daveotter Samba Member
Posted: Mon Jun 13, 2005 5:30 pm Post subject: Type III with a sidedraft weber DCOE |
Anyone ever tried or heard of anyone trying a sidedraft Weber 45 DCOE on a T3? I always hated tinkering with my dual DCNF's, and thought that a single DCOE in the middle would be plenty for a small but healthy motor. Just wondering if anyone had ever tried it, or had some really good idea why it would be a bad idea.
Dave |
vdubjim Samba Member
Posted: Sun Jun 19, 2005 12:00 am Post subject: |
i was thinking of this the other day, taking a bug manifold, cutting down the height, then welding it back together, then installing it rotated. |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sun Jun 19, 2005 11:28 am Post subject: |
It'd be all kinds of fun to try with dual-port Bug manifold pieces -- the driver-side endcasting won't clear the tin over the oil cooler as-is.
Better bet for the manifold would be to use the runners from a Weber progressive setup, and you can probably find a used one cheap 'cuz *those* carbs are a horrid idea for using on a T3 .. and yet people keep buying 'em, go figure. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Jun 19, 2005 11:31 am Post subject: |
tristessa wrote: |
Anybody want one
Free for the shipping. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Jun 26, 2005 10:06 am Post subject: |
So type one manifolds are out. Don't know that Iv'e ever laid eyes on the progressive 2bbl manifold setup, unless it's that one with a square box in the middle that really looks like it doesn't flow smoothly for squat.
That thing aside, what of a pair of ICT dual port manifolds at each side, and then fab up your own center section? The ICT ends straight up, so you could (theoretically ) have the center section curve away from the oil cooler. Might the 45 DCOE be too restricted through the 34 manifold? Perhaps one is limited to a 40 DCOE? (or whatever size DCOE's com in)
food for thought . . . . |
Posted: Sun Jun 26, 2005 11:01 am Post subject: |
http://classicvw.org/Engine.jpg
There one is in all it's glory. Free for the shipping. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Erik G Samba Member
Joined: October 16, 2002 Posts: 13286 Location: Tejas!
Posted: Sun Jun 26, 2005 12:01 pm Post subject: |
if you decide to go for it and try, you may want to cinsider using that tubing that turbo guys use to plumb stuff for mock up/test runs. I think it might be PTFE, but anyways, defenetly heat resistant and stuff, might be easy to cut ICT manifolds, use these to adapt it to the top just to see if it works without spending too much time.......
_________________ Stop dead photo links! Post your photos to The Samba Gallery! |
