Built_To_Spill Samba Member
Joined: June 17, 2005 Posts: 43 Location: San Diego, CA
Posted: Mon Jul 04, 2005 8:44 pm Post subject: DUAL WEBER 34 ICT CARBURETOR KIT |
DUAL WEBER 34 ICT CARBURETOR KIT FOR TYPE 3'S.
ARE DESIGNED TO FIT UNDER DECKLID.
INCLUDES THE FOLLOWING:
(2) WEBER 34 ICT CARBURETORS (2) DUAL PORT INTAKE MANIFOLDS (2) AIR CLEANERS (1) LINKAGE KIT (1) COMPLETE SET OF INTAKE GASKETS
the cost of this kit is $450 on jbugs.com
i have two questions
a) is this everything i need to convert?
b) is this a good set-up (quality and reliability) for a stock engine? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22729 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Jul 04, 2005 8:46 pm Post subject: |
If you are converting from fuel injection, I'm interested in your ENTIRE injection system. PM me please! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Mon Jul 04, 2005 10:56 pm Post subject: Re: DUAL WEBER 34 ICT CARBURETOR KIT |
Built_To_Spill wrote: |
Not nearly the quality and reliability of stock Fuel Injection _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Posted: Mon Jul 04, 2005 11:03 pm Post subject: |
well i'd be more than happy to keep my f.i. but my engine is running pretty richly, and as i understand it there could be 43,324,596 things wrong with it, is there a check list to refer to? also does anyone know of a good place to get a longblock from in the san diego area? |
karfer67 Samba Member
Posted: Tue Jul 05, 2005 12:19 am Post subject: |
if you decide to go with carbs these are the best way to go. i have them and love them. i have found out that there are two sets sold one is jetted for a totally stock engine meaning stock ignition, exhaust and so on. the other is jetted slightly more rich ment for an engine with a header etc.. i think i have the leaner of the two as i have been having some hot running issues but if it is the jetting i can't blame the carbs. they have stayed very well adjusted, and as long as you get a good linkage (hex bar style) you are good to go. just make sure that the links are the same and that the carbs open at the same time. although if you can figure out the fi stick with it. i wish mine still was. _________________ aircooled for life (1972 squareback cal look) |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Jul 05, 2005 8:07 pm Post subject: |
There is a FI trouble shooting guide up on my web site.
http://classicvw.org/gallery/Fuel-Injection-Manual
If you need any more, let me know.
BTW, there aren't 43,324,596 components in the FI system. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
chillz1 Samba Member
Joined: August 03, 2002 Posts: 869 Location: Where You Least Expect
Posted: Tue Jul 05, 2005 8:28 pm Post subject: |
PLEASE listen to the others and trouble shoot your current EFI. You will not be sorry. The ICT's have no chokes, so cranky initial running in cool country and they usually don't have a provision for vacuum advance. If you're still set on carbs, you will also need to remove the stock EFI fuel pump (pressure is WAY too high), and instal a mechanical fuel pump, or eletric facet style pump and regulator. _________________ 2%
http://www.animalsintheattic.com
Click to view image |
Posted: Tue Jul 05, 2005 8:38 pm Post subject: |
Most rich running FI systems, are either caused by a bad Pressure sensor, or a leaky hose to the pressure sensor. BUT, first check the charging system. voltage at the battery should be 13.5V-14.5V at approx. 2500 rpm. Low voltage will cause rich running. USE only Bosch voltage regulators.
Check resistance on the plug wires, No greater than 2500 ohms. Check the resistance of the rotor. 3000-4000 ohms.
Fuel pressure should be 28-30 psi. maybe 32 psi tops. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
neilbates Samba Member
Joined: May 05, 2004 Posts: 48 Location: San Jose, CA
Posted: Thu Jul 07, 2005 8:44 pm Post subject: |
Some Friendly advise from someone who did what you are thinking about doing.....don't....
I had a fi 68 sqaure I converted it to 34 webers and hate the things...If you can try and find the problems with the FI if you are sick of them completely then try and find a stock carb setup with chokes...they make a huge difference. _________________ 64 Ghia mod
68 Square |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22439 Location: Kimball, Mi
Posted: Thu Jul 07, 2005 9:13 pm Post subject: |
The biggest problem with the Weber 34s is most of the kits available today don't come with a balance tube. This tube makes a world of difference in how they are tuned and how they run / respond. About the only kit that has the balance tube comes from CB Performance. The Empi kits don't, and that might be part of the difference in price (along with proper jetting).
But if you can get the FI to work, you'll save some money, and keep it original (damn that make me sound like a purist ). But for what it's worth, the FI is the best set up you can have on these cars, as it gives more power, better fuel economy, and it's already in your car (it's also a very easy to work with system). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jul 08, 2005 1:04 pm Post subject: |
thanks so much for all the input |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Fri Jul 08, 2005 3:01 pm Post subject: |
Looks like Tram isn't getting his FI system. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
