RockStock Samba Member
Joined: November 26, 2004 Posts: 3929 Location: England
Posted: Wed Jul 02, 2008 5:05 am Post subject: |
those boys only need to find a speedo... _________________ -StockRocks- |
bubba Samba Member
Posted: Wed Jul 02, 2008 5:24 am Post subject: |
Lowdown Dirty Rat wrote: |
rare barndoor 1950 only, viegel speedo, same manufacture who made speedos for the very very early porsche 356's. |
That is the speedo that i have in my bus. It's a 7/50. Thanks again "surfindo". Not to my people would give something like this up!! |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Wed Jul 02, 2008 6:06 am Post subject: |
Rusting Hulk wrote: |
I don't think that's true
btw i'm still looking for the correct screws to hold my luggage rails down should be ready for the MOT then |
And it would appear very sensitive also!
I guess the mot man would fail you if you didn't have that luggage rail place huh?! _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
surfindo Samba Member
Joined: March 11, 2004 Posts: 442 Location: Haarlem, Netherland
Posted: Wed Jul 02, 2008 9:25 am Post subject: |
bubba wrote: |
you welcome!!!
I rather see my speedo cruisin around in early barndoor than hiding inside the box
hang-on.........
maybe one day I find cheap/early 50 barndoor with missing speedo??
nah...I had enough problem to finish my 54.
surfindo |
EverettB Administrator
Joined: April 11, 2000 Posts: 69831 Location: Phoenix Metro
barnjunkie Samba Member
Posted: Tue May 05, 2009 10:11 am Post subject: |
Everett that is damn nice
the earliest clock with that face that I've seen is 9 53 _________________ Luca Brasi's got nothing on me
54 rhd Judson super narrowed
BDM Wannabe |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Tue May 05, 2009 10:57 am Post subject: |
Another 12/54 brother...... from Feb 55 bus
_________________ 64 356 C Coupe |
Posted: Tue May 05, 2009 3:22 pm Post subject: |
Yea the pin was on it when i got the bus, the clock works but does slow down pretty quick, i may look for a circlip see if it makes a difference.
I had all my pods painted and the steering wheel so they at least match...... They also miss stamped the number with the extra 4 at the start of the number _________________ 64 356 C Coupe |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
Posted: Fri Oct 23, 2009 11:21 am Post subject: |
So I've learned a lot from this thread already, still got a question concerning this clock that came with a 50 split bug project. The face seems to make it a late 1953 DLX clock, but how does the spring winding work with those earlier clocks? The 55 that Everett postet seems to have the integrated windingwheel like the 8 day kienzle clock, mine seemed to have a side shaft as used on split bugs. was it the same on busses ?
The face has a VDO Logo on it. pointers are discolored from age, should be an off white originally.
somebody at some time unfortunately cut a hole in the back, obviously to get access to the winding mechanism, so the production date stamp is missing ( at least the interesting second digit )
Haven't put any efforts to get it working, but since my pops is an oldschool watchmaker, this shouldn't be the problem.
_________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Sat Oct 24, 2009 3:36 am Post subject: |
Should the winder come out of the side? _________________ 64 356 C Coupe |
buggen Samba Member
Posted: Sat Oct 24, 2009 12:40 pm Post subject: |
djfordmanjack wrote: |
Should the winder come out of the side? |
as with my clock thats the way. and thats the way it works on split bugs, with an additional extension the winder even pokes through the passenger glove box.I would like to know if that's the same on BD Dlxs |
Yes this style winds from the right side like a split bug. The winder looks like a split bug winder but the winder is a little shorter. This is the clock from my bus.
Posted: Sat Oct 24, 2009 3:51 pm Post subject: |
surfindo wrote: |
bubba wrote: |
you welcome!!!
I rather see my speedo cruisin around with your early barndoor than hiding inside the box
hang-on.........
surfindo |
Posted: Wed Jan 20, 2010 4:26 pm Post subject: |
Here's the resto of my 1953 DLx clock.
Tried to keep some patina as I flat clearcoated the cleaned original paint face/pointers and polished/straightened the original ring.
started with this
welded the housing
had to fabricate and repair the broken winding shaft extension
My Dad restored the clock to below +- 1min a day ( he's a professional watchmaker since 1959 )
After glass media blasting and repainting all parts ready for assembling
it's a 53 (Along with a friends 52' bug clock I took the shaft dimensions from)
Posted: Wed Jan 20, 2010 4:38 pm Post subject: |
nice resto! can i send mine your way _________________ -StockRocks- |
DanM Samba Member
Joined: June 07, 2002 Posts: 1330 Location: Falls Church, VA
Posted: Wed Jan 20, 2010 6:49 pm Post subject: |
Nice work fixing the back of the case! |
Posted: Thu Jan 21, 2010 3:33 am Post subject: |
Thanx !!
@RockStock:
Sure I can restore your clock, But you could try just a traditional local watchmaker ( I know that there are not as many around anymore, since the business has gone from repairing to changing batteries and throwing the used watches in the bin-as with todays automotive engineering).
The clock itself is a very simple device and often they just have to be cleaned, regreased and only some minor repairwork done to the bushings and shafts, something a good watchmaker can do. that said it is nearly impossible to find spare parts for these , if something is really broken, still it can be fabricated by professional shops, even the gears!
only time will tell... _________________ Hotrods, Fords, Veedubs and Triumph Twins !
