casey79westfalia Samba Member
Posted: Tue Feb 21, 2006 10:01 pm Post subject: oil filter mount |
My oil filter mount has a steel ball on the underside to the side of where the filter screws in. The steel ball is reccessed in the mount and there is a metal ring that holds it in. I cannot figure out which way this is suppose to go back in(it fell out when I removed the filter). Also is there suppose to be a spring between the steel ball and the metal ring that holds the ball in. Anyone have a pic of an oil filter mount from the underside.
Thanks _________________ 66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it" |
SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Tue Feb 21, 2006 10:54 pm Post subject: |
That ball is part of a pressure relief valve intended to allow oil to bypass the filter if the filter gets too clogged with crud. It isn't supposed to come out. Yes, there is supposed to be a spring behind it. Without the spring the valve will bypass the filter all the time.
Do not consider running your engine without getting this thing fixed!
You may very well be looking at sourcing another oil filter mount. Perhaps one of the Samba members can help with that. Otherwise, your next best option is to either find that spring or block off the hole completely, then be extremely anal about changing your filter regularly. _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
Posted: Wed Feb 22, 2006 8:11 am Post subject: |
Anyone got one by any chance. Even just the spring and ball?
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
germansupplyscott Samba Member
Posted: Wed Feb 22, 2006 8:29 am Post subject: |
the ball is swaged into the filter stand. if it comes out you need a new mount. i have good used if you need one. _________________ SL |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Wed Feb 22, 2006 8:30 am Post subject: |
I've got a couple extras, when do you need it.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Posted: Wed Feb 22, 2006 8:37 am Post subject: |
asap. What are you guys asking for them. I have lots of parts to if you need anything and wat to trade. _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Posted: Wed Feb 22, 2006 8:56 am Post subject: |
Whatever shipping costs are. If you want one PM your address and I'll have it in the mail in the morning.
Posted: Wed Feb 22, 2006 9:06 am Post subject: |
whip I pm'd you. _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
jberger Samba Member
Posted: Wed Feb 22, 2006 9:52 am Post subject: |
Is that ball not just a check valve for flow direction? When the engine is off it prevents oil from flowing back into the filter. I do not believe the mount has anything to do with pressure regulation. |
Posted: Wed Feb 22, 2006 11:39 am Post subject: |
jberger wrote: |
Is that ball not just a check valve for flow direction? |
Have another look at it. The valve is installed in a passage from the inlet side of the filter to the outlet side. It's in parallel to the filter, not in series, if you'll forgive an electrical analogy. The valve will open when pressure differential across the filter reaches a certain level. It has nothing to do with pressure in the rest of the system.
I haven't measured it myself, but it can be opened with light finger pressure. I believe that when considering the addition of an external oil cooler that taps off of the oil filter mount, one should be careful to ensure that the pressure drop across the additional cooling system doesn't exceed the opening pressure of this valve. Otherwise, not only are you turning your expensive "full-flow" cooling system into a bypass system, you may be bypassing the oil filter as well. _________________ Present:
Back in the day:
'72 Super Beetle
Posted: Wed Feb 22, 2006 12:08 pm Post subject: |
SlowLane wrote: |
jberger wrote: |
Have another look at it. The valve is installed in a passage from the inlet side of the filter to the outlet side. It's in parallel to the filter, not in series, if you'll forgive an elecirical analogy. The valve will open when pressure differential across the filter reaches a certain level. It has nothing to do with pressure in the rest of the system.
I haven't measured it myself, but it can be opened with light finger pressure. I believe that when considering the addition of an external oil cooler that taps off of the oil filter mount, one should be careful to ensure that the pressure drop across the additional cooling system doesn't exceed the opening pressure of this valve. Otherwise, not only are you turning your expensive "full-flow" cooling system into a bypass system, you may be bypassing the oil filter as well. |
The check valve is on the outlet side of the filter, the inlet is isolated from the outlet to prevent particles from entering the oil system. The check valve opens under very slight pressure and has nothing to do with pressure relief at the filter, which is taken care of by the oil pressure relief valve. |
Posted: Wed Feb 22, 2006 12:53 pm Post subject: |
jberger wrote: |
Please reference this drawing:
Note the sprung ball check valve at the right edge of the drawing, next to the filter. Ask yourself "under what conditions will the valve open?" When the pressure across the filter exceeds the opening pressure of the valve, right? _________________ Present:
Back in the day:
'72 Super Beetle
Posted: Wed Feb 22, 2006 1:03 pm Post subject: |
Right you are. |
Posted: Wed Feb 22, 2006 1:06 pm Post subject: |
Thanks. I knew we were agreeing at some level.
Where did you get that drawing, BTW? It's beautiful.
Oh, I see. Same place I found the first one. Thanks for the Web page, tuna! _________________ Present:
Back in the day:
'72 Super Beetle
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Feb 22, 2006 1:13 pm Post subject: |
jberger wrote: |
Is that ball not just a check valve for flow direction? When the engine is off it prevents oil from flowing back into the filter. |
The filter itself is responsible for anti-drainback. Some filters are more successful than others with this task. I have found that the good ol' Wix (NAPA) filter does a good job.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Wed Feb 22, 2006 9:51 pm Post subject: |
Phil I dont need the mount anymore check Pm. _________________ 66 Westfalia
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
