fredybear Samba Member
Posted: Sun Jun 18, 2023 12:32 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Blasted Rims
Lets Paint Some Rims
The Futures Soooo Bright, I Gotta Wear Shades _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
hutmo Samba Member
Joined: February 05, 2002 Posts: 41 Location: Pittsburgh, PA
Posted: Sun Jun 18, 2023 5:25 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
That is quite a project. You're a better man than me. That thing would be off to the classifieds! LOL
It reminds me of the question...How do you eat an elephant? One bite at a time. Before you know it, it will be running and moving and grooving again.
Good luck
HUTMO _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002 |
Posted: Mon Jun 19, 2023 9:07 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
hutmo wrote: |
Good luck
HUTMO |
Thanks, the worst stuff is always more fun. Did you see the beetle?
Lets take it to the original color
The crappy stripper works good for this. Good thing some people use cheap paint. This should take awhile.
The original color adds a few dollars to the value
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Mon Jul 17, 2023 12:41 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Took the engine apart, easier to carry around a short block
Who new....
The whole bearing is missing. Where did it go? Did they forget it?
Lets clean the filth _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Mon Jul 17, 2023 12:44 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
The crank looks good Just took the rod off...Hmmm
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Jul 19, 2023 6:10 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Cleaning the filth
E85 awesome for cleaning
2 yrs I had that gas rotting in that orange bucket. Still works
1/2 at a time. The more useless you are, the more patience you have
2yr old rotting gas for the serious filth. _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Jul 19, 2023 6:38 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Shredded Wheat The rod bearing just shredded into a pile. Coolness
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4965 Location: Southern AB
Posted: Thu Jul 20, 2023 3:16 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
hopefully you are pulling all the plugs on that case to clean out the oil passages
there is a good article on superbeetles.com in the tech section for that: Engine Rebuild - Case Prep - Step 1 _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Thu Jul 27, 2023 12:38 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
W1K1 wrote: |
hopefully you are pulling all the plugs on that case to clean out the oil passages |
I have my collection of stuff
The filth is almost done an clean. Next up _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Thu Jul 27, 2023 7:14 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Cleaning the filth. $10 worth of E85 and 2yr old bad gas. I don't recommend bad gas as it stinks like crap, but
YUMMY, Leftovers
Nice and clean
Next up, Drill and Tap the Hole, My Favorite _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Tue Aug 01, 2023 8:32 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Vice Grips, Screw & Hammer Time, Cant Touch This
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Mon Aug 14, 2023 12:24 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
BLASTED CLEAN
Gettin the full flow workin for the bus mount
Need to make me a Mr. Parker Mount for that full flow system
Im tired of the 95 to 100 degrees in the shop. I cant take it anymore
100 bucks. temp ac.
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Aug 30, 2023 6:19 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
This thing is a Tank. I cant even push it around like a beetle. Maybe a Turret on top with a 105mm These things are freakin heavy. How does a stock motor even move these thing around with people in them Geeeeze
So Now
How bout a Turbo Tank
Lets make a mount, shall we
Testing Testing
The setup
The Temp Test
Notice the 2 holes? Woops, it was upside down
This case should go in the beetle and get me an Alu Ni Mum Case for the Tank THE TANK NEEDS BEEF
Cropola, $2Gs to beef up my transaxle. YUK Than install it, than finish the mounting _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Sun Nov 26, 2023 7:35 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Back to the BUS
You will do what I say when I say
Back to the BUS
You will die when I say you must die
Back to the BUS
You coward, you servant, you blind man
Lets Go, Im done being useless,,,,wait hmmmm _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Mon Nov 27, 2023 3:52 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
I am taking it apart. I said dont do it, stop, slap&roll. O-BOY
I think it was all orange and not half and half. How do I tell??? Some original on the gutter and such. What about the roof?? Rotting Rubber
I find some BUS ROT Under that plate is some rustola. Pop the plate and clean it up?
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Tue Nov 28, 2023 2:25 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
A relief cut and some pressing gets the dent out. Back of the door still looks beautiful.
That dent is deep
Busses are just awesome Can be used for many things
Some more fixin and some welding, the welding should shrink it up beautifully.
Back to the rear next. _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4435 Location: Stuck in Ohio
Posted: Fri Dec 01, 2023 7:39 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Buggeee wrote: |
I just got all caught up on your bus thread Freddy...and I love how you are smashing this bus back into shape. Something makes me think you did not get that turbo from Brazil. Back to the front! |
Thanks Homie More Smashin here. Dent fixin is fun
HP & TQ.....We goin there
FREDY 2024 Why U Ask
Before
I gonna B you next
PRESS-A-DENT
After
The Cut for easy wed up
Next Up. Paint Removal. How U Ask? Wait and find out _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Davy_B. Samba Member
Posted: Sat Dec 02, 2023 12:54 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
just do what's necessary! on the right track...
Sierra yellow L11H
Hopefully the paint comes out well! |
Posted: Tue Dec 26, 2023 11:15 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Davy_B. wrote: |
Sierra yellow L11H
Thanks
Im workin it
Ready
Second exhaust fan
The Best Ever
Toxic Flesh Burning Juicyness It took 3 weeks of screwups to get it. Is it worth it HellYEAH Hours to strip the Tank, I mean the whole bus. U have no idea how easy
Check out the bubbles
After
Still cant figure the paint. All white under the rubber, notice the orange. The roof was all orange at some point. The all white under the rubber might suggest it was painted all orange at one point, is that about right???
Who want to watch me live on YouTube do the bus.
Im gonna go live OBOY _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
