JonL Samba Member
Joined: March 07, 2002 Posts: 308 Location: Highlands Ranch, Colorado
Posted: Thu Mar 24, 2016 4:08 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
came across a photo of my old autocraft turbo motor |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Fri Mar 25, 2016 8:06 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
The 2176cc engine from my old 64.
_________________ If you`re going to do something, do it right. |
coolrydes Samba Member
Posted: Fri Mar 25, 2016 11:51 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
CoolRydes Customs 47' Coper Split build
Not just bolt on parts here...... _________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
Posted: Fri Mar 25, 2016 11:55 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
CoolRydes Customs Drag Bus Vintage ARPM / Deano Dynosaur Engine
MENDEOLA SUSPENSION
Deh Shark Samba Member
Joined: December 09, 2006 Posts: 704 Location: U.S. Virgin Islands
Posted: Fri Mar 25, 2016 6:50 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
2387cc
_________________ AH TIYAD AH DAT DEH BAI!!!
Organize folks are just to lazy to look for stuff!!
55 3 fold Ragtop
Manx Dune buggy 2387cc |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Fri Jul 29, 2016 3:46 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Here's my 2110 powered Ghia engine compartment. Obviously I chose function over form - no wire or hose management whatever but its all mine - built it myself just like so many other VW's I've had. Its not the fasted thing on the road but it does just fine with the 4:37 final drive. Its a great gear ratio for my locale. Keeps the rpm's up and the motor cool and the AC cold. With 100 degrees oil temp is right at 205-210 after a 30 minute drive.
_________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Mon Jun 05, 2017 11:49 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
That's some engineering! Cudos 8) |
sovereignsamba Banned
Posted: Thu Jun 08, 2017 9:42 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Whats with the dizzy |
Ace Samba Member
Posted: Thu Jun 08, 2017 9:48 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Dual plugs per cylinder |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Thu Jun 08, 2017 5:23 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
That is pretty friggin badass! _________________ If you can't join them, beat them! |
vince1 Samba Member
Posted: Wed Apr 11, 2018 8:25 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Untitled by lyndon creamer, on Flickr |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76970 Location: Sneaking up behind you
Posted: Wed Apr 11, 2018 8:36 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
WOW, super clean.
Specs? _________________ Glenn
Member #1009
#BlueSquare |
EmpiGT Samba Member
Posted: Fri Apr 13, 2018 7:35 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
so would they have had to chop up a very early 25 hp to use the case sections to weld to a new aluminum case? I love the thought of making a new case look old to give you much more hp than an okrasa build |
earlesurfs Samba Member
Posted: Sun Apr 22, 2018 9:39 am Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
Work in progress-
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sun Apr 22, 2018 5:33 pm Post subject: Re: Bad A$$ Engine Fest - Nice engines IDA's Welcomed... |
My 2165, will look better once I color match all the sheetmetal to the car.
[img][/img] _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
