Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Mar 15, 2016 8:24 am Post subject: Re: The Tire Sticky |
johns68doublecab wrote: |
Well, it's time to close this one out. I went to Walmart with both front tires. The passenger tire looked okay, but the driver-side tire had a funny twist to it.
This is the tire when they removed it from the wheel. They said that they'd never seen anything like it. I have to agree.
Again, thanks for the help.
John |
... I've only driven 500 miles since it's been back on the road after several years. ... |
What would cause a tire to assume that shape? Pinched from being uninflated with the wheel down to the ground? Did the steel take a warped set?
Aloha
tp |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Tue Mar 15, 2016 8:32 am Post subject: Re: The Tire Sticky |
That tire is toast, could be any number of things caused it. Used on a rope swing, used as shock absorber on a tow rope, supported an engine while in the back of pickup….. I wouldn't use it on the road no way, no how!
Bill _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20282 Location: Sandpoint, ID
Posted: Tue Mar 15, 2016 8:35 am Post subject: Re: The Tire Sticky |
Tom Powell wrote: |
Aloha
tp |
Tread separation and/or belt shift. I would bet that a side shot of the tire will show it seriously out of round radially.
Glad this was found and fixed. Throw that tire in the scrap pile, or better yet, hang it on the wall as a reminder of what can happen. I am curious of brand, build date, ply count, etc. too. _________________ nothing |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Thu Mar 17, 2016 4:33 pm Post subject: Re: The Tire Sticky |
I decided to order my tires, hankook RA08, because I'm going camping in early April and this will be my longest trip with the bus so I wanted to minimize any issues.
I ordered through Amazon via bestwheelsonline who are based in CA and because amazon gave me an instant $80 gift card making the 5 tires less than $500 shipped. I wanted the RA18's but they weren't available anywhere. I figured I'd get a call from the seller to opt for the newer tired instead of the RA08's and sure enough I did.
I ordered late Monday and they arrived today:D
I plan on getting them installed at Costco. They use a lift (looks like an X) and they hand torque the lug nuts. Any suggestions or anything I need to let them know about mounting my tires? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
wet_bread Samba Member
Posted: Thu Mar 17, 2016 10:17 pm Post subject: Re: The Tire Sticky |
ivwshane wrote: |
Any suggestions or anything I need to let them know about mounting my tires? |
Get them balanced. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Thu Mar 17, 2016 10:42 pm Post subject: Re: The Tire Sticky |
ivwshane wrote: |
I plan on getting them installed at Costco. They use a lift (looks like an X) and they hand torque the lug nuts. Any suggestions or anything I need to let them know about mounting my tires? |
That's a sweet deal! Now you can post a ride report for us. To tell you the truth, any feedback I could've given would be somewhat meaningless since I've only put about 20 miles on my Westy, and that was on 23 year old tires, so I have nothing to compare with.
Just make sure your tires don't have a yellow dot on the lower sidewalls (my new RA18's do not). If they do, make sure the tech lines yellow dots up with the valve stems (but again, I doubt they have them).
But do this: insist that the tech put the DOT date code on the outsides...Insist, because the date code is only on ONE side of each tire, and whether for you or someone else, you don't want to have to crawl under the car to see them if you don't have to. |
Posted: Thu Mar 17, 2016 11:49 pm Post subject: Re: The Tire Sticky |
Thanks! The tires had two date codes, some were made in late September 2015 and others in early October 2015. I don't recall seeing any yellow dots though. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Fri Mar 18, 2016 2:12 pm Post subject: Re: The Tire Sticky |
What does the yellow dot signify? _________________ nothing |
Posted: Fri Mar 18, 2016 5:58 pm Post subject: Re: The Tire Sticky |
It's the lightest point on the tire, so to put it adjacent the heaviest part of the wheel is supposed to counter the weight (to a degree, I suppose) and give you a balancing advantage, such as maybe fewer or no weights at all. Just cuz these HKs don't have 'em doesn't mean they're perfect tires, its just not mandatory to identify the light spot. I think a red dot identifies a high spot on a non-concentric tire, or runout. Any other colors are just random. |
Posted: Fri Mar 18, 2016 8:14 pm Post subject: Re: The Tire Sticky |
Busstom wrote: |
Thanks. _________________ nothing |
Posted: Fri Mar 18, 2016 8:48 pm Post subject: Re: The Tire Sticky |
I got my tires mounted today at Costco for $70 for all five. They almost couldn't do it because their books didn't go back far enough but luckily, thanks to samba, I was able to give them the torque specs (they needed to see it in the manual) and the psi recommendations.
Handling has improved greatly! With my new koni shocks I'd say the tires have improved handling with a 60/40 ratio, meaning the tires can be accounted for 60% of the improved ride handling while the shocks made up the rest of the improvement. The bus feels much more secure when doing sharp turns.
One thing costco did note was that my rims were a little rusted. I plan to get them powder coated by Schwab, who will blast them. Is that good enough to take care of the rust or do I need to do some other prep as well? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Sat Mar 19, 2016 9:38 am Post subject: Re: The Tire Sticky |
You'll be in great shape if you powder coat the rims, they'll do a full sandblast prior to spraying them...ask to confirm they do the inner rim too (under the tire) too, I'm sure they do. Just do a search around here for that other thread, there's a back-and-forth about cleaning the coating from the lug seats so your lug nuts don't come loose |
Posted: Sat Mar 19, 2016 11:31 pm Post subject: Re: The Tire Sticky |
Here are the pictures of the hankook RA18 tires I got.
69 ghia coup 1600dp
70 single cab |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Tue Mar 29, 2016 12:43 pm Post subject: Re: The Tire Sticky |
Ron, do you all have the RA18’s in yet?? I’d like to continue to be the Arkansas buyer of Bus Depot!
IF not, are the manufacturer’s date fairly recent on the RA08’s y’all have left? It’s basically April now, I mean, c’mon..... |
Busdepot Samba Member
Posted: Wed Apr 06, 2016 2:05 pm Post subject: Re: The Tire Sticky |
The R08's are now gone. I have exactly ONE left, a 185R14. If you have a set of RA08''s and want a matching spare, this is your last chance to grab one. I'll knock it down to $93 plus shipping. PM me if you want it. I'll post here when it's spoken for.
Still waiting for an updated ETA on the RA18's, will keep you posted. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
srfndoc Samba Member
Posted: Wed Apr 06, 2016 2:45 pm Post subject: Re: The Tire Sticky |
If your in Austin (or anywhere close) this seems like a great deal:
http://austin.craigslist.org/wtd/5418546264.html _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Wed Apr 06, 2016 5:28 pm Post subject: Re: The Tire Sticky |
Actually it's an exceptional deal. Someone near Austin should grab 'em. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Thu Apr 07, 2016 12:42 pm Post subject: Re: The Tire Sticky |
Dang, that is good and less than 15 minutes from where I work!
I don't need tires, but if I did I'd be all over that! _________________ 1976 Westy
1966 Beetle |
Ace.perkes97 Samba Member
Posted: Mon Apr 11, 2016 10:17 pm Post subject: Re: The Tire Sticky |
Will a P225/70R14 fit on my stock vw bus rim lowered 2"? |
Posted: Wed Apr 13, 2016 8:07 pm Post subject: Re: The Tire Sticky |
Anyone have any knowledge or experience with Hercules Ironman HSI-S 185R-14C tires?? Weight is just over 1800lbs a tire. 8 ply. I know Hercules is a similar tire to Cooper, and I am a big fan of Cooper tires. I am curious about drivability and handling, they happen to be extremely cheap compared to the BFG's and even cheaper than the RA18's by Hankook that are now out. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
