vwairheads Samba Member
Joined: March 26, 2007 Posts: 675 Location: chula vista
Posted: Mon Mar 17, 2008 2:31 pm Post subject: |
can you please post a type IV? |
Asunder Samba Member
Joined: April 16, 2006 Posts: 612 Location: The other Orange County..N.Y. State
Posted: Tue May 06, 2008 2:21 am Post subject: |
1967 with stock Solex 30 Pict 1 Carb, one year generator, and one year oil bath air cleaner. Missing is the small air cleaner bracket that attaches it to the bottom of the carb/top of manifold input.
Later edit..I am changing the pictures to my "new" 67 engine with more of the proper pieces such as fuel pump and coil
_________________ 1967 Type1 Zenith Blue
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Mon Jun 02, 2008 2:31 am Post subject: |
'71 Super all original only 68,000 miles. Only thing not right is missing hose from intake manifold to altitude adjuster.
_________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Mon Jun 02, 2008 8:01 pm Post subject: |
73 Type 4
_________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3436 Location: minnesota
Posted: Thu Aug 21, 2008 4:01 pm Post subject: |
Since there hasn't been any pics of a 1300 i figured i would add a picture of mine. It's in my '66 bug and this is the numbers matching engine that came in the car from the factory.
_________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
panic_fan Samba Member
Joined: April 21, 2008 Posts: 711 Location: Mcdonough GA
Posted: Tue Oct 07, 2008 9:03 am Post subject: |
My 1970 Deluxe Bus, T1
Still working on getting a few missing pieces.
One major difference that I have noticed is the metal fuel line, most that I see have a soft line & clamp where I have metal line with some sort of nut. see below.
_________________ Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
6volt "THE" Kabriolet Kid
Joined: April 14, 2007 Posts: 470 Location: North Carolina
Posted: Thu Oct 16, 2008 3:51 pm Post subject: |
is there a thread about the engine number like if it starts with AE is a DP 1600 H, is a 1500? _________________ 64' walk through panel
65'bug
85' wolfsburg cabby |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Marv [UK] Samba Member
Posted: Thu Jan 29, 2009 8:33 am Post subject: |
panic_fan wrote: |
The pic from the 70 deluxe is missing a few pipes. Just thought i'd clarify what should (and shouldn't!) be in there
Warm air inlet pipe is missing. THis should connect to a "stove pipe" bit of tinwear to gain the hottest air available when the engine is cold. This is to increase fuel vaporisation and prevent carb icing whilst the heat risers warm up. This is the bit that most VW mechanics throw out. Item 2 on this microfiche from Mr Atwell's site
Additionally, the warm air thermostat connection is missing. THis is a bicycle cable type affair from the thermostatic flaps. Ther are 2 types of oil bath filter, one mechanically controlled, one vacuum controlled. This one is mechanical. Look in the bottom left hand corner of the microfiche at items 40 - 42
The oil filler neck brether pipe is missing, item 11 on the fiche
And there is a fuel filter in the engine bay!!!!!!
Sorry for being pedantic |
Posted: Thu Jan 29, 2009 9:51 am Post subject: |
Marv [UK] wrote: |
panic_fan wrote: |
Thanks Marv! I have done a good bit of cleanup/replacement since then. Still not sure about the cable/tstat flaps. Id like to see a pic of one correct if possible. Thanks Samba
1970 Baywindow Bus
57streetrodbuggy Samba Member
Joined: November 17, 2008 Posts: 900 Location: Santa Cruz, CA
Posted: Sun Feb 01, 2009 12:44 am Post subject: |
panic_fan wrote: |
that looks like brakeline _________________ Bermoco buggy on 57 pan - under construction
There's no such thing as too much horsepower, there is only a point where the car breaks in two |
EverettB Administrator
Joined: April 11, 2000 Posts: 69834 Location: Phoenix Metro
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Thu Feb 19, 2009 5:08 am Post subject: |
1974 convertible w/ EGR, and original SVDA, 34PICT3, fuel pump, and throttle dashpot. The coil has a large VW logo stamped on its top end.
_________________ Mike
Sold my sedan
Parts... |
Harris Samba Member
Posted: Thu Feb 26, 2009 11:57 am Post subject: Engine Guide |
'62 40 hp 1385 |
wcfvw69 Samba Purist
Posted: Thu Feb 26, 2009 9:05 pm Post subject: Re: Engine Guide |
Harris wrote: |
'62 40 hp 1385 |
Nice, powder or paint on the tins? _________________ Contact me at [email protected]
The Samba member since 2004.
112Ben Samba Member
Posted: Sat Apr 04, 2009 8:19 am Post subject: |
so i guess the stock engine for my "74 1200cc beetle is the 40hp engine?
if it is one.. what basic parts should i change to make it more reliable? |
outoftheoffice Samba Member
Joined: March 02, 2009 Posts: 470 Location: Houston, Texas
Posted: Tue Apr 28, 2009 12:14 pm Post subject: |
36 horse from my 58
Posted: Thu Apr 30, 2009 3:15 pm Post subject: |
vugbug68 wrote: |
73 Type 4
Didn't '73 T4's have duel Solex carbs?
jim _________________ '72 FI Westy
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Tue Jun 16, 2009 11:31 am Post subject: |
Hi all,
That fuel pump in the photo (dome-top and threaded inlet with a threaded nut metal fuel inlet line) is correct I believe up through 1968 or '69 Type 2. There are photos of it in the 1968 T2 owners manual. Not sure if it went thru 1970 though. It was eventually replaced with the later pump that has a top held on by 4 screws, has a cone shaped internal fuel filter screen behind a big brass nut/cap, and both the inlet and outlet pipes on the pump are brass pipes that a rubber fuel line connects to. Get out your 1970 Bus owners manual and look for photos of the type of pump you should have.
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Tue Feb 09, 2010 10:32 pm Post subject: |
1995 - Type 1 (Itamar) - 1600cc - Last Beetle made in Brazil til 1996
_________________ 1957 Typ 113 - Polarsilver
1959 Typ 113 - Flint Grey
1975 Typ 221 - Last yr Brazilian Split Window
Ighor Toth
