63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Sun Apr 08, 2007 7:42 pm Post subject: Basic Motor wiring diagram needed |
Does anyone out there have a basic motor wiring diagram they could share or explain? I have what has been told to be a 1600. I know it is sigle port with a 12 v generator. I have it on a stand. I would like to try and fire her up. The wiring was pulled prior. I am looking for coil wiring, generator wiring, regulator wiring, distributor, starter and anything else you could think of.
Thanks in advance. |
Semper_Dad Samba Member
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Mon Apr 09, 2007 7:59 am Post subject: |
Their listed 181 '73 diagram isn't accurate, the (very large) '74 diagram looks more like it. Since it's on a stand, you probably could use their given diagram - there's not too much to hook up - less if you don't care about the generator charging the battery.
I'm reworking my wiring and doing away with the test plug. That plug doubles the wires in the rear of the car and it's pretty worthless. |
suntour Samba Member
Joined: November 25, 2004 Posts: 443 Location: Woodinville, WA
Posted: Mon Apr 09, 2007 4:25 pm Post subject: |
Bug wiring is basically the same except for the gas heater setup. I used a wiring diagram for a 73’ beetle in the Haynes manuals when I rewired my car mixed with a 75 diagram when I switched to an alternator. _________________ Order of the Voodoo Spoon |
kubelmann Samba Member
Posted: Tue Apr 10, 2007 8:42 pm Post subject: |
The RoMTOC Thing Data CD now comes with all the air cooled VW wiring diagrams. |
