1964...Diamond in the Rough
Page: Previous  1, 2, 3 ... 11, 12, 13 ... 25, 26, 27  Next
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Nov 28, 2015 12:36 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
flyboy161 wrote:
Well, I don't know why I didn't think of this sooner, but here goes. This car had a 1200 in it up until a few months ago. When I bought the car, it had an 009 distributor that did not work very well. And wanting it to be "period correct" I researched the correct distributor and bought one. A Bosch ZV/PAU 4R2. I also found that Autozone sells an identical cast iron distributor so I got that one as a spare. Truth be told the AutoZone one worked better than the Bosch, so I ran that one until the motor went kaput.
Once that happened I swapped the 1200 out for a 1600. Most all the bolt on stuff moved over to the 1600 (generator, gen pedestal, carb and distributor). Outward appearance I was after was 1200 with 1600 pep. Unfortunately, the 28pict is way too lean for the 1600, and this in turn made the car, well, kind of gutless. I popped out the cast iron dizzy and the 28PICT. In went the H30/31 and the 009.
So, I've been running the 009 on the 1600 and tweaking things until I got 27.5mpg out of her. And never one to leave well enough alone, I thought I'd try out an SVDA on the 1600. See above...bad out of the box. Also, pulled the trigger too fast. An SVDA and an H30/31 are not a good match. Today after answering Bill above, a light popped on in my head. I've got these two vacuum only distributors in my garage not being used.
They are both bench set up with hold down clamps already installed. Dwell and timing set. And in the tech section here is a tune up parts chart that also gives specs on nearly if not all VW distributors. The 009 I've been running is set at 30 degrees advance and falls at 7.5 degrees at idle. So, 22.5 degrees. The vacuum only ZV/PAU 4R2 is set for 18+/-3 degrees advance.
I stuck it in the car and she runs great. Static time is 10 degrees and at idle it's about the same, maybe a tad under 10. As I raise engine speed timing advances slowly up to 30 degrees on the dot. Car runs cool as well, no pinking and no hesitation. It is also not gutless.
That's good news! Lord knows I'm certainly guilt of buying a part and then remembering I had one in a box or drawer that I stumble on days/weeks later.. Doh!
I've been going thru all my VW parts/spares recently for this very reason. I've also been selling many items I know I'll never use as I'm tired of them taking up room!
Glad you got her running well!
The Samba member since 2004.
flyboy161
flyboy161 is offline
PostPosted: Sat Nov 28, 2015 12:55 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
It was good advice, Bill. I know the writer of the article "comparing carburetors" said that the 205K dizzy would work with the H30/31. It has a 19+/- 3 degree advance. The highest advance coming from the 205L with 25+/- 3 degrees. He recommended to set the timing "correctly" which I assume means at whatever he had on his chart...
Well the cast iron dizzy is set at 10 degrees and it doesn't appear to be running too hot. I will keep an eye on it. Do you think 10 degrees is too much for a 1600?
1968 Westfalia
https://www.thesamba.com/vw/forum/viewtopic.php?t=792825&highlight=
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
pj.olsson
pj.olsson is offline
PostPosted: Sat Nov 28, 2015 2:19 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Hi,
nice ride you have! I love the look of your car! The things you do on your bug is just amazing!
I love the Bumpers you are installed! I want to do the same on my 1967 VW blue Bug!
Best regards,
Pj.
flyboy161
PostPosted: Sat Nov 28, 2015 2:40 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Thanks, PJ! I'm really happy with these bumpers. They've been on the car since January 27th and still look as shiny as when I first got them. No rust at all, so I'll give the Vietnamese stainless steel bumpers a thumbs up.
1968 Westfalia
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Nov 28, 2015 5:12 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
http://www.oldvolkshome.com/ovhignbo.htm
I'm not familiar with that number on the distributor? Several of the early 60's distributors are set at 10 BTDC though. Is there another number that starts with 113? Here's a chart on the VW distributors that provides the specific specs and what to time them at. If you check that distributor on the side of it's body, it should have numbers stamped on it. Find the number and then cross check it to this list.
flyboy161
PostPosted: Sat Nov 28, 2015 6:21 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Distributor: VW 113-905-205A, Bosch ZV/PAU 4R2, 4R5 (0231 139 002) > 113-905-205B, 0231 139 006 > 311-905-205, ZV/PAU 4R4, 4R6 (0231 139 005) > 315-905-205B, 0231 137 031
Can Use: VW 111-905-205L or M, Bosch 0231 147 002 or 111-905-205N, 0231 137 005
Condensor: 02 006
Rotor: 04 010
Cap: 03 037
Coil: 00 001 (Blue Coil: 00 016)
Vacuum Can: 07 015 (NLA)
Ignition Wires: 09 001
Spark Plug: W8AC
Timing Set At:: 10deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Vacuum Advance Only: 10deg @ 1.3 In. Hg, 15-21deg @ 2.8 In. Hg
1968 Westfalia
flyboy161
PostPosted: Sat Nov 28, 2015 6:41 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
I'm starting to feel more comfortable with this. The 1600 SVA is timed statically at zero degrees. At idle with the vacuum line capped it is timed with a strobe light to zero degrees using. Once the vacuum line is connected it will advance a certain amount. At 1.3" Mercury it times at 17-19 degrees before top dead center, whereas mine is set to 10 degrees statically and at 1.3"Mercury it is 10 degrees before top dead center.
Bottom line I didn't notice any drive ability issues with it set as though it were on a 1200cc motor. I know the ZV/PAU 4R2 is "all in" at 5" of vacuum. Watching the advance as it revved up, it gradually increased to 30 degrees BTDC and 10 degrees BTDC.
AND THEN PERRY WAS HAPPY BECAUSE A NOVICE LOOKING UNDER THE DECK LID MIGHT BELIEVE HE WAS LOOKING AT A 1200cc MOTOR, AHAHAHAHAHA! Oh yeah, and it drove nice and smooth, too!
1968 Westfalia
flyboy161
PostPosted: Sat Nov 28, 2015 6:49 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Oh and the ZV/PAU 4R2 is the number on the tag of the distributor. It looks like this:
1968 Westfalia
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Nov 28, 2015 7:31 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Well, it sounds like you nailed the correct timing then! Very Happy I've always used that site to double verify how I timed a particular distributer. The 205K and M timed at 7.5BTDC. I have an original "K" distributor that I rebuilt on my 67. I love it. So smooth.
Glad you got it all figured out.
flyboy161
PostPosted: Thu Dec 31, 2015 3:32 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
One month later:
The cast iron dizzy did the trick! Top speed 75mph and running like a champ! Getting 28 mpg again as long as I keep the speed under 60mph. She's a comfortable daily driver again
1968 Westfalia
EXJAY
EXJAY is offline
PostPosted: Thu May 05, 2016 7:44 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Just went through both your 70 and 64 build threads..man great work! Applause I really liked the 70 mostly for the story behind it and that it was for your dad to have back as he once did.
EXJAY
'74 Superbeetle (Family owned since new)
'73 181 Thing (sold)
flyboy161
PostPosted: Thu May 05, 2016 11:36 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Thanks so much! I've just been tooling around in the '64 for the last few months. I keep in touch with the guy that bought the '70 from me. He really loves that car.
Between work and my other addiction (Jeep) I just haven't had the time to do anything with the Diamond. And a part of me wants to leave it just the way it is. Getting into the car is just like stepping into a time capsule. Everything still looks and smells just as it did years ago. Driving home at 2:00am, trying to tune in a distant am station, listening to the motor, which still purrs like a sewing machine, is exhilarating. She keeps up with the fastest of traffic, which surprises and P.O.'s the other drivers. I guess there's just something about an old bug running 75mph that just rubs people the wrong way.
Other than that, it's fun to see people stop in their tracks to watch her go by, or stop at a traffic light and the person next to you rolling down the window and asking, "What year?" Oh yeah, and the people that slow down so they can snap a quick picture on their phone as I pass them. Too much fun.
I remember 30 years ago, when VW's were plentiful, and seems like everyone had at least one in their yard, it was just a curiosity to folks as to why you would drive one. Now it's something more, now it's nostalgia, it's memory. My daughter says, "You're eccentric". I ask her why and she says, "Because you could drive anything, but you choose to drive that old car!"
She'll never understand, she never lived the life I lived.
1968 Westfalia
flyboy161
PostPosted: Thu May 12, 2016 9:59 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
A little show car glaze #7 before work and voila! What a shine!
1968 Westfalia
1968buglogan
1968buglogan is offline
PostPosted: Thu May 12, 2016 4:48 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
What color of blue is that?
flyboy161
PostPosted: Thu May 12, 2016 8:24 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
It is a respray of something close to Sea Blue. I pushed the exposure a bit, it really is more of a greenish blue
1968 Westfalia
flyboy161
PostPosted: Thu May 12, 2016 8:32 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
This is an early pic after I bought her. There is a small area under the deck lid on the rear apron, where the re-spray chipped off. It is on the left side and in the pic appears to be a lighter blue. That is Sea Blue. The cameras just don't do the color any justice
1968 Westfalia
flyboy161
PostPosted: Thu May 12, 2016 8:37 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Un re-touched photo
1968 Westfalia
flyboy161
PostPosted: Thu May 26, 2016 7:50 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Well, time for some maintenance. In the two years I've owned this bug I've always had an issue down shifting to second. The dreaded, "oops that's reverse" syndrome. So, I pulled the shifter and took a look in the tunnel. Shifter bushing? What shifter bushing? It must be that shredded looking bit of whatever in the bottom of the tunnel.
Parts ordered: shifter bushing and coupling just in case. Parts arrived yesterday, so I think I'll tackle the job. Ugh!
1968 Westfalia
flyboy161
PostPosted: Thu May 26, 2016 9:04 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Or not. Apparently I have a late model shift coupling, so now I have an early model coupling for the '58. Ugh! Back to the ordering!
1968 Westfalia
grandpa pete
grandpa pete is offline
PostPosted: Thu May 26, 2016 2:47 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
I just ordered the bronze bushing that replaces the plastic one ; I'm curious if it is worth the effort .
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Page 12 of 27
