Highpockets Samba Member
Posted: Thu Mar 21, 2024 11:45 am Post subject: Brake Caliper Bracket Question |
This bracket is to thick. it will not let the bearing cap tighten down properly. it is a beeline trailing arm and a appletree bracket. both of them say they never heard of this. someone did say they had this problem and milled the bracket down. I do not know the thickness of a backing plate in order to do that. somebody else said I need a different year cap. I would rather not have to mill it and if there is not supposed to be a problem, why do I have one ? I am new to this game. any help would be appreciated. thanks
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2768 Location: West Coast (Michigan's)
Posted: Thu Mar 21, 2024 1:42 pm Post subject: Re: BRAKE CALIPER BRACKET QUESTION |
Why not get longer studs?
Either that or weld it on the arm, away from the spindle. It appears to be right where you could tack it on the back side and then cut away the rest of the bracket and finish welding it to the side of the arm.
I know, I know, but this is supposed to be bolt-on. lol whatever. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
BFB Samba Member
Posted: Thu Mar 21, 2024 3:24 pm Post subject: Re: BRAKE CALIPER BRACKET QUESTION |
Yeh, weld it. Bad thing about those bolt on type caliper brackets is they space out your bearing cap so your bearing isn’t actually captured in there like it was / is supposed to be. Ive had a few buggys that this caused some play in the rear wheels to where i could move an 31” tire about 1/4 - 3/8” in & out at the top and i machined the caps down in order to make it all right again.
If i were you id bolt it all up and make sure thats a good position for the caliper bracket, then since your caliper bracket is so close to your arm weld it where it sits then cut the bolt on section off and and put the bearing cap back together as it should be. Then consider yourself lucky that you got to use the cap bracket as a placement guide for where to weld the caliper bracket because its no quite that easy to mock up everything for normal weld on brackets _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
Posted: Thu Mar 21, 2024 5:38 pm Post subject: Re: Brake Caliper Bracket Question |
Well more than likely he'll find that spot won't work. It depends on the way the caliper attaches to the bracket, but it would probably be off by the thickness of the bracket. Because once you take the bracket out the caliper is that much closer.
I put calipers on the back of mine and it took a lot of re-assemblies before i got it right. Unfortunately, my setup was completely custom and i didn't pick a good caliper. You learn a lot about brakes AND fabricating with a project like this. I would never pay $1k for the bolt on kits because i like the process of doing your own thing. Everybody's different.
Isn't there a bearing cap that is thinner? For some reason that just popped into my head. Like i remember that being factor when i was doing mine. Maybe I'm trippin. _________________ Brian H.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20432 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Mar 21, 2024 6:39 pm Post subject: Re: Brake Caliper Bracket Question |
THere is actually three different bearing cap thicknesses, I believe it depends on year of cap....
_________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
BFB Samba Member
Posted: Fri Mar 22, 2024 5:27 am Post subject: Re: Brake Caliper Bracket Question |
Where the bearing cap is has nothing to do with where the rotor will sit, by that i mean if OP mocks everything up a then removes the unwanted / unneeded bracket from behind the bearing cap that wont change where the rotor seats on the stub axle. The rotor bottoms out on the spacer & bearings irregardless of cap or even housing.
Also, and i could be wrong, but those caps may be different thickness but the bearing recess all look to be the same depth. The caps are designed to capture the outer bearing so unless there are thinner & thicker bearings they should all be the same in that regard. _________________ Forced induction can overcome a lot of obsticles that gets in it's way
Posted: Fri Mar 22, 2024 7:12 am Post subject: Re: Brake Caliper Bracket Question |
BFB wrote: |
Also, and i could be wrong, but those caps may be different thickness but the bearing recess all look to be the same depth. The caps are designed to capture the outer bearing so unless there are thinner & thicker bearings they should all be the same in that regard. |
Wrong.... The thickness of caliper bracket vs thickness of backing plate determines whether the cap will clamp the outer race of bearing or not.... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Fri Mar 22, 2024 7:32 am Post subject: Re: Brake Caliper Bracket Question |
Needless to say, whenever anyone is doing something like this, it is necessary to mock it up as many times as you can to make sure everything clears and fits together. If it's possible you can get a thinner cap and make it work when you can't have it milled then maybe that's something to look into. _________________ Brian H.
Posted: Fri Mar 22, 2024 3:24 pm Post subject: Re: Brake Caliper Bracket Question |
Don't know how to delete double post[/list]
Posted: Fri Mar 22, 2024 3:25 pm Post subject: Re: Brake Caliper Bracket Question |
Seems maybe I didn't explain so well for some. Sorry. Everything fits fine. Bolts are correct length etc. Problem is that when it is all tightened down, the caliper bracket keeps the cap from tightening up properly on the bearing. So it let's the stub shaft and bearing move slightly. And since I did not build the buggy and am not familiar with vw, I have no idea what it is that I have to start with. If I take the bracket off, yes it does tighten down and stop like it should. Without a backing plate or bracket. But if I get the bracket to thin, it won't have any clamping force to keep it from moving. It will just move whatever the slack in the bolt holes allow when braking forward and reverse. What should I look for to know what year cap I have and know which year to go to...thanks |
BFB Samba Member
Posted: Fri Mar 22, 2024 3:54 pm Post subject: Re: Brake Caliper Bracket Question |
Dale M. wrote: |
BFB wrote: |
Wrong.... The thickness of caliper bracket vs thickness of backing plate determines whether the cap will clamp the outer race of bearing or not.... |
No shit, thats what i said previously regarding the bearing. As far as using the bracket to mock shit up to weld the caliper part to the arm, then cutting off the part of the bracket that would bolt to the bearing housing makes absolutely no difference to where the rotor or caliper will sit. Read shit more throughly before you just tell people they are wrong like some sort of jackass. _________________ Forced induction can overcome a lot of obsticles that gets in it's way
Posted: Sat Mar 23, 2024 7:04 am Post subject: Re: Brake Caliper Bracket Question |
I apologize, the deletion of the backing plate slipped my mind. Does the bearing fit through a hole in that caliper bracket? Maybe what you need is some shim washers to put behind the bearing? _________________ Brian H.
Posted: Sat Mar 23, 2024 7:18 am Post subject: Re: Brake Caliper Bracket Question |
ORANGECRUSHer wrote: |
I apologize, the deletion of the backing plate slipped my mind. Does the bearing fit through a hole in that caliper bracket? Maybe what you need is some shim washers to put behind the bearing? |
Do they actually make such a thing? _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 201 Location: Clare MI
Posted: Sat Mar 23, 2024 1:07 pm Post subject: Re: Brake Caliper Bracket Question |
"IF" the caliper bracket is much thicker and you extend the bearing outward with shims etc, the outer bearing sleeve will not be inset quite a bit and the spacer shaft outer spacer may be too far into the seal and let the inside of the drum/disc rub.
I got lucky with my caliper brackets. They were just a bit thinner than the original backing plate, or for that matter maybe the same thickness. After I used one paper gasket on top of the caliper bracket, the outer bearing retainer clamped down to lock the caliper bracket very tightly, perfect one might say!
The step in the bearing carrier where the backing plate slides over, is what your caliper bracket needs to be in thickness. As some have said, surface grind the inner surface of the outer bearing retainer or surface grind the caliper bracket to that thickness.
Good luck, Dan |
BFB Samba Member
Posted: Sat Mar 23, 2024 2:27 pm Post subject: Re: Brake Caliper Bracket Question |
You can’t space the bearing out without adding another spacer between the center bearing race and the sleeve otherwise you’re going to separate the bearing. You could put spacers between the cap and bearing though. Dale, for someone who knows so much as to be so eager to just tell someone else they are WRONG you should’ve known this already and stated that it wouldnt work.
I’ve attached a couple diagrams…
And Dan you didnt just get lucky, you just had a better kit. There is supposed to be a plate between the cap and the housing, it was the drum brake backing plate. So your bracket just happened to be closer to the factory backing plate thickness. Which they all should do but they dont.
Ive also seen multiple buggys where they had weld on caliper brackets and just bolted the bearing caps down without anything behind them which resulted in the cap bottoming out on the bearing and then the bolts folding the cap corners over, not sure how someone misses that.
I’m not sure why people make this so complicated, it’s not rocket science and it’s not a hard fix. If you get lucky like Dan, great. If you’re unlucky like OP then just shave some off the cap. Hell, ive hand sanded some down, you dont need a milling machine or any special equipment. The over thick bracket isn’t going to be that much over, 1/16” maybe? So it doesnt take a lot of effort or time to take some material of the caps especially on a belt sander or something similar.
Posted: Sat Mar 23, 2024 4:26 pm Post subject: Re: Brake Caliper Bracket Question |
Thanks for the replies. Looks like I will be grinding or welding. I would just really like to know why it doesn't work as it should.. |
Posted: Sun Mar 24, 2024 8:16 am Post subject: Re: Brake Caliper Bracket Question |
Boy, if i had spent all that money on a brake kit and I still had to monkey around with it to make it fit, i would be pretty upset. Not to say that isn't par for the course with vws. _________________ Brian H.
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1079 Location: St. Louis
Posted: Mon Mar 25, 2024 6:28 am Post subject: Re: Brake Caliper Bracket Question |
Highpockets wrote: |
The core reason it doesn't work as it should is because instead of companies Neal/CNC, Jamar, GearOne, Summers Bros or AMS designing and peddling these kits and parts to us, we mainly have EMPI and Latest Rage.
The former list of companies are comprised of enthusiasts who were in this game at a level none of us ever will likely be, testing their stuff from Barstow to Baja, and the last two companies are corporate blobs extracting money from us using shiny inferior parts priced attractively. Often these are poor copies of some of the best ideas pioneered by the original companies.
In summary, things used to be awesome and now they are trash. Good luck! _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
