sweetlokin66 Samba Member
Joined: November 15, 2006 Posts: 1220 Location: Luftwagenville, FLDuh
Posted: Thu Apr 26, 2018 9:23 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
finally getting into the running phase on e85 _________________ Follow IG for more content @greyarearacing
Turbo type 4
http://shoptalkforums.com/viewtopic.php?f=3&t=134157
66 NA hard top
****Insert event here**** |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76963 Location: Sneaking up behind you
Posted: Fri Apr 27, 2018 3:58 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
WOOD _________________ Glenn
Member #1009
#BlueSquare |
vwjetboat Samba Member
Posted: Fri Apr 27, 2018 4:30 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
I wonder what the HP #s are ^^^^ and how much boost |
Posted: Fri Apr 27, 2018 11:30 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Setup for up to around 20ish lbs. Heads are step sealed w/copper ring, forged pistons. I'll see how the cylinders do as I work the boost up and go from there. _________________ Follow IG for more content @greyarearacing
Turbo type 4
66 NA hard top
Westbandit Samba Member
Posted: Sat Jul 21, 2018 8:28 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
2.0 Typ 1, Formula V Race Engine 165 HP
Glasser Samba Member
Joined: September 18, 2007 Posts: 1640 Location: Calgary Alberta Canada
PeteSC Samba Member
Posted: Thu Dec 06, 2018 7:48 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
EverettB Administrator
Joined: April 11, 2000 Posts: 69832 Location: Phoenix Metro
PeteSC Samba Member
Posted: Thu Dec 06, 2018 8:43 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
EverettB wrote: |
In a '58 Ghia too? Sweet. |
Yep....and thanks! |
Glenn Mr. 010
Posted: Mon May 20, 2019 4:03 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Here's what it currently looks like.
Member #1009
#BlueSquare
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Tue Jun 18, 2019 1:47 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Glenn wrote: |
Gorgeous as always Glenn! Do you use those air screens exclusively? |
Glenn Mr. 010
Posted: Tue Jun 18, 2019 1:51 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Since I don't drive it much I figured why not.
I can put on a set of uni-filfer foam if I need to. _________________ Glenn
Member #1009
#BlueSquare |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Wed Jun 19, 2019 1:12 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Edit: Type 4 2316 built by Jake Raby; I installed it in a '71 Ghia convertible in 2005 and have been enjoying it ever since, weather permitting.
Glenn Mr. 010
Posted: Wed Jun 19, 2019 1:16 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Details? _________________ Glenn
Member #1009
#BlueSquare |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1225 Location: IRELAND
Posted: Fri Jun 28, 2019 1:24 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Just got mine together. 2276 with speedshop efi and crank trigger
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Fri Jul 05, 2019 1:12 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Here's my entry from my 356 Outlaw.
227HP at 6,000 RPM. It's been alive since 1999, but has been fitted to 3 different cars.
_________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Sun Jul 07, 2019 1:48 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Jake Raby wrote: |
Here's my entry from my 356 Outlaw. |
Squared Away! Though you could have hidden the Sync-Link behind the shroud it's good to see it front and center. |
AZOffTheWall Samba Member
Joined: December 27, 2012 Posts: 209 Location: Arizona
QRP Samba Member
Joined: April 27, 2008 Posts: 1713 Location: NORTH HOLLYWOOD,CA
Posted: Tue Nov 05, 2019 12:21 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Current setup in my 68 ghia. 78x94 |
mhisel Samba Member
Joined: October 03, 2007 Posts: 249 Location: Los Angeles metro
Posted: Fri Aug 28, 2020 3:55 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
