dave kroesen Samba Member
Posted: Tue Jan 01, 2008 11:20 pm Post subject: 356a speedo cable supposed to be lubed by motor?? |
driving the '59 today, motor oil started dripping very slightly from the connection to the rear of the speedo. since the cable drive is taken off the oil pump cover, is the motor oil supposed to feed up thru the cable? has a seal been compromised along the way? thanks for reading. _________________ 40-horses to freedom! |
mpribanic Samba Member
Joined: October 25, 2004 Posts: 3177 Location: Neptune Beach, Florida
Posted: Wed Jan 02, 2008 5:39 am Post subject: |
Do you mean the tachometer? The speedo cable is driven by the front wheel not the oil pump. _________________ Call your Cunado's:
https://vimeo.com/67661950 |
Posted: Wed Jan 02, 2008 8:35 am Post subject: |
my mistake, of course it is the tach drive. after 350 miles behind the wheelof the *a* , i was a little out of my mind last night. is it supposed to be oil fed? _________________ 40-horses to freedom! |
coad Samba Scapegoat
Posted: Wed Jan 02, 2008 9:22 am Post subject: |
I think it's like Microsoft Windows-- there's no such thing as "bugs", they're all "Undocumented features".
No, I think any benefit of some oil leaking into the cable would quickly be surpassed by the grime that would build up. |
OMT Samba Member
Posted: Wed Jan 02, 2008 8:03 pm Post subject: Oel flowing thru Tach Cable |
Hallo Dave,
There is seal in your Tach Drive ( at the oel pump)...it is going bad.
I recommend you change this seal or your Tachometer will fill with oel.
Hope this helps.
Al |
Posted: Wed Jan 02, 2008 10:05 pm Post subject: |
thank you so much al! i'll correct the problem at its source. ~dave _________________ 40-horses to freedom! |
