Rear Luggage area
Caqfatboy
Caqfatboy is offline
PostPosted: Wed Mar 09, 2005 9:43 am    Post subject: Rear Luggage area Reply with quote
I'm replacing the entire rear luggage area metal, and I have cut off the metal strip that holds the carpet or flooring. I didn't measure it before I cut it off the old shelf, so I now need the distance of the strip in relation to the bottom of the shelf or as a reference the area where the seat belts bolt in. So, could someone measure the distance between the two so I can weld it in the right place. Thanks!
Kim in Tulsa
Kim in Tulsa is offline
PostPosted: Wed Mar 09, 2005 10:41 am    Post subject: Reply with quote
This is my luggage area...is this the area you mean? I'd be happy to run out to the car and get some measurements...
Kim
1970 Yukon Yellow Beetle
Check out my online Beetle Diary!
http://kimsbug.blogspot.com/
DeMinimis
I Eat Glue
DeMinimis is offline
PostPosted: Wed Mar 09, 2005 2:06 pm    Post subject: Reply with quote
Harley riders, geeszch. I forgot what bug you have. If applicable, I'd be happy to measure my late vert for you later this evening if you like.
Yes Virginia, beer can make you smarter.
'78 SB CEII In Progress.
Caqfatboy
PostPosted: Wed Mar 09, 2005 7:30 pm    Post subject: Reply with quote
Kim in Tulsa - I think it was your tenth picture down, when you fold the seat down it is connected to the metal strip which is welded to the shelf area...
DeMinimis - Road King Classic - what can I say! Anyhow the car is a 71 Super Beetle...I think the location of the metal strip should be the same on all cars, I think....Thanks for your help!!
Kim in Tulsa
PostPosted: Thu Mar 10, 2005 6:44 am    Post subject: Reply with quote
Ok...I took these measurements with a flexible cloth tape measure. The tape measure laid smooth on the surface I was measuring.
I've got one more picture to take, from the top of the latching bar to the top of the back seat support. Will post it here in a bit.
Kim
Caqfatboy
PostPosted: Thu Mar 10, 2005 7:48 am    Post subject: Reply with quote
Great! Thanks for your help!!
Caqfatboy
PostPosted: Thu Mar 10, 2005 8:03 am    Post subject: Reply with quote
Perfect! That's what I needed...You must be using Photoshop!
Kim in Tulsa
PostPosted: Thu Mar 10, 2005 8:17 am    Post subject: Reply with quote
This is the only measurement I took that went through the "air". I stretched the tape measure from the top of the latch bar to the top of the back seat support (which didn't make it into the picture).
Yes, that is a former mouse nest on the left. Hubby is borrowing a shop vac this weekend and hopefully we'll get this car spiffed up a little.
Anything else you need?
Kim
Caqfatboy
PostPosted: Thu Mar 10, 2005 8:36 am    Post subject: Reply with quote
Nope! For now that will do jusy fine! Thanks for taking the trouble to get the dimensions! Again, thanks!!! Oh! had a couple mouse nests in mine also....
Kim in Tulsa
PostPosted: Thu Mar 10, 2005 8:43 am    Post subject: Reply with quote
You're quite welcome!
Kim
DeMinimis
I Eat Glue
PostPosted: Thu Mar 10, 2005 9:12 am    Post subject: Reply with quote
Looks like Kim got you covered. I didn't get home from job #2 and a heated board meeting until too late to even watch the Daily Show.
Caqfatboy
PostPosted: Thu Mar 10, 2005 9:23 am    Post subject: Reply with quote
Yep! She did...Thanks for your offer to help, though....
