perfect fit in the fuse panel opening under the dash and comes preloaded with ATO fuses in whatever arrangement you request. The original clear plastic panel cover even snaps right on.
I don't normally stray from stock components, but I believe the greater contact surface area of ATO blades will help reduce voltage drop (always a concern with a 6V system). The only trade off is that 16 and 8 amp circuits would need to use 15 and 7.5 amp ATO fuses, which I don't believe will have an adverse affect.
Please excuse the tape labels on the wires ... a precaution to make sure I got everything connected correctly. Great time to clean/scrape connectors.
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Wed Apr 03, 2024 7:10 pm Post subject: Re: What did you do to your Beetle this week? |
Replaced my generic ignition switch with an OG 67 switch I bought from GabVWKey.
Once the switch arrived, I matched the door lock cylinders to the ignition switch.
I followed Keith's key match thread idea. Since my door locks were already modified by an earlier PO. I didn't feel any shame in modifying the door lock cylinders.
The best part is, I now have one key that unlocks the doors and starts the car. I couldn't be happier. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri Apr 05, 2024 6:19 am Post subject: Re: What did you do to your Beetle this week? |
I knocked out a ton of projects this week.
My beetle has been stinking like gas, I did everything, I replaced the gas cap (twice!), the fuel sending unit, the sending unit seals, fuel lines in the back. Only one thing left, the line from the tank to the metal tube. Conveniently I went out one morning this week and there was a puddle under the beetle. Culprit confirmed.
More info and pics: https://robonza.com/beetle/index.php/2024/04/04/gas-leak/
Then a few weeks ago I replaced my blinker LEDs with KC rock lights, I used surface mounts the first time and I swapped them with flush mounts, which required making the holes bigger.
More pics and stuff: https://robonza.com/beetle/index.php/2024/04/05/installing-kc-cyclone-led-flush-mounts/
I noticed way too much dust in the battery compartment area, looks like when the PO disconnected the heater tjhey never blocked off the heater tubes. I blocked those off.
https://robonza.com/beetle/index.php/2024/04/05/capping-heater-tubes/
And the week isn't over
Posted: Sun Apr 07, 2024 1:11 pm Post subject: Re: What did you do to your Beetle this week? |
Joe, you're not allowed to post any more pics of your car, without at least one of your Basset Hound in it. Love that dog!
Added an AFR Gauge to the JG 67 yesterday.
Looks like I have some tuning to get after. _________________ I have learned over the years.
Buy Once, Cry Once!
Coreymillia42 Samba Member
Joined: September 05, 2023 Posts: 32 Location: Victor Colorado
Posted: Sun Apr 07, 2024 5:00 pm Post subject: Re: What did you do to your Beetle this week? |
I got a new 1966 Beetle with no breaks, towed and in my yard.
I Sat in it pumping the breaks for a little, letting the pressure build up and then immediately dropping, while trying to find a leak. No luck yet. Will try again tomorrow.
Otherwise, looking for a new rear window and trying to figure out if a '66 and '67 is the same.
Planning on getting new running boards, and rubber for the windows.
Full tune up this week. But for a car that had been sitting for a long time it runs and sounds good.
_________________ 1971 Super Beetle. Owned 25 years... And now the owner of a 1966 Beetle. Plus, a 1967 bus that doesn't run. |
Posted: Sun Apr 07, 2024 5:14 pm Post subject: Re: What did you do to your Beetle this week? |
Coreymillia42 wrote: |
The 66-67 windows are the same size.
Change the rubber bits underneath the car. Brake lines, fuel lines and the like. Make it safe, before making it go!
Typically the metal rear brake line is corroded just behind the drivers side seat. Check it. It's inside the car along the tunnel under the floor mat.
Congrats on your new to you purchase. Have fun with it. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Apr 07, 2024 8:34 pm Post subject: Re: What did you do to your Beetle this week? |
I’ll do better
And from a trip to Bears Ears last week.
