Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Fri Dec 07, 2007 11:37 pm Post subject: |
Regarding that used dual stage air compressor that I bought, it has a Century 220 volt, 22.0 amp, 5 h.p. electric motor. I've mounted the power box and the Furnas magnetic starter on the wall next to it. The top of the air compressor had hit the starter box (the door was off) when it was laid down on the bed of a truck when I was picking it up and, today, I noticed that the front plastic piece that was attached to the base behind it is broken clear across.
Is it necessary to use a magnetic starter with a 22 amp, 5 h.p. electric motor, or can I get rid of it and have the three wires go directly from the power box to the little air regulator box on top of the air tank? |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Sat Dec 08, 2007 9:07 am Post subject: |
alexh wrote: |
Sort of a crazy idea but here it goes...
Has anyone tried to rig a super huge compressor unit using a huge 5000+ gallon tank off a 18 wheeler fuel or water truck (or any other huge tank)and several high output multi piston compressor units to fill and preassurize?
Watch out for the light bill when running this one! |
Those tanks are not designed to contain air pressures like you would get on a compressor (125-175 psi). They would blow up into the shape of a pillow....
Cool idea though............. _________________ John Henry
'57 Deluxe
'56 Single Cab |
reasley Samba Member
Posted: Sun Dec 09, 2007 7:30 pm Post subject: |
Campy
The magnetic starter provides two services to the motor on your compressor. It has contacts large enough to take the full amperage load on start up and it provides overload protection. You could probably get the pressure switch to work for a few cycles, but it would soon burn up the contacts. A replacement starter should be around $60. |
AJ Quick Samba Member
Joined: July 20, 2006 Posts: 539 Location: Minnetonka, MN
Posted: Mon Dec 10, 2007 10:29 am Post subject: |
Campy wrote: |
Is it necessary to use a magnetic starter with a 22 amp, 5 h.p. electric motor? |
Absolutely!
alexh wrote: |
Has anyone tried to rig a super huge compressor unit using a huge 5000+ gallon tank off a 18 wheeler fuel or water truck (or any other huge tank)and several high output multi piston compressor units to fill and preassurize? |
Would be completely pointless.
That is how they used to do it. With duplex or more compessors filling a large tank. 1000-2000 gallons.. but the actual compressors are much better at pumping CFMs then they used to be. For the cost and risk.. a simple screw style compressor would be much better. If I were designing a big system for cheap.. two compressors on each end with a fairly large storage tank somewhere would suffice. _________________ Read My Beetle Restoration Blog!
http://www.RideSpace.net/
http://www.AJQuick.com/ |
Bugs'n'Pugs Samba Member
Joined: July 18, 2004 Posts: 1453 Location: Charleston, South Carolina USA
Posted: Tue Dec 18, 2007 2:46 pm Post subject: |
This is a difficult question to answer. There are so many different manufacturers out there. No one could know them all. There' s no free lunch. Its always a trade off between amperage and cfm. That's the reason for moving up to 220 volts. it drops the amperage by 50%.
I've seen up to 7.5 cfm at 100 psi on a 110 circut. They draw around 20 amps and would have to be on a 25 amp circuit at a minimum. You can't just plug these into an outlet as it usually uses a different plug. A 6 to 6.5 cfm will draw about 15 amps and will run on a 20 amp circuit. Any compressor manufacturer that sells into the consumer market will have one of this size. Re-read John Henry's post on page 2 and shop around. |
Campy Samba Member
Posted: Tue Dec 18, 2007 11:03 pm Post subject: |
Regarding my dual stage air compressor, I need some help with the wiring: the three wires from the electric motor go up to the magnetic starter, and black, white, and green wires go down from the magnetic starter to the small air regulator unit on top of the tank. The plastic piece in it has four connections for wires: I have the black wire connected to the right one, which is marked 'line"; to the left of it, the connection is marked "motor," the one to the left of it is the same, and the connection at the far left is marked "line." Should the white wire go to the connection marked "line"? When I first got the air compressor, an electrician had wired it and he the black wire going to "line" and the other wire going to "motor", which didn't make sense to me. There is a screw in the metal case for grounding a wire, so I have the green wire going directly to it. |
Posted: Thu Dec 20, 2007 11:29 am Post subject: |
Campy
The black and white wires from the magnetic starter connect to the terminals marked "motor". The terminals marked "line" connect to your incoming power leads. The white wire is not a common. In a 220 circuit both leads are hot and need to be switched. It is also absolutely required that you attach the green ground leads from the power source as well as from the starter.
If you are at all uncomfortable or unsure hooking these up seek help. |
Campy Samba Member
Posted: Thu Dec 20, 2007 12:48 pm Post subject: |
Thanks for the information, reasley. I have the power box, which came with the air compressor, on the wall and the wires go from it to the magnetic starter. Its on/off lever is what he used to turn the air compressor on and off. The three wires coming out of the starter go to the air regulator unit on the air tank. The electrician he had set it up had the black wire at the "line" terminal and the other wire at the "motor" terminal next to it. Yesterday, I connected the white line to that "motor" terminal and the air compressor worked. Should I leave it that way or try it with both wires connected to the "motor" terminals?
The oil drain bolt is in the typical spot at the base of the pump, with flat metal in front of it, so there is no way to get a funnel next to it. With my smaller horizontal air compressor, I used to lean the unit toward the side so the oil would drain out through a funnel and not on the air compressor, something which I can not obviously do with a vertical tank mounted on the garage floor. Does anyone have a suggestion for getting the oil out of the pump without making a mess? |
Posted: Thu Dec 20, 2007 2:23 pm Post subject: |
The oil drain is easy. The plug is most likely 1/4" npt (could be 3/8"npt). Just buy a pipe nipple long enough to reach over the edge of the platform and a 90 degree elbow. The existing plug will screw into the elbow to seal it off.
As for your wiring issue. It won't usually matter whether you attach the mag starter on the line side or the motor side of the switch. But... do it right, be consistant. Hook both hot wires from the starter to terminals in the pressure switch marked "motor". Hook the 2 hot leads from the power source to the terminals marked "line". Both green wires should be grounded to the pressure switch body. The wiring of this beast is critical to your safety. Do it right. |
Posted: Mon Dec 24, 2007 10:11 am Post subject: |
Bugs'n'Pugs wrote: |
What is the biggest (by cfm) compressor on the market that can be used with 110-volt? |
I'd say about 5-7 CFM.. and that amount would be hard to get.
A gas engined compressor can deliver higher amounts, and be run outside.. if you don't have a 220 outlet available. _________________ Read My Beetle Restoration Blog!
skatepopwar182 Samba Member
Posted: Mon Dec 31, 2007 7:41 pm Post subject: |
I bought my 25 gallon 1.8 hp craftsman for loke $360 it does 6.8 cfm at 90 psi. I wish I would of gone bigger but it gets the done and it was right in my price range. |
clinkfield Samba Member
Posted: Thu Jan 10, 2008 2:38 pm Post subject: |
Anyone have any experience with the 80 gallon Kobalt compressor that is sold at Lowes? _________________ Cary
67 Deluxe
28" Chagoi |
DarinNDebra1961VW Samba Member
Joined: October 12, 2006 Posts: 48 Location: Saraland Alabama
Posted: Fri Jan 11, 2008 1:32 pm Post subject: buying a compressor |
I know that we're all compelled to look at the relatively inexpensive compressors that are available from Sears, Lowes, Home Depot, Sams Club...places like that.
If you're looking at a 5hp compressor...be aware. A real 5hp 1 phase electric motor weighs almost 100lbs.. and the shaft is 1 1/8" diameter and these big boys turn 1800rpms. Dont be in the mindset that the 3600rpm motors are what you need. All these are doing is slinging a cheaply built aircompressor to pieces.
A real air compressor has cast iron (finned cylinders) just like the ones on our vw's. And they can be rebuilt later down the road. If you buy the cheap one, sure you'll get some use out of it. When it breaks, you have a piece of junk that is worthless. In the long run it would be better to stick with a good heavy compressor with a cast iron pump. Champion, Ingersoll Rand, something like that. Does it cost more? sure does. It will last you for decades if well maintained and serviced.....
A dead give away...if the motor on the 5hp compressor is the size of a coffee can? or says SPL on the data plate where HP is normally listed....just walk away. Its not what you're expecting. |
Posted: Fri Jan 11, 2008 1:36 pm Post subject: Air Compressor |
Another point I forgot to mention. Dont look for longevity from the direct drive air compressors. Look for one thats belt drive. Otherwise you have something you have to go back to the OEM to get a replacement motor for. You can rest assured that they will thoroughly spank your wallet. If your belt driven, you can buy the motor at any reputable electric motor repair shop, or industrial supply company.
Im in the electric motor repair business. Not looking to plug for business, just want to share with my friends what works and doesnt work. I get these small homeowner type compressors in my shop all the time for repair (this should be a sign) and 99% of the time, they are toast and have to be replaced.
If you can afford to go with the higher quality, then for god's sake please do so. You wont regret it. If you cant? then buy the homeowner style machine, but just dont expect a long life from it.
Thanks friends !!!!!!! |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Sat Jan 12, 2008 6:09 am Post subject: |
Define long life. If you buy a homeowners compressor and use it as a homeowner/hobbyist it ought to last while. 5 years ago I bought a Husky Pro, 7hp peak, single phase 220v, 60 gallon, 10.3 cfm @90 psi, cast iron, 100% duty cycle. $400 dollars and absolutely no problems. Built my Buggy and repaired my Bus. It almost keeps up with a cut off grinder some times called a whizzer. I don't give it much of a break, when using it, when the lack of air slows a tool to where it doesn't want to work, I'll stop until the compressor stops and start right back up. Probably should have gone up a size or two, but I spent what I could afford. Did I say I haven't had a single problem with it. It was, at the time, the smallest 220V they had at Home Depot.
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
Posted: Sun Jan 13, 2008 4:23 pm Post subject: Re: buying a compressor |
DarinNDebra1961VW wrote: |
If you're looking at a 5hp compressor...be aware. A real 5hp 1 phase electric motor weighs almost 100lbs.. and the shaft is 1 1/8" diameter and these big boys turn 1800rpms. Dont be in the mindset that the 3600rpm motors are what you need. All these are doing is slinging a cheaply built aircompressor to pieces. |
Don't forget a lot of compressors will say 5HP, but they mean 5HP peak.. they tend to run at 1-2HP. I had a heck of a time trying to sell my top of the line Home Store compressor because I accurately represented it as a 1.9HP... where everyone was saying they could get a 5HP one for cheaper..
Another thing to look at is Oilless vs Oiled Compressors.
Don't even bother with an oilless compressor. They are loud.. noisy.. and destin to break. Imagine running a car engine without oil.. eventually it will seize. When buying a compressor, do not even bother looking at direct drive oilless compressors.
Go straight to Oiled & Belt driven ones.. Cast Iron is a plus.. Same with 220v. _________________ Read My Beetle Restoration Blog!
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Frankie Pintado Samba Member
Joined: April 02, 2008 Posts: 372 Location: Lake of the Woods, VA
Posted: Sun Apr 27, 2008 12:01 am Post subject: |
gabe321 wrote: |
Hey I've sand blasted and painted my 66 beetle with a 8 gallon Cambell air compressor which I bought at Walmart for $225 on sale past Summer. It did the job and it did it well, just had to wait to reload but it wasn't a big deal. |
You have given me hope. I don't have the space or money for an $800 compressor. Do you have any pics of the car finished? |
substock Samba Member
Posted: Thu May 08, 2008 5:26 am Post subject: |
I got one that does an honest 7CFM with 110, It sucks over 20 amps from the wall so you need a 30 amp circuit to run it....it'll also accept a conversion to 220 if you aren't confident with that much current going through the wires. It's not big enough for media blasting or running a DA for very long....I'm currently shopping for a unit that can deliver an 11-15CFM @ 90PSI. Hopefully that will be enough...as I usually work alone.
j. |
