DUNTOVFAN Samba Member
Joined: November 03, 2023 Posts: 61 Location: Fremont
Posted: Tue Nov 28, 2023 2:57 am Post subject: Re: Garage Fest - post recent pics of your garage |
Devon-Dyno-Soar118 Samba Member
Joined: August 30, 2004 Posts: 849 Location: Devon UK
Posted: Tue Nov 28, 2023 1:26 pm Post subject: Re: Garage Fest - post recent pics of your garage |
Been a very long time since I posted anything on here, thought after nearly 15 years I ought to lol. Here’s my shed. It’s not very tidy, but neither am I
_________________ 71 West coast Kombi
54 Oval, 60k km from new
Daves 68 Bug Project
Rust Collector. |
mg50 Samba Member
Joined: August 30, 2022 Posts: 682 Location: Southeast
Posted: Thu Dec 21, 2023 6:34 am Post subject: Re: Garage Fest - post recent pics of your garage |
My new garage. 25x26 with 8ft. walls. Waiting on doors and meeting with electrician today to discuss electrical. Thinking 2 outlets on each wall, 4 led strip lights - spacing them favored toward the back of the building; flush mounted to steel members. Outdoor gooseneck lights over the side door and one centered over the pull up doors.
_________________ 1971 Super Beetle & 1971 Karmann Ghia
engine rebuild: https://www.thesamba.com/vw/forum/viewtopic.php?t=775424&highlight= |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2269 Location: HdG, MD & NJ
Posted: Thu Dec 21, 2023 8:13 am Post subject: Re: Garage Fest - post recent pics of your garage |
Sounds like a plan. Just remember, the more outlets, the better. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 350 Location: Noblesville, IN
Posted: Thu Dec 21, 2023 9:09 am Post subject: Re: Garage Fest - post recent pics of your garage |
I'd suggest wiring a couple dedicated 30A 110v outlet and at least one 22Ov outlets for compressor/welder/plasma cutter. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
2type2 Samba Member
Joined: June 02, 2002 Posts: 990 Location: SW Colorado
Posted: Thu Dec 21, 2023 9:44 am Post subject: Re: Garage Fest - post recent pics of your garage |
Outlets on ceiling. Hang 8 led lights around edges and along center, using individual pull string switches.... all the lights you need, where you need it without running everything. _________________ "A life of peace and happiness depends on your own gratefulness" |
mg50 Samba Member
Posted: Thu Dec 21, 2023 11:41 am Post subject: Re: Garage Fest - post recent pics of your garage |
2type2 wrote: |
Outlets on ceiling. Hang 8 led lights around edges and along center, using individual pull string switches.... all the lights you need, where you need it without running everything. |
That's a great idea. _________________ 1971 Super Beetle & 1971 Karmann Ghia
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20318 Location: Sandpoint, ID
Posted: Thu Dec 21, 2023 11:55 am Post subject: Re: Garage Fest - post recent pics of your garage |
mg50 wrote: |
2type2 wrote: |
That's a great idea. |
I wired mine in three rows with three switches. That way I can just light up one side where my main bench is, or light up the whole shop if needed.
Also, more outlets than seems necessary, and place them up high to clear any work benches. Set the bottom of the outlet at four feet from the ceiling, that way if you hang sheeting on the walls, you only have three cuts to make it around the outlet. Saves mud and tape time if you hang drywall, too. _________________ nothing |
slayer61 Samba Member
Posted: Thu Dec 21, 2023 12:03 pm Post subject: Re: Garage Fest - post recent pics of your garage |
Kafer_Mike wrote: |
I'd suggest wiring a couple dedicated 30A 110v outlet and at least one 22Ov outlets for compressor/welder/plasma cutter. |
I get the 220 stuff, but I'm curious. Why 30 amps of 110?
Dedicated, multiple 20 amp circuits makes sense, but I don't get the 30 amps? _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
OldSchoolVW's Samba Member
Posted: Thu Dec 21, 2023 2:29 pm Post subject: Re: Garage Fest - post recent pics of your garage |
https://www.youtube.com/watch?v=iX3kxAA2L4Q
_________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Thu Dec 21, 2023 2:38 pm Post subject: Re: Garage Fest - post recent pics of your garage |
slayer61 wrote: |
Dedicated, multiple 20 amp circuits makes sense, but I don't get the 30 amps? |
Flexibility to run 110v welders/plasma cutters and compressors. Many of the 140 amp welders and 50 amp plasma cutter manufacturers recommend 30 amp breakers to keep it from tripping too often. Same for some of the larger 110v compressors. They all list 20 amp as the "minimum". For <$50 difference in the breaker and wire (10 guage vs.12 guage) for a 25' run, I would install the dedicated 30 amp circuits. _________________ Kafer_Mike
indianpeaksjoe Samba Member
Posted: Sat Dec 23, 2023 9:57 am Post subject: Re: Garage Fest - post recent pics of your garage |
Spent the morning cleaning up the workbench area. So I should share it before it gets messy again!
-Joe _________________ Adventures in owning a 66 beetle |
mg50 Samba Member
Posted: Sat Dec 23, 2023 4:28 pm Post subject: Re: Garage Fest - post recent pics of your garage |
indianpeaksjoe wrote: |
-Joe |
Very cool! Looks like time for a new project to mess it all up! _________________ 1971 Super Beetle & 1971 Karmann Ghia
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1259 Location: Vancouver, BC
obus Samba Member
Joined: March 08, 2001 Posts: 11124 Location: just off Garden State Parkway Exit 81
WrennMetallWerks Samba Member
Joined: December 06, 2007 Posts: 2711 Location: Rescue ca
TastyTuner Samba Member
Joined: March 11, 2010 Posts: 116 Location: Tulsa, OK
Posted: Wed May 08, 2024 9:15 am Post subject: Re: Garage Fest - post recent pics of your garage |
_________________ TastyGarage |
BRANDEN HOY Samba Member
Posted: Wed May 15, 2024 12:31 pm Post subject: Re: Garage Fest - post recent pics of your garage |
I spy an old friend there... RHD American spec Ragtop with a Judson.
The story of that car is so good. One of my all time favorite VW's. Looks like she's in a good home. Thought she ended up in Tennessee for some reason. |
