SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Dubskii Samba Member
Posted: Thu Jun 30, 2016 6:02 am Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Great informational thread. I plan on replacing my center pin and bushings this weekend. I have read a lot of discussion on this thread about the reamer but little on the drift. Aside from the proper VW tool like Hazetguy uses and an actual bushing driver, has anyone used a socket and extension? I would imagine a socket slightly smaller in outside diameter than the bushing would work? _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
57 Kombi - Dove Blue http://www.thesamba.com/vw/forum/viewtopic.php?t=648240
WTB Early Dove Blue Bus Driver's Side Door
WTB Joe Heishman VW Arlington, VA License Plate Frame or Other Memorabilia |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jun 30, 2016 7:56 am Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Dubskii wrote: |
I would imagine a socket slightly smaller in outside diameter than the bushing would work? |
A lot easier to use a piece of all thread at least 3" longer than the tube the bushings are in, some extra thick grade 8 washers with bigger ID than the all thread, three nuts, two grade 8 washers with smaller OD than the bushings and ID close to the all thread rod diameter, and a large socket.
Sand two flats on one or two of the grade 8 washers that are just smaller on the OD than the OD of the bushings, so they will be able to drop thru one of the bushings when tilted just right. So you want the piece of all thread to be smaller than the inside of the grade 8 washers to allow washer tilt.
Use the large socket to pull the bushing into it, a 36 mm socket should be bigger and longer than the bushing. Use two of the nuts locked against each other to keep them from moving on the all thread, when those two nuts are inside the front suspension.
When you pull in the top bushing (after putting in the bottom bushing) you will want a thick washer or piece of steel that has a much bigger OD the the top bushing. Pull the top bushing in part way and install the top warpy washer of the bushing kit around the bushing. Then pull the bushing the rest of the way down into the bore of the front suspension. The warpy washer will keep you from pulling the bushing down too far and set the correct bushing height just right. _________________ In Stereo, Where Available! |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2214 Location: UK (South)
Posted: Thu Jun 30, 2016 8:34 am Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Dubskii wrote: |
Great informational thread. I plan on replacing my center pin and bushings this weekend. I have read a lot of discussion on this thread about the reamer but little on the drift. Aside from the proper VW tool like Hazetguy uses and an actual bushing driver, has anyone used a socket and extension? I would imagine a socket slightly smaller in outside diameter than the bushing would work? |
I used a chunky spark plug socket. Just wrapped it in electrical insulating tape to prevent it marring the bushes. Helpfully one end fitted inside the bush, which made getting the new ones started in the tube easier. Then I inverted it and used it with a short extension to knock the top bush up.
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Mon Jul 04, 2016 10:29 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Completed this much needed replacement. Everything went just as hazetguy and others indicated. Many thanks! You can see my replacement steps on my build thread in my signature. _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Thu Mar 02, 2017 2:10 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
I ordered the drift, reamer and pin from JOGR! All ready to go, going to go get a clamp at HF, however...
Do you have to use one of these "drivers"? if so do they have them at harbor freight?
I see someone use a regular socket, does that work as well? any opinions or tips?
Stocknazi Samba Member
Posted: Thu Mar 02, 2017 2:19 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
I used a socket and T-handle breaker bar and it worked well. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Mar 02, 2017 2:22 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Longboardluv wrote: |
a long time ago, i bought that at sears. they might still have them available? not sure about harbor fright. maybe northern tool, perhaps even a big box store like lowe's or home despot might carry them. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Thu Mar 02, 2017 3:11 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Do you have to use one of these "drivers"? if so do they have them at harbor freight? |
That is a "tap handle" good for reamers or threading holes with taps. They come in several sizes, so you will want one that is designed for the square size of the reamer you have. While you could use a lot of other tools to turn the reamer, a tap handle just gives you a lot better control of it to get it straighter. _________________ In Stereo, Where Available! |
Posted: Fri Mar 03, 2017 6:15 am Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
I think I ended up using a spanner. I couldn't find a tap handle with jaws big enough to take the centre pin reader. _________________ Andy
Posted: Sat Mar 04, 2017 5:23 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
I'd also like to thank HazetGuy and everyone else that's contributed to this thread! I referred it the whole way through doing my pin. #TeamAircooled
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Mon Mar 06, 2017 9:20 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Here's my set-up...I bought one of the cheapo Chinese 24mm Straight Flute Reamers from FleaBay. I just kissed the flats on my grinder and it now fits in a 19mm or 13/16" socket (1/2" drive) and rotate it with a 1/2" drive 'T' handle...works perfect. _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
ernstben Samba Member
Joined: April 30, 2005 Posts: 621 Location: Manchester, Mi
EverettB Administrator
Joined: April 11, 2000 Posts: 69831 Location: Phoenix Metro
Posted: Wed Mar 08, 2017 3:54 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
hazetguy wrote: |
I like to install the clamp and upper spacer to compress the arm on the pin. This allows the bolt to be removed easily, and the threads of the bolt will not get chewed up by dragging them through the pin and arm area which is in an uncompressed state.
Size check - Is that an 8" clamp from Harbor Freight? _________________ How to Post Photos
Posted: Wed Mar 08, 2017 4:43 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
EverettB wrote: |
Size check - Is that an 8" clamp from Harbor Freight? |
Yes, correct. The top needs to be modified for beam clearance. Took some trial and error to get it right, without totally compromising any structural integrity. Hasn't broken yet!
I would think that a smaller clamp would work too. When I bough it I wasn't sure how big to get, and since this one has worked so well, I haven't seen the need to try any other size.
hazetguy: invested?
RWK Samba Member
Posted: Thu Mar 09, 2017 7:42 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
anyone ever make the bushing driver? I have time and a lathe, have made MANY special tools over the years, getting ready to to do my 64 SC,
rwk |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Mar 10, 2017 10:18 am Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
RWK wrote: |
rwk |
Here are the drawings for many tools...
http://www.thesamba.com/vw/archives/info/local_manufacture.php |
Posted: Fri Mar 10, 2017 1:57 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Really a threaded puller works better. With a driver one will require removing the entire front beam to get enough room to swing a hammer. _________________ In Stereo, Where Available! |
Posted: Fri Mar 10, 2017 3:36 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
Eric&Barb wrote: |
With a driver one will require removing the entire front beam to get enough room to swing a hammer. |
this is untrue. jack the bus up, put it on jackstands, lots of room. and if you have, or have access to a lift, there is PLENTY of room. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Fri Mar 10, 2017 3:50 pm Post subject: Re: Bus Center Pin Replacement (Long, MANY pics) |
hazetguy wrote: |
this is untrue. jack the bus up, put it on jackstands, lots of room. and if you have, or have access to a lift, there is PLENTY of room. |
Sure on a lift, great, but jack stands are not going to be enough room to get a real good swing at it.
Even then you have to swing uphill, with crap falling in your face.. Again a puller is a lot easier and less cursing. _________________ In Stereo, Where Available! |
