sandys73 Samba Member
Joined: February 16, 2006 Posts: 45 Location: Bothell, Washington
Posted: Wed May 24, 2006 6:29 pm Post subject: need a new transmission |
i have a 73 bug tranny pushin 30" wildcats and reverse is out of it. its horrible! i can go wheelin with no reverse (well i have been using a come-along!) anyways, i was wondering if anyone had any suggestions on what kinda tranny i should put in it as a replacement, or if there is a tranny better built for pushin 30's. _________________ greasy hands, beater car, and no cash |
Nicksan Samba Member
SHMO Samba Member
Joined: July 29, 2004 Posts: 1647 Location: Lynden, Washington
Posted: Thu May 25, 2006 8:07 am Post subject: |
Or just do a Bus converion. The 002 (aka 3-rib) Bus trannies are much lower geared and will work well for pulling 30 inch tires. They are also much stronger. Keep in mind however, ALL VW trannies have weak reverse gears. Be gentle with that one.
SHMO |
SHMO Samba Member
Posted: Thu May 25, 2006 8:10 am Post subject: |
002 bus trans
SHMO
Posted: Thu May 25, 2006 7:39 pm Post subject: |
SHMO wrote: |
SHMO |
ok i am considering on doing this swap. does everything bolt right up? i know there is some sort of difference in the high that the hockey puck sits. but other than that, i have no idea _________________ greasy hands, beater car, and no cash |
USMCord1 Razorback
Posted: Thu May 25, 2006 7:42 pm Post subject: |
Axles,cv's, stub axle, tranny axle flange maybe arms, depends on how far ya want to go. _________________ For a Good time |
Big Dave Samba Member
Posted: Thu May 25, 2006 8:30 pm Post subject: |
SHMO wrote: |
002 bus trans
SHMO
Is that the premade aluminum shifter coupling? How does it work? I haven't heard too much good about them.
I just made my own by welding two bug couplers on top of each other and welding some plates to it to make sure it doesn't bend. |
subybaja Samba Member
Joined: July 06, 2005 Posts: 1026 Location: Anchorage
