Kevin S. Samba Member
Joined: May 23, 2005 Posts: 113 Location: Vancouver, Washington
Posted: Fri Jul 01, 2005 12:17 pm Post subject: Tilt steering colum?? |
Is it possible to put a tilt steering colum in a type 3?? I have a 1971 fasty. I thing it would be different..... does anyone know if there is obe out there, or a company who builds one. I know of Flaming River, but not on their website. Just pondering the application. _________________ Do you feel lucky???? |
fastback1971 Samba Drummer
Joined: January 02, 2005 Posts: 239 Location: Tri-Cities
Posted: Fri Jul 01, 2005 1:59 pm Post subject: |
http://www.airkewld.com/
These guys sell one. I believe it will go in a type 3 as well. Check em out. _________________ I refuse to tiptoe through life, only to arrive safely at death. |
TheDDB Samba Member
Joined: April 08, 2003 Posts: 752 Location: Type 3 Central - Portland OR -
Posted: Fri Jul 01, 2005 2:00 pm Post subject: |
Kevin-
This can be done...
But you will neet to use a gm column...
they will fit in your car.
But some rewireing and brackets will need to be made.
if you want to go further we can discuss... _________________ Martin Magnia
Home of the only bolt on type 3 air ride kit
http://www.theDDB.com
Its a type 3 thing, so you might not understand
Yes I Walk the Walk |
Posted: Fri Jul 01, 2005 3:13 pm Post subject: |
would the GM colum be large and bulky looking?? Has it been done?? Any pics??? _________________ Do you feel lucky???? |
brent67 Samba Member
Joined: December 31, 2003 Posts: 515 Location: Port Townsend,WA
Posted: Fri Jul 01, 2005 5:57 pm Post subject: |
TheDDB wrote: |
Kevin-
This can be done...
if you want to go further we can discuss... |
I would like to discuss....Sorry M, won't be making it this weekend....but will be down soon, I think the 9th (Saturday) looks good....will bring motor, drums, wheels, battery....let me know if I need to bring something else too.... _________________ DSD
Dark Side Disciples
(Inner Circle/4th degree) |
TheDDB Samba Member
Posted: Fri Jul 01, 2005 6:51 pm Post subject: |
brent67 wrote: |
TheDDB wrote: |
Kevin-
This can be done...
I would like to discuss....Sorry M, won't be making it this weekend....but will be down soon, I think the 9th (Saturday) looks good....will bring motor, drums, wheels, battery....let me know if I need to bring something else too.... |
Yes we can discuss this next time your down.
I hope all is well, see you soon.... _________________ Martin Magnia
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Fri Jul 01, 2005 8:27 pm Post subject: |
Kevin S. wrote: |
would the GM colum be large and bulky looking?? Has it been done?? Any pics??? |
Yes, it's been done. Both mine and my son's Roadsters have GM tilt columns in them, and I might do another type3 or 2 before I'm all done. You'll need to lengthen the shaft about 14 inches, and fabricate some brackets to hang it from the dash, and down lower near the firewall. You'll also have to do some wiring mods, as it's not a direct swap (it's close though). My son's car used a more "normal" round style column, while my Roadster used a "later squared" style column (out of a 90 Berretta). Both required about the same amount of work to install. If you go to the link in my signature, you'll see some pics of my install there (after it was done), and if you do a search in the t-3 gallery under my screen name, you'll find some pics of my son's car there. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jul 01, 2005 8:44 pm Post subject: |
Would useing a truck column be less hassle or is a car column a better choice??? I saw the pics Bob. Does it work nicely?? I am looking at putting a custon steering wheel in it. From Budnik or Billet Specialties. I want to have the room, but at the same time the tilt makes it easier to get in and out. This is a tuff decision to make. _________________ Do you feel lucky???? |
Posted: Fri Jul 01, 2005 8:57 pm Post subject: |
The biggest thing is to find a column out of a vehicle that has a floor shift in it. Truck or car doesn't make a difference, as GM uses basically the same length "upper" part, with varied lengths for the "lower" part. It works great though, and if you drop it down slightly from the stock VW position, you can get it more into your lap (if you're short like me) when in the lowest cruising setting. My son is 6'2", and kept hitting his knee on the stock column and steering wheel, but after the conversion, he doesn't have that problem any more. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jul 01, 2005 9:01 pm Post subject: |
The search is on!! Thanks very much Bob. I have the column out of the fasty fight now trying to fix stuff and gather parts. I have a tilt Gm column in my garage. I will mock it up and see how I like it. Thanks again for the help. More questions to come on the wireing part of it.....lol... All you guys are so informative!!! _________________ Do you feel lucky???? |
littlebuggie Samba Member
Joined: March 23, 2004 Posts: 698 Location: California
Posted: Fri Jul 01, 2005 9:30 pm Post subject: |
Solow yopu are the sh*t!!!! _________________ Do you feel lucky???? |
Posted: Sat Jul 02, 2005 8:27 am Post subject: |
Yeah, it's hard to believe that I wrote that up over 2 years ago when I was working on my Roadster. This year we re-did the dimmer swtch set up on my son's car to match mine (his was the original guinnea pig). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
TheDDB Samba Member
Posted: Sat Jul 02, 2005 9:42 am Post subject: |
Also dont forget about other columns that are telscopeing [sp?] and the ever famous swing-away colum...now your talking...
I think they were in late 60's early 70 fords?
that would be cool... _________________ Martin Magnia
