Clementine79 Samba Member
Posted: Sun Feb 05, 2023 3:24 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Everything is running good again, finally had some decent weather to take the bus out again.
_________________ 1979 VW BUS
Riviera Penthouse Model |
Posted: Sat Feb 11, 2023 5:33 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
On ignition switch #3 last one lasted about 2 years 😒 ordered two more and each was different from the same website.
Posted: Mon Mar 13, 2023 9:10 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
50 degrees and still snow, but amost good weather for camping again,
Posted: Sat Mar 18, 2023 9:38 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Another successful trip in the books, good memories made!
Posted: Mon Mar 27, 2023 11:53 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Upgraded the shifter, the way this shifter functions automatically going back to the 1-2 gate when shifting makes driving much more enjoyable.
A great improvement over the stock setup! _________________ 1979 VW BUS
notchboy Samba Member
Joined: April 27, 2002 Posts: 22487 Location: Escondido CA
Posted: Mon Mar 27, 2023 12:35 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Clementine79 wrote: |
A great improvement over the stock setup! |
I bet - looks killer. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
blink Samba Member
Joined: September 07, 2011 Posts: 90 Location: Australia
Posted: Mon Mar 27, 2023 6:53 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
what brand shifter is that one? |
Posted: Mon Mar 27, 2023 7:24 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Its a CRC, coolrydescustoms _________________ 1979 VW BUS
richparker Samba Member
Joined: November 24, 2011 Posts: 7025 Location: Durango, CO
Posted: Tue Mar 28, 2023 7:48 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Yea for sure, I was kind of in a hurry to get the shifter in as I have been using the bus for driving back and forth to work everyday. I would eventually prefer a carpet mat from Sewfine someday in the future. I'm going to try to straighten up the access hole that was cut in the factory mat so it lays flat again. _________________ 1979 VW BUS
Posted: Tue Mar 28, 2023 10:40 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
richparker wrote: |
Maybe you could clean up that mat somehow to finish it off. |
Are you putting piss in your Wheaties again instead of milk? _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Mar 28, 2023 3:53 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
notchboy wrote: |
richparker wrote: |
Are you putting piss in your Wheaties again instead of milk? |
Na, this bus is fly. Just looks like the mat was hacked a bit, tightening that up, would really set it off.
That and a set of sled tins. 😂. JK! _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Thu Mar 30, 2023 9:11 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
richparker wrote: |
Hah yea I had to adjust the shifter more times than I could count, when we got it back from the shop it was fine but every now and then we couldnt hit 3-2 downshift or get it into 1st. We finally ended up cutting a hole so if it ever happened in rush hour traffic again I could loosten the 13mm up just enough to hit the gear and get out of the way without pulling off to the side of the road and pulling the whole floormat out to access the two bolts and shift plate.
With the new shifter it has no issues with any of the gears and doesnt require realligning the shift plate every few years anymore. _________________ 1979 VW BUS
Posted: Sun Apr 02, 2023 1:08 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Camping again
Posted: Fri Apr 21, 2023 12:32 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
I swapped back to an older head unit for now.
Posted: Sat May 27, 2023 4:49 pm Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Posted: Tue Jun 06, 2023 9:43 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Day in the shop, such a nice spot to work on the bus during the heat of the summer. The Doosan orange almost matches the bus paint.
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1297 Location: Vancouver, BC
Posted: Tue Jun 06, 2023 9:49 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
Nice sized shop! You could do a lot of work in there. It must be handy in the Winter too. Have you done your trip up to BC and Alberta yet, or sometime this summer? _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
Posted: Tue Jun 06, 2023 9:56 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
We are coming up August 10-13, staying at Tunnel Mountain. We will be using our travel trailer on this trip. _________________ 1979 VW BUS
Posted: Wed Jun 28, 2023 8:26 am Post subject: Re: Our new bus! 1979 VW Riviera Penthouse |
