Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Mon Jan 07, 2008 6:17 pm Post subject: |
Sweet. I have ordered my disengagers. Now where do i get the grommets from?
and what about the BD only sliders?
I wish when people said 'exact reproductions of the original items' they really ment it! |
barnjunkie Samba Member
Posted: Mon Jan 07, 2008 6:19 pm Post subject: |
BeaterBarndoor wrote: |
they are for the most part the same. unfortunately i dont have a photo of barndoor disconnects but i have inspected some a few years back. other than the "frame" of the disconnects being a little different ,the shaft as well as the brass threaded tube which the shaft goes through and secures the unit into place is really what would need lengthening to make up for the added space due to that rubber gromet .
i think you could maybe get away with using a 55-64 unit but i wont promise. i modified my later units by lengthening both parts described.its been some time but i think i just used the brass threaded part from a standard barndoor shaft and installed into place on the disconnect unit after welding the needed length onto the shaft. |
Will this help ?
Any news yet Mark _________________ Luca Brasi's got nothing on me
54 rhd Judson super narrowed
BDM Wannabe |
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 824 Location: North Carolina
Posted: Mon Jan 07, 2008 7:22 pm Post subject: |
hey Trevor,
below is the best representation based on memory using your photo.for some reason i just didnt have a camera and did not take any measurments on the BD pivots when i had them in hand. but the following on the left is my hack job of "photoshop skills" using windows paint to show what a BD pivot looks like roughly.someone must have some originals to post ???
ill PM you regarding your second question....
_________________ www.thebustransfer.com
Whaaaaat? |
NOS PARTS Samba Member
Joined: June 24, 2001 Posts: 377 Location: behind the wheel, safari's open
Posted: Mon Jan 07, 2008 8:05 pm Post subject: |
if you get those 55-64 safari wiper shafts, you wont be able to use the orig BD wiper (inner/outer) grommets, dome washer, nut and fluted dust cover
you will have to modify shaft, brass threaded bushing... |
Posted: Mon Jan 07, 2008 8:19 pm Post subject: |
got the 55-64 shafts on the basis that i can extend/modify the brass thread and shaft. (maybe using original non-safari ones that come with a bus).
I dont have to change the 'frame' size like you have with photoshop to make it work do i?
barnjunkie you called them 'bd safari pivots' in the Parts/Accessories Gallery but im pretty sure they are just 55-64 parts. |
Posted: Mon Jan 07, 2008 8:27 pm Post subject: |
to answer my own question, im pretty sure no one is making the BD sliders. But they look fairly easy to replicate. Lazer cut 4mm steel.
So if anyone has some OG BD safaris please please could they scan/photocopy a slider for me, either at real size or with measurements.
Oh and are all 4 sliders the same?
thankyou
P.s. when is Gerson going to start making repop Safaris? There must be a big enough demand. |
Posted: Mon Jan 07, 2008 8:37 pm Post subject: |
the 55-64 pivots will work after the length mods. the body wont make a difference. its exactly what i have in my 53 .
those sliders you posted ,to my knowledge are nothing to do with barndoor. at least ive never seen those. any barndoor safaris i have seen use the same slider as 55-67 safaris.but i dont claim to know everything.
i see Micro9301 just posted his real pivots.im guessingthese are the ones i had in my hand once? ill let him post his pic. _________________ www.thebustransfer.com
Whaaaaat? |
Drew Ogden Samba Member
Joined: February 19, 2004 Posts: 329 Location: Elbow Cay, Bahamas
Posted: Mon Jan 07, 2008 8:39 pm Post subject: |
Hope these help, not the best pics.
Posted: Tue Jan 08, 2008 12:00 am Post subject: |
those slider must be from a boat or maybe tempo matador safari's... even more rare!!
slider are the same 1950-67
make new shafts, new brass threaded bushings and buy new BD wiper grommets, while you are at it, buy a real looking 1 eyed duck and not those things that looks like 1 eyed goofy!
Drew, nice tossed salad!
bon appetite... |
