Project 67
Page: 1, 2, 3, 4  Next
Stauffenberg
Stauffenberg is offline
PostPosted: Mon May 30, 2016 10:00 pm    Post subject: Project 67 Reply with quote
Well after 5 years of not having a beetle im finally back and this time i'm getting what I want, and that's a BAJA Twisted Evil
I'm starting with a pretty solid 67 that was involved in a front end collision, but thankfully it only damaged the front clip and not the frame head. There is some small rust areas but nothing as bad as my first beetle, that will all be taken care of. Right now i have stripped it down to find out what i really have and have found some things that were surprising but nothing that cant be fixed (mostly wiring). So far i have gathered a few parts to start the project once the rust is gone including:Thing beam, spindles, arms, and a wiring harness
I'm moving in a couple of months and will soon have a double car garage all to myself and that's when i will start with the rust repair, but for now i'm just gathering parts.
My big thing is that the 67 currently has the swing axle trans and I know I want to move away from that but can not decide which way to go, as of right now I know someone selling a swing axle with the reduction boxes and someone with a 002 trans. I know the reduct would be an easier swap but without the Johnson setup it has all the hop. With the bus swap i know you have to weld in pivot points an d the problem with that is I don't even know how to weld yet and dont trust myself with something that important suspension wise. So i'd like some input on that and what you would recommend.
Anyways here is some pictures so far
dustymojave
dustymojave is offline
PostPosted: Tue May 31, 2016 11:10 pm    Post subject: Re: Project 67 Reply with quote
Class 11 style!!!
That beam HAS to GO!!!
Unless you already have the new beam and the Thing pieces, I would suggest a BugZyla conversion beam and link pin arms and spindles.
For the rear, IRS vs reduction box swing axle with no-hop is not a huge difference in welding. Maybe you can find somebody on here who lives near you in Colorado to help.
Richard
SoCalBajas Member
Stauffenberg
PostPosted: Wed Jun 01, 2016 5:17 pm    Post subject: Re: Project 67 Reply with quote
Class 11 is out of the question unless i want to weld on a whole new front end, it was crunched up pretty good and whoever "fixed" it before wasn't afraid to add about a quarter inch of bondo in the front quarters. Plus the front clip is trash
My thing spindles and arms arrived today and I picked up the thing beam the other day it was already raised 2 inches and is very low miles
Stauffenberg
PostPosted: Mon Jul 25, 2016 10:39 pm    Post subject: Re: Project 67 Reply with quote
Ive been working on it lately but didnt have wifi until I moved and now i have a garage that I can use Cool
Everything I did was before the move because i didnt trust the beam as far as I could throw it, so I went crazy and almost built the whole front end in a day except I had a ball joint strip out and had to get a new one pressed in. But now it sits all on its own and with the cut and turned beam and thing spindles i gained 4.5" inches of clearance at the beam Twisted Evil
Anyways pictures
As far as I got after the ball joint stripped
Sitting on all fours
Front end all assembled
Stauffenberg
PostPosted: Tue Jul 26, 2016 9:52 pm    Post subject: Re: Project 67 Reply with quote
I forgot to upload this picture which cracks me up because its getting towed by one of its younger cousins Laughing
I still need to index the rear but wanted to wait until i could do it on pavement and not gravel
Stauffenberg
PostPosted: Thu Apr 27, 2017 9:35 pm    Post subject: Re: Project 67 Reply with quote
I've been working on the bug and slowly picking up parts here and there, but I don't make progress as fast as some of you around here
I was able to mount one of my seats out of a Subaru Forester, the covers were off to wash
I received my one piece front end from Mark V
I spent 4 hours removing a lower shock bolt that someone previously failed to remove
I also mounted my brake lights that are stupid bright and I plan on adding a third on the cowl
Picked up a cage for the rear off c list for 100 bucks and installed my "all my neighbors hate me exhaust"
Mounted my fuel cell and now I have some parts on the way including an aluminum dash and a front bumper
I just moved again and i hope to get it street legal by May 20th when we have our first VW show here
tobiism
tobiism is offline
PostPosted: Thu Apr 27, 2017 9:52 pm    Post subject: Re: Project 67 Reply with quote
Looking great so far!!!
"There has never been a genius without a hint of madness."
-Albert Einstein
Stauffenberg
PostPosted: Thu Apr 27, 2017 9:55 pm    Post subject: Re: Project 67 Reply with quote
Also I've been discovering how "body work" was done before
Nothing says proffesional like 1/2 of bondo
Fenix
Fenix is offline
PostPosted: Thu Apr 27, 2017 10:38 pm    Post subject: Re: Project 67 Reply with quote
I have a 30 ford with an easy 20lbs of leading...original 1950's "bodywork".
Stauffenberg
PostPosted: Mon Jan 29, 2018 9:16 pm    Post subject: Re: Project 67 Reply with quote
Not much of update but I finally got the tires for the front end mounted and they look much better! I'm still figuring out how I want to mount the one piece font end but i'm just scared to cut into that fiberglass Laughing
Any recommendations on shocks for the front? It's a cut and turned thing beam with thing spindles and arms.
YDBD
YDBD is offline
PostPosted: Mon Jan 29, 2018 9:31 pm    Post subject: Re: Project 67 Reply with quote
looking good.
Shocks-depends on your off roading style...something soft and supple for the light weight front end for driving in the bumps, but if you do some jumping or hill climbing you don't want too squishy. Had quite a collection of shocks for my '64, but settled on KYB oil, gas adjust were too stiff on the front.
Cut a fuel filler hole so you don't have to tilt or remove the front clip. Have a vacuum set up when you cut so the dust doesn't go everywhere, it's itches bad, I use duct tape on the itchy parts to get the glass fibers out. Most fine tooth wood working blades and bits cut fiberglass nice. Measure 9 times before cutting.
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
Dark Earth
Dark Earth is offline
PostPosted: Mon Jan 29, 2018 9:50 pm    Post subject: Re: Project 67 Reply with quote
I bought Bilstein B46-0493VW front shocks for my thing front end. I haven't installed them yet as I'm still in the "build" stage. I did install hook and rod stops to protect the shocks and ball joints though.
Here's a link showing the shock specs ...
http://eshocks.com/bil_ORvh.asp?Series_Index=Q7&am...ar=Q#thumb
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
Stauffenberg
PostPosted: Mon Jan 29, 2018 10:43 pm    Post subject: Re: Project 67 Reply with quote
I was planning on that after I saw other people complaining about that. I cut the holes for the brake lights and already learned that hard lesson about the fibers haha
I was looking at similar shocks to these but didnt know if they would work but I like how those say cut and turned beam!
Dark Earth
PostPosted: Mon Jan 29, 2018 11:07 pm    Post subject: Re: Project 67 Reply with quote
I took some measurements of my shocks. Not sure if it will help you or not.
veeweeman
veeweeman is offline
PostPosted: Tue Jan 30, 2018 5:45 am    Post subject: Re: Project 67 Reply with quote
If you want to learn how to weld most community colleges offer classes, most even offer night classes so you can still keep your day job. ..looks like you are making really good progress on that baja. ..it's funny that all you need these days is a shell of a car, an Internet connection, a credit card and you can pretty much build an entire car from scratch Laughing Laughing
If it was my choice I'd choose the reduction GB trans.
Mal evolent
Mal evolent is offline
PostPosted: Tue Jan 30, 2018 9:03 am    Post subject: Re: Project 67 Reply with quote
that reduction box system will make the car a roll-o-matic. if you add reduction boxes build a roll cage
it's funny that all you need these days is a shell of a car, an Internet connection, a credit card with a very high limit and you can pretty much build an entire car from scratch
30 years back you could buy a pallet with 10 30,000 mile 1600DPs on it for $3000. you could go to any junkyard and choose among the 1600DPs, $300 apiece. now it's dry out there, Sahara dry.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
Stauffenberg
PostPosted: Tue Jan 30, 2018 12:55 pm    Post subject: Re: Project 67 Reply with quote
Ill have to measure when I get home but that does help thanks!
I have sourced quite a few parts from the internet which makes life easier for sure. Eventually I want to swap an IRS bus trans in because like Mal evolent said its a roll-o-matic haha and its near impossible to find a Johnson no hop kit and fabbing one it way beyond my skill level.
I remember when I had my first beetle and I always wondered why it took everyone so long to build their projects and now I'm realizing why that is haha.
Stauffenberg
PostPosted: Tue Jan 30, 2018 8:13 pm    Post subject: Re: Project 67 Reply with quote
Measured from the top of the beam to the lower arm and its 18.5" so those should be perfect!
Stauffenberg
PostPosted: Thu Feb 01, 2018 10:07 pm    Post subject: Re: Project 67 Reply with quote
Ordered the above shocks and some new wheels and tires for the back more on those once they get here.
I wanted to share a project I made a couple years ago to go into a Humvee and have a way to charge our phones in the field haha plus who doesnt like having some tunes! It was very simple to construct and now im going to mount it in the beetle!
Here are the photos from building it, cost me about 75 bucks but it can probably be done even cheaper. Doubles as a mostly waterproof container and you cant see it but inside I also mounted a cheap 12 volt and dual usb outlets for charging, and I also replaced the cheap wire twist connectors with solder and heat shrink. Also has a kill switch to not draw power but that was from hooking it up straight to the battery in the Humvees. Its loud enough to hear clearly inside the trucks on the highway so it should be plenty loud in a beetle Laughing
Buggeee
Buggeee is offline
PostPosted: Fri Feb 02, 2018 9:48 am    Post subject: Re: Project 67 Reply with quote
That's Cool Cool
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
Page 1 of 4
