bnam Samba Member
Joined: July 02, 2006 Posts: 2957 Location: El Dorado Hills CA/ Bangalore, India
Posted: Tue Feb 01, 2022 7:00 am Post subject: Re: Welding equipment |
https://www.cruxweld.com/welding-cutting-equipments/tig-250/
I could use inputs on either of these machines - single phase or 3 phase versions. Do the specs seem ok?
There is also a 200A version, would that be enough? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
esde Samba Member
Joined: October 20, 2007 Posts: 5993 Location: central rust belt
Posted: Tue Feb 01, 2022 7:06 am Post subject: Re: Welding equipment |
Never heard of that manufacturer, so I can't comment on quality. But, what about service if something doesn't work correctly?
200A is more than enough for anything you need to do restoring a car, IMO _________________ modok wrote:
bnam Samba Member
Posted: Tue Feb 01, 2022 9:42 am Post subject: Re: Welding equipment |
esde wrote: |
200A is more than enough for anything you need to do restoring a car, IMO |
They are a local manufacturer and have decent service according to someone I know who uses them. I was wondering more about the difference between 200A and 250 - if the 200A would be sufficient for most needs in the garage. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Lie2me Samba Member
Posted: Wed Feb 02, 2022 7:59 am Post subject: Re: Welding equipment |
New to welding, thoroughly searched this topic.
My handy mig will not feed, I believe I've narrowed it down to the liner. Hoping for some assist before I pull the liner and take it to AirGas.
From my understanding, they are universal; cannot find verification. Will order Lincoln if required, but I'd rather procure one locally without
the cost of shipping--$10 to ship a $16 part hurts my soul.
Thanks in advance.
Will the Harbor Freight VULCAN MIG Gun Liner (0.025 - 0.045 In.)
work with a Lincoln Handy Mig (Code Number:10919, 11205)
[Item #11 Liner PN: S25351-50] |
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 282 Location: Colorado
Posted: Sat Jul 23, 2022 3:25 pm Post subject: Re: Welding equipment |
I'm kinda new to welding myself...been learning through research and grinding. I've got a thread over in the Oval forum... The 'Ol 55.
I've found some gems of info here on TS that have helped me along. I'm trying to accomplish what needs to be done with what resources I have. Currently only a Millermatic 175 so no TIG or spotweld, studweld capabilities. And self teaching/learning how to weld through what I can glean from anywhere I can get the info.
I recently watched this video for some insight into MIG welding body panels that just really helped me see the difference between TIG and MIG and where the applications differ...this guy's body work skills are top notch, everything from fabrication to dent repair...all of which I need to learn to get my old bug back on the road. Maybe someone else will find this useful. It's a little over an hour long with some fabrication, TIG and then MIG panel welding. The MIG welding portion begins around 52:30.
Semper Gumby Samba Member
Joined: November 30, 2022 Posts: 99 Location: Southwest Florida
Posted: Wed Feb 15, 2023 7:22 am Post subject: Re: Welding equipment |
My "handy me down" 30+ year old Lincoln welder finally sh*t the bed. Since I rarely weld anything thicker than 3/16" and am a mere hobbyist at it, I selected Eastwood's MIG 140 (120v - inverter technology) which replaced its 135 series system. I had the dedicated 20 amp line already so it was plug and play for me.
Not too shabby for a value / affordable MIG. Plus, I liked the 3-year warranty which beat a few other systems I considered.
If you're a hobbyist at it and don't want to break the bank welding the VW - Eastwood's 140 might be a good pick.
Lotos plasma cutter (R) and Eastwood MIG 140 (L)
_________________ "If you don’t have time to do it right, when will you have time to do it over?" - John Wooten |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2931 Location: Memphis
Posted: Mon Feb 27, 2023 1:53 am Post subject: Re: Welding equipment |
Semper Gumby wrote: |
I'm another Eastwood user, they make a robust and well designed welder. Around 2010 when I was welder shopping for the first time, one simply could not buy a mig welder with infinite controls on both wire speed and power for what, less than a grand? I finally decided on the MIG 135. After using it for about ten years, I recently replaced it with their 200 amp multi process welder and upgraded my bottle from an 80cf to 125cf. It comes with a 240v adapter plug so it's usable on a regular 120v receptacle.
I think the entry level gas-capable Eastwood welders will handle any hobby project like VWs, and beyond. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2263 Location: HdG, MD & NJ
Posted: Mon Jul 31, 2023 12:25 pm Post subject: Re: Welding equipment |
Anyone have a Amazon Yesweld tig welder. They start at $100 for a 145 and go up from there. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
SparksLP Samba Member
Posted: Sun Sep 24, 2023 7:20 pm Post subject: Re: Welding equipment |
Any good reason to step up to the Eastwood 180 from the 140? _________________ Tom
1966 VW Beetle Sunroof Sedan |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 574 Location: South of Raleigh
Posted: Tue Oct 03, 2023 6:25 am Post subject: Re: Welding equipment |
"Project Farm" did a nice comparison video of welders, from (IIRC) around $150 all the way up to $2200. He had a professional welder do the actual welding so the opinions seem to be valid. The biggest take-away for me is that the cheap welders had a narrower range of capability, i.e either they could do thick stuff or thin stuff better, but they didn't have the range of capability the $2200 welder had. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3905 Location: San Jose, CA
Posted: Tue Oct 03, 2023 10:42 am Post subject: Re: Welding equipment |
johnnyvw164 wrote: |
"Project Farm" did a nice comparison video of welders... |
Ahh, I haven't seen his welders comparo. Thanks for the tip, I'll have to check it out. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
