Lifted Sedan, Class 11, Full Body Baja, etc (pics 1st trip)
Page: Previous  1, 2, 3, 4 ... 16, 17, 18  Next
earthquake
earthquake is offline
PostPosted: Sat Jul 05, 2008 11:31 am    Post subject: Reply with quote
AZ-BUG
I finely got around to mounting my front beam in my car and turning up my rear torsions, now I just need to work on the floor pans and paint.
Earthquake
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
AZ-BUG
AZ-BUG is offline
PostPosted: Sat Aug 09, 2008 10:33 pm    Post subject: Reply with quote
OK, another update. Got the straps installed to keep the frame horns from cracking...
Made seat mounts (thanks Neanders for the idea) and installed seats (from a 2003 Cavalier)... also added tube from cage to front beam.
and beefed up the front suspension mount... added upper & lower supports as well as diagonals. Still need to buy my Bilsteins for the front.
Engine is back in, and most of the electrical is working, still a few bugs to work out. I am getting close to finishing up, should be done in time to enjoy the cool weather!
neanders
neanders is offline
PostPosted: Sun Aug 10, 2008 7:00 am    Post subject: Reply with quote
Nice!! I like them seat mounts. Laughing I may borrow some of your ideas to reinforce my front end...
It's mine now and I want a BAJA!!!
AZ-BUG
AZ-BUG is offline
PostPosted: Sun Aug 10, 2008 8:37 am    Post subject: Reply with quote
Yeah, got 'em off the internet somewhere Very Happy
Please do on the front re-inforce... you can also add a couple of diagonals to the bottom tubes from near the clamp back to the tunnel. Has to be pretty small tubing (at least on the driver's side) because of the master cylinder. A vertical one between the two tubes behind the clamp is also a good idea.
neanders
neanders is offline
PostPosted: Sun Aug 10, 2008 8:46 am    Post subject: Reply with quote
You still using the stock gas tank?
AZ-BUG
AZ-BUG is offline
PostPosted: Sun Aug 10, 2008 10:47 am    Post subject: Reply with quote
yup, stock tank. You need to keep an eye on the upper tubes coming from the cage, right where they come through the firewall, you also want to make sure you don't lower it because it will interfere with the tie rod (unless of course you get your hands on a tube bender, then it is easy to handle).
Shawng_88
Shawng_88 is offline
PostPosted: Mon Aug 18, 2008 4:50 pm    Post subject: Reply with quote
Hey man, nice build.....some of my buddies race class 11...1149 in SCORE and 1199 in SNORE & MDR...they just won the SNORE midnight special a couple weekends ago...you should check out their car...tracksidephoto.com has some pics
AZ-BUG
AZ-BUG is offline
PostPosted: Mon Aug 18, 2008 7:54 pm    Post subject: Reply with quote
Thanks! I took a look, they must have had a blast! Photos of the build, suspension, etc would be cool...
perrib
perrib is offline
PostPosted: Mon Aug 18, 2008 8:16 pm    Post subject: Reply with quote
You are doing a very clean job. Its going to be a very clean prerunner.
bizmarkie
bizmarkie is offline
PostPosted: Sat Sep 20, 2008 6:15 pm    Post subject: Reply with quote
very very nice bug..i like the cage work so far..what welder you using?..and was that a premade cage and you just added your own tube?
AZ-BUG
AZ-BUG is offline
PostPosted: Sat Sep 20, 2008 9:00 pm    Post subject: Reply with quote
Hi, thanks for your comments. I started with a 6 point cage and then added to it. I am using an big & old Lincoln stick welder that a friend lent me. My welds are OK if there are no tricky angles, etc... otherwise I am getting a few ugly welds Embarassed
I got temporary tags for it the other day and am working on getting it to pass emissions. I pass everything except for hydrocarbons at idle. I guess I need to play with the card adjustment some more.
sammyphsyco
sammyphsyco is offline
PostPosted: Sat Sep 20, 2008 9:11 pm    Post subject: Reply with quote
Since you are stick welding, not sure if you knew this or not. But you can bend the stick at any angle you need to in order to get those hard to reach spots.
Car looks good.
sammyphsyco wrote:
Your just jealous the voices are talking to me
USMCord1
Razorback
USMCord1 is offline
PostPosted: Sat Sep 20, 2008 9:38 pm    Post subject: Reply with quote
Change the oil just before you go in.
For a Good time
AZ-BUG
AZ-BUG is offline
PostPosted: Sun Sep 21, 2008 7:30 am    Post subject: Reply with quote
Thanks, I actually went through the entire engine while it was out:
new stuff:
points, condenser, cap, rotor, plugs, plug wires, manifold seals, belt, fuel line.
tune-up work:
- adjusted valves
- set timing 7.5 deg static bosch 009
- carb rebuild & adjust
- fresh oil
Got is nice & warm before taking it in...
Any additional ideas are welcome.
AZ-BUG
AZ-BUG is offline
PostPosted: Thu Sep 25, 2008 8:10 pm    Post subject: Reply with quote
Update on emissions testing:
I set the idle speed around 1200 RPM, leaned out the idle mixture as much as possible (until the engine began running rough, & then backed out a little until it ran smooth again). Left timing at 7.5BTDC, warmed it up and took it in... it passed with flying colors. HC limit at idle is 500, car passed at 90 (first time was 2000, second time was 1200... 3rd was the charm). Getting registration tomorrow, so I'll be hitting the roads (hopefully we'll soon dip under 100 F around here!).
I can't wait to take it off-road, will post pics of the maiden voyage.
ppp
ppp is offline
PostPosted: Fri Sep 26, 2008 7:25 pm    Post subject: Reply with quote
any updates? Thanks.
GhiaBateman
GhiaBateman is offline
PostPosted: Sun Sep 28, 2008 11:42 am    Post subject: Reply with quote
YES Please!! update... it's road worthy now right? lets see some pics off in the dirt!! Oh yeah, did you get that Jeep seat figured out yet? just wondered.
(o=|=o) Life before play... Damn! it's gonna be awhile.
InkyLewis
InkyLewis is offline
PostPosted: Fri Oct 10, 2008 11:55 am    Post subject: Reply with quote
Are your rear arms just beefed up stock arms? If so how did you get that much lift outa the rear. The car looks great and I hope mine turns out that nice.
travelvw
travelvw is offline
PostPosted: Sun Oct 12, 2008 9:26 pm    Post subject: Reply with quote
I'm working on mine, too. Just picked up an IRS bug pan this weekend that I'm goint to build up this winter for the bug. Right now its a 68 swing axle with 215's all around and a slight lift. Super fun to drive!
1963 SO-34 camper
1969 sunroof beetle
1963 Adam's parts gilla
AZ-BUG
AZ-BUG is offline
PostPosted: Sun Oct 12, 2008 11:08 pm    Post subject: Reply with quote
Hi! Yup, she's road worthy... been tooling around running errands in it mostly, as well as a few commutes into work. Unfortunately I haven't taken it off-road yet... next weekend I plan to take it out though. I still need to replace the front shocks with something respectable, so I'll be taking it easy with the stockers for now.
I've been fighting a small fuel leak (more like seepage) from the filler hose, right where it connects to the tank. Hopefully I can get it fixed soon, as is makes for stinky left turns (if you've had the problem you know what i mean!).
As for the rear arms, they are just beefed up stockers. I re-indexed the rear, set-up the spring plates so they were just tangent to the bottom bolt hole. It is currently riding on the stop, but takes only about 50 lbs or so to bring it off the stops. I am sure it will droop a bit after my first off-road trip. All rear components are stock, and I have not notched the plates, etc.
Will post photos of the maiden voyage next weekend.
Page 3 of 18
