Vndlfsn Samba Member
Posted: Tue Mar 19, 2024 10:02 am Post subject: Get a snug fit on pop top |
It seems as if the pop top towards the rear rests ever so slightly above the roof, maybe about half an inch or so. Is the primary means of adjusting using the locknuts and the L -shaped clips that snap into the latches towards the front? |
bikes! Samba Member
Joined: April 27, 2014 Posts: 98 Location: Central CA Coast
Posted: Tue Mar 19, 2024 4:56 pm Post subject: Re: Get a snug fit on pop top |
Assuming your van is a Westfalia weekender (which is what I'm familiar with), and the top has previously closed correctly, the first thing to check is if the rear hinges are binding. A few drops of light oil on each of the pivot points helped the top on my van close much more smoothly.
If you have a full camper built by Winnebago, others will have to chime in there. |
Posted: Tue Mar 19, 2024 5:22 pm Post subject: Re: Get a snug fit on pop top |
Interesting, so the pop top mechanisms for the weekender and the EVC are different?
I have a 1997 EVC by Winnebago. |
bjanaszek Samba Member
Joined: December 29, 2011 Posts: 33 Location: United States
Posted: Wed Mar 20, 2024 7:19 am Post subject: Re: Get a snug fit on pop top |
Vndlfsn wrote: |
Yes, they are totally different roof systems. By most accounts (including my own, having owned a 2003 Weekender and (currently) a 1995 EVC), the Winnebago roof isn't as good as the Westy roof.
Unfortunately, I don't have an answer to your query about tightening up the roof fit. _________________ 1995 EVC - 5 cylinder manual |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2815 Location: North Carolina
Posted: Wed Mar 20, 2024 10:27 am Post subject: Re: Get a snug fit on pop top |
While it may not be as good as a Westfalia roof think about it this way- mine at least has lasted 30 years. That's AMAZING actually.
Anyway, it still what I call a scissor hinge in back. Check it for binding or being bent just like described above. It could also be that somethings is off with the struts in the front and that's effecting the closure in the rear. Those are the only points stopping the roof from laying flush, unless the body of the van or roof are somehow warped/bent, so I guess check that too.
Sorry, not very specific, mostly saying- there's not too many factors to look at, really. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
