freekazoid Samba Member
Posted: Thu Feb 22, 2007 8:03 pm Post subject: rear defrost |
On my '70 Ghia I have the rear-air defrost port and a rear-windshield that has a now useless grid on it. I'm not sure which way to go on this. I could just hook up the air defrost and hope it works well enough on those random nights/mornings, although this car isnt meant to be my daily I would like the availability of it as a daily. Or I could get a replacement grid kit, I forgot the name of the one I found but it comes with the grid and relays and connectors and whatnot. I think the kit is about $50-70.
So what do you guys think? |
cudabnu Samba Member
Posted: Thu Feb 22, 2007 10:21 pm Post subject: |
Sometimes you can repair your grid. I believe I've seen a repair kit at Pep-Boys. Just take your volt meter and test line by line until you find a break. Make sure your defrost relay is working first! We fixed my brothers Eclips GSX this way _________________ RACE it, don't RICE it! |
74Ghia Samba Member
Joined: December 17, 2003 Posts: 2131 Location: Middle of Georgia
Posted: Fri Feb 23, 2007 4:23 am Post subject: |
I say get them both working. If the electric fails you always have the air defrost as a back-up when you need it. I think Eastwood or Eastbrook (?) sells a kit. _________________ Allen C.
2012 Silverado
53 FiberFab MG TD Replica (VW)
Life is hard and its harder if you're stupid. |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri Feb 23, 2007 6:06 am Post subject: |
Grid repair is easy.
If you close all the vents in the heating system (rear seat and front footwells) you get more then enough air out of the front and rear defrost. Just keep a towel handy to wipe up moisture. |
Plantman Samba Member
Joined: July 12, 2004 Posts: 688 Location: Brevard,NC
Posted: Fri Feb 23, 2007 7:47 pm Post subject: |
The company I got my rear window defrost grid from was http://frostfighter.com/ It came with good instructions and everything needed. The only draw back to it is that the grid lines don't follow the wrap around curve of the window. The next one I do, I will apply the wires individually to match the curve of the window. If you do use the kit you will have some extra of the wire grid, save some of it incase you damage one of the grid wires. I pitched the extra and now I need a piece to repair one that i screwed up.
David _________________ Every day may not be good, but there is something good in every day,
No matter where you go, there you are.
'69 bug & '71 Ghia |
