What is stock flywheel made of?
mnakandala
mnakandala is offline
PostPosted: Mon Aug 11, 2014 2:00 am    Post subject: What is stock flywheel made of? Reply with quote
Hi guys a little dilemma, the subject tells it all, what is the stock VW bug 200mm 12V flywheel made of? is it cast iron or other material
Question Question
1964 bug
1983 mitsubishi Delica
Joe Bence
Joe Bence is offline
PostPosted: Mon Aug 11, 2014 2:07 am    Post subject: Reply with quote
The stock German flywheels are Chromium vanadium steel very high quality by OEM standards (most OEM stuff is cast), yes there are cheapo cast iron wheels out off brazil etc both OEM and aftermarket.
mnakandala
PostPosted: Mon Aug 11, 2014 2:15 am    Post subject: Reply with quote
Thank you Joe Bence and is there a way to identify these from one another?
1964 bug
Joe Bence
PostPosted: Mon Aug 11, 2014 2:18 am    Post subject: Reply with quote
I can tell just from looking at it. Also if some one is selling a flywheel or lightened flywheel too cheap it is most likely cast.
Cast wheels have a dull machine finish and pressed on ring gear, German wheels have a shiny machine finish.
Quokka42
Quokka42 is offline
PostPosted: Mon Aug 11, 2014 3:00 am    Post subject: Reply with quote
The machine finish is from the machining after it is cast. Cast iron provides a very effective frictional surface in such an application. There would be no logical reason to forge such a part (except the "forgery" of marketing.)
There has only ever been one man who was perfect, and they nailed Him to a cross.
Boolean
Boolean is offline
PostPosted: Mon Aug 11, 2014 4:25 am    Post subject: Reply with quote
What is your point? The VW stock flywheel is Chrome Vanadium steel. It is a good choice of material. The cast aftermarket ones are very weak as discovered by some who had them fall off leaving the center on the crank.
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
Quokka42
Quokka42 is offline
PostPosted: Mon Aug 11, 2014 4:45 am    Post subject: Reply with quote
Not sure of the metallurgy, I'd have though Chrome Vanadium too expensive and unnecessary for this application, but it is definitely cast steel - you can often see the mould impression. Very hard metals such as Cr-V tend too provide poorer friction and less heat tolerance, as does forged metal.
jpaull
jpaull is offline
PostPosted: Mon Aug 11, 2014 12:09 pm    Post subject: Flywheel Reply with quote
If your application is high performance, I would not settle for anything but a NEW forged chromoly flywheel. Vw's have enough issues with the dowl pin area already. Dont settle for anything but a REAL Chromoly flywheel such as this:
http://www.thesamba.com/vw/classifieds/detail.php?id=1382480
I spun the Center out of a "German" flywheel after a hard launch on the street. Never again will I mess with a stock VW flywheel of any sort in high performance application.
Jeff
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
Boolean
Boolean is offline
PostPosted: Mon Aug 11, 2014 12:36 pm    Post subject: Re: Flywheel Reply with quote
Jeff
I almost called BS on that remark. I honestly dont think its possible to to do. Maybe the "German" flywheel was made by a guy called Chang...
You cannot get a better flywheel than stock.
Build thread here:
jfats808
jfats808 is offline
PostPosted: Mon Aug 11, 2014 1:05 pm    Post subject: Reply with quote
This is true. I saw the light a few years ago myself and almost always try to run a german flywheel when .possible on builds now. A loose or improperly torqued gland nut can accomplish the same results.
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
andy198712
andy198712 is offline
PostPosted: Mon Aug 11, 2014 1:15 pm    Post subject: Reply with quote
Where are you finding German flywheels? Buying a used one and 8 doweling? Refacing ect?
Alstrup wrote:
I like 5,5inchers in the rear at least.
Northof49
Northof49 is offline
PostPosted: Mon Aug 11, 2014 1:32 pm    Post subject: Reply with quote
I used to shoot at an old VW flywheel at a gravel pit when I was a teenager. 6.5x55 Swedish Mauser with fmj ammunition wouldn't even leave a dent in an oem german flywheel. Just a shiny spot and it rang like a bell.. That was not cast iron.
1958 Karmann Ghia owner
Joe Bence
PostPosted: Mon Aug 11, 2014 1:43 pm    Post subject: Reply with quote
DPR Jose will take a good German core and re-manufacture it to your liking.
andy198712
PostPosted: Mon Aug 11, 2014 2:18 pm    Post subject: Reply with quote
I'll have a look at his site, being in the uk mean postage is a killer on something like that
flyinglow94
flyinglow94 is offline
PostPosted: Mon Aug 11, 2014 3:35 pm    Post subject: Reply with quote
From first hand experience, I have lighten stock flywheels and they are anything but cast iron ,cast iron is very flake when machined like drilling a cast rotor and Cr-v does not chip very well it wants to come off the tool in strings. Also the stones to resurface most import fly wheels are speced for Cr-v. I highly recommend buying only OG VW flywheels especially for daily drivers.
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Aug 11, 2014 4:16 pm    Post subject: Re: Flywheel Reply with quote
Boolean wrote:
I almost called BS on that remark. I honestly don't think its possible to to do. Maybe the "German" flywheel was made by a guy called Chang... You cannot get a better flywheel than stock.
German was in quotations, probably meaning he got burned by a cast flywheel masquerading as a true OG steel one. I've seen pics of an exploded cast flywheel, and it wasn't even on a strung out motor. Get a real German one, or a a confirmed steel one to avoid issues. The Ford and Chevy guys can get away with it, we can't.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
stealth67vw
stealth67vw is offline
PostPosted: Mon Aug 11, 2014 6:18 pm    Post subject: Reply with quote
Later OEM VWs had cast cranks and flywheels.
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile
Quokka42
Quokka42 is offline
PostPosted: Tue Aug 12, 2014 4:31 am    Post subject: Reply with quote
I think the Germans were a little too clever to forge a flywheel ever. It doesn't mean they were cast iron, a lot of metal can be cast (and what we traditionally know as "cast iron" would be unsuitable for this application due to it's high carbon content.) Ironically, (pun intended,) several "stainless steel" alloys work well for flywheels and brake disks and drums, but they are almost invariably cast.
satterley_sr
satterley_sr is offline
PostPosted: Mon Apr 03, 2017 1:52 pm    Post subject: Re: What is stock flywheel made of? Reply with quote
Old thread, but I am curious about the use of cast flywheels. Seems like they have been around for ACVW's for a number of years now. Has there been any improvement in metallurgy to where they are now ok to use?
p.s. remember old quokka42?
DDC racing
raygreenwood
raygreenwood is offline
PostPosted: Mon Apr 03, 2017 3:41 pm    Post subject: Re: What is stock flywheel made of? Reply with quote
Lot of crap in this thread. The stock flywheels are indeed steel...cast and hardened steel...not cast iron...and not forged. They are tougher than hell.
For instance among type 4 engines (I realize we are speaking of type 1 here)..the only models that came with a forged flywheel were the early 411 with 200mm (Europe only) and the Porsche 914 2.0 liter.
Cast steel is totally different than cast iron...alot stronger tensile wise but with some of the same issues.
All aircooled VW types 1 through 4 cranks that came out of Germany were forged. Whether they started making some cast cranks in Brazil in the last years.....mainly 1980s....I do not know.
Aftermarket cast flywheels...I have no idea what they are made of whether its iron or steel. Ray
