NRG Samba Member
Joined: January 08, 2004 Posts: 28 Location: Ft Collins Co. USA
Posted: Sat Mar 11, 2006 11:24 am Post subject: Fuel line substitution? |
I need to replace a few sections of my fuel line ( 2.0 FI ) all I can find around town is 1/4 " not for fuel injection.
Will that stuff work or do I have to order the 7.0mm FI stuff.
The sections I am replacing are pre pump, so I dont think the pressure should be a problem, but I am not sure if the decrease in volume would cause premature pump failure.
Thanks |
deschutestrout Samba Member
Joined: May 15, 2005 Posts: 864 Location: Maupin, Oregon
Posted: Sat Mar 11, 2006 11:39 am Post subject: |
Get the 7mm FI stuff. Scott from German Supply can help you out! www.germansupply.com _________________ '71 bug, answers to "Clementine"
'75 7 passenger bus called "Kombi"
'78 7 passenger sunroof bus, goes by "Gus"
'78 Westy "'Ole Red...The Happy Camper"
'78 Westy "The Big Turd" |
Randy in Maine Samba Member
Posted: Sat Mar 11, 2006 3:58 pm Post subject: |
I know you can buy that locally in Ft. Collins. try the VW dealer or the Benz dealer. Want the FI quality though. |
Posted: Sat Mar 11, 2006 5:34 pm Post subject: |
I would guess Chris at BustedBus in Boulder could help you too...give you an excuse to hit the Walnut Brewery for a beer _________________ '71 bug, answers to "Clementine"
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Sat Mar 11, 2006 6:18 pm Post subject: |
NRG,
Can't help with the fuel line, but that is a great photo of Shane MacGowan! l |
steponmebbbboom Samba Member
Posted: Sat Mar 11, 2006 6:25 pm Post subject: |
he's a dreamboat! |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Sat Mar 11, 2006 7:38 pm Post subject: Re: Fuel line substitution? |
NRG wrote: |
I need to replace a few sections of my fuel line ( 2.0 FI ) all I can find around town is 1/4 " not for fuel injection. |
None of the auto part chains will be able to help you out.
Quote: |
Will that stuff work or do I have to order the 7.0mm FI stuff. |
1/4" is too small. You'd have to use 5/16" hose. Besides have too large an inside diameter (ID) the american hoses are either a) not high pressure b) go hard with 6 months and don't last or c) both.
You'll have to get some from your local VW parts supplier. OEVeedub is in Lake George, CO...look for these part numbers:
http://www.ratwell.com/technical/FuelHoses.html (see Locating Hose section)
Quote: |
The sections I am replacing are pre pump, so I dont think the pressure should be a problem, but I am not sure if the decrease in volume would cause premature pump failure. |
The fittings are not 1/4" so how would you get the hose to fit?
The best FI clamps (Gemi 13) at the best price are 7mm clamps for Mercedes Benz cars. Order (001 997 69 90) and look for 50-69 cents per clamp for a good deal (anywhere but the MB dealer of course). _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
