Posted: Thu Jul 28, 2016 8:34 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
iheartstrangers wrote: |
I've also learned that the ET is 37, which is the same as the stock wheels, right? Any chance that I will not need spacers and bolts? |
That depends on the width of the wheel. If they are 15x7s then you will definitely need spacers on the front. The rear could be installed without spacers, but since the rear track width of the 2wd Vanagon is already 16mm narrower than the front track width, it looks really odd without rear spacers, especially once you add front spacers since that increases the track width discrepancy. In addition, with the correct rear lug nuts, the stock rear studs are right at the minimum as far as safe thread engagement is concerned. Adding rear spacers will make the final installation look better and will add stability (wider track width). Adding longer rear studs will improve the thread engagement and will allow you to run the rear spacers.
No matter what you do, assuming the wheels are 15x7, you will definitely need new front lug bolts, front spacers and new rear lug nuts. There's no safe way around that. If you want to make the installation the best it can be, you will want to add rear spacers and studs as well. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1891 Location: Sidney B.C. Canada
Posted: Thu Jul 28, 2016 9:33 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Hi,
I recently machined a set of steel wheels. Was a bit of a shaky set up, I shot for nominal 67 mm bore as I wasn't sure I could hold to 66.56 mm. They fit up on the hubs fine.
Pics etc here.
https://shufti.wordpress.com/2016/07/09/vanagon-boring-steel-wheels/
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
iheartstrangers Samba Member
Joined: May 19, 2010 Posts: 47 Location: Portland, Maine
Posted: Thu Jul 28, 2016 5:25 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Waiting to get my wheels back so I can make sure measurements and ask a few final questions.
Thanks so much for your help. You really are saving the day (and my wallet). _________________ --
My name is Joshua and I am just getting started with an '84 Adventurewagen |
Posted: Fri Jul 29, 2016 10:41 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I picked up the wheels from the machine shop today. The center hole is just lovely. Thank you for the correct measurement.
The wheels are VW Ronal wheels and they measure 15 x 8 with a 37ET.
I put one on the front and wasn't able to secure it because it is too deep and, as you said, I will need longer bolts.
Would you mind giving me some specific recommendations for what to do from here? Namely, what spacers and bolts do I need for front and back?
Thank you! _________________ --
Posted: Fri Jul 29, 2016 11:02 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Did this measurement come from throwing a tape measure over the entire width of the wheel? I'm guessing so. The wheel size should be cast/stamped into the wheel somewhere and I would be willing to bet that your wheels are 15x7, not 15x8. Wheels are measured inside the rim lips from tire bead seat to bead seat.
Assuming they are 15x7, I would recommend 10mm spacers for the front and rear. Small ball seat (not large ball like the Vanagon lugs) front lug bolts, longer rear studs and small ball seat rear lug nuts would round out the parts package. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Fri Jul 29, 2016 11:52 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
You are right again! 7J x 15H2
Is there a preferred recommended place for buying said spacers, lugs, and bolts?
Thank you, thank you, thank you. _________________ --
wyldryce Samba Member
Joined: August 14, 2011 Posts: 83 Location: Annapolis, MD
Posted: Fri Jul 29, 2016 1:13 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thank you, thank you, thank you. |
Um, yeah. Though he'd never toot his own horn, I'm happy to. T3Technique! (Christopher's business) THE BEST customer service and expertise. |
Posted: Fri Jul 29, 2016 1:42 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Wonderful!
Posted: Fri Jul 29, 2016 2:31 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
If I may...
Just one more question (I think).
With switching from 14's to 15's, what should I consider for tire sizes? Is there an optimal size for driving around the country? _________________ --
Posted: Sat Jul 30, 2016 7:14 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
You've probably discovered the tire thread by now...
http://www.thesamba.com/vw/forum/viewtopic.php?t=584507
I don't want to sully up the wheels thread, but do some reading, with a careful eye towards getting a tire with appropriate load rating (doubly true as you have an adventurewagen ie; super-heavy). |
Posted: Sat Jul 30, 2016 3:44 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks to Christopher at T3 Technique, I now have my C class 17" rims mounted up with new spacers and stud kits. Went with Khumo Ta71 Solus' front and rear (staggered fitment) with 225/50/17 front and 245/45/17 in the rear. With all new suspension springs,Powerflex bushings and shocks, she's sitting pretty tough. Firm ride, but should handle twisty roads and spirited driving well.
Posted: Sun Jul 31, 2016 5:57 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
THANK YOU! _________________ --
Bladeserpent Samba Member
Joined: December 19, 2008 Posts: 50 Location: Virginia
Posted: Tue Aug 02, 2016 6:19 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Would 18x8.5 et30 work on a 82 Vanagon? What kind of modifications would i need to do? All I read about was possible trouble with the little center hub where the speedo goes, not sure about anything else. I'm trying to fit these exact wheels http://www.aspiremotoring.com/products/esr-wheels-sr02-gold |
Posted: Tue Aug 02, 2016 6:34 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Bladeserpent wrote: |
Unfortunately 8.5" wide is not a good fit on the front. The additional width forces the wheels outward and with the 2wd Vanagon's front track width already being wider than the rear, it forces wheels out too far to look decent and it causes tire to fender clearance issues. In addition, due to the Vanagon's large hubs, you would not be able to run center caps unless you made something custom.
Nothing is impossible, but that size and those wheels are not necessarily recommended. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Halifaxwesty Samba Member
Joined: October 21, 2012 Posts: 213 Location: Halifax, Nova Scotia, Canada
Posted: Mon Aug 22, 2016 10:24 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Anyone recognize these?
Posting says they are 17 inch, 5X112 and were formerly on a 1998 A4.
Really like the look of them and I anticipate the center bore will be too small...but I would love to know more about them and If they would work on 84 2wd. _________________ 84 Westfalia Vanagon
2.2 RMW Conversion
Work in Progress
My first car was a 1968 VW Bug |
Posted: Mon Aug 22, 2016 3:27 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Halifaxwesty wrote: |
Really like the look of them and I anticipate the center bore will be too small...but I would love to know more about them and If they would work on 84 2wd. |
Got a link or picture? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
baltik Samba Member
Posted: Mon Aug 22, 2016 4:07 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Chris - I am loving the look of these wheels but they are 16" x 7.5" et45. Is this doable for a Syncro with spacers or is the width too much?
Posted: Mon Aug 22, 2016 5:44 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Sure do...lol....it was there when I previewed it.
2.2 RMW Conversion
Work in Progress
UngaWunga Samba Member
Posted: Tue Aug 23, 2016 12:52 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Christopher Schimke wrote: |
No matter what you do, assuming the wheels are 15x7, you will definitely need new front lug bolts, front spacers and new rear lug nuts. There's no safe way around that. If you want to make the installation the best it can be, you will want to add rear spacers and studs as well. |
Excellent thread.
For a Syncro, would the 15x6.5 ET37 wheels fit with 205 or 215 tires without spacers, after boring out the center to the 66.56mm diameter?
Thanks for the guidance. |
Posted: Tue Aug 23, 2016 1:59 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Not sure if this is helpful for folks, but Christopher at T3 was a godsend and the only reason I was able to sort this out.
The front set went on like a breeze. The hiccup in the rear was the axle nuts. After soaking them in Kano Kroil and destroying a breaker bar, I got someone with a better/bigger breaker bar to help get them started for me. I also had to pound the daylights out of the drums to free them. After all that, though, everything was very smooth.
15 x 7 Passat wheels. ET 37. 10mm spacers on front and back. New studs, nuts, and bolts. Tires are 215 65 15. And I still have room.
I had little money and loads of time. It is very possible to do this on a budget. _________________ --
