mturner7 Samba Member
Joined: April 04, 2022 Posts: 20 Location: Northern CA
Posted: Fri Aug 12, 2022 11:33 am Post subject: Does anyone know what this is>? |
Hi, Take a look at the photos of my 1974, 2.0L Porsche type4 engine bay, mystery sensor.
It was installed in the car when I purchased it. I think it is a remote oil pressure sensor, but without tearing into the engine, I can't tell.
They used several colors of wires (from one side of the unit), goes from red, to green, to blue then goes into the harness.
The white wire goes into a different harness.
The hose goes into a hole next to the distributor by cylinder #4. I think it goes over to the case to the oil pressure hole.
Any Ideas what this is?
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76980 Location: Sneaking up behind you
Posted: Fri Aug 12, 2022 11:45 am Post subject: Re: Does anyone know what this is>? |
Oil pressure sender. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Aug 12, 2022 1:08 pm Post subject: Re: Does anyone know what this is>? |
OK, I found it.
- It's a Dual Oil pressure sensor and Oil Pressure dummy light sensor in one.
1) 80psi MAX VDO gauge sensor
2) Dummy light to the gauge in the instrument panel.
- Also, it's too big to fit in to the designated hole, so it was mounted remote using a flex tube of some sort. I Found several posting on the subject.
- No one wants to cut a huge hole in the tin above the case!
The VDO Dual Pole Electric Oil Pressure Sender can be used to provide an oil pressure signal for a gauge as well as the idiot light.
VDO Pressure Senders have a 10 x 1.0 thread and can be installed directly into a VW/Porsche 914 engine case or used with a Multiple Adapter (provides for location of pressure and temperature senders).
For use with all 12-volt pressure gauges.
https://www.cbperformance.com/product-p/2350.htm
Thx
I found one with the hole cut in to the tin
vdubwizard Samba Member
Joined: May 14, 2008 Posts: 52 Location: Palomar Mountain, Calif
Posted: Thu Dec 15, 2022 11:27 pm Post subject: Re: Does anyone know what this is>? |
And Very Professionally Done!! G _________________ Please use <vdubwizard> for all messages, Big foot does not work correctly? Long rod Engines slow the piston down at TDC and BDC to let more flow and less angle to the pistons which helps the engine to last longer, less wear, and move the power band up the scale a bit. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21524 Location: Oklahoma City
Posted: Fri Dec 16, 2022 1:23 pm Post subject: Re: Does anyone know what this is>? |
Just keep an eye on it. The dual senders have two different pressure ranges. They also can be glitchy sometimes so check the reading on the cockpit gauge with the reading of a standard dial type gauge.
Also, more importantly....if this is a hose that has been made up by a hose shop for the use of motor oil...perfect. Too many people simply use a brake hose for this modification. Brake hoses are lined with EPDM rubber.
EPDM WILL NOT work with any VOC, mineral oil, mineral spirits, motor oil, fuels of any kind etc.
Propylene glycols, glycol ethers, silicone oil...good. Most other types of oils are very destructive to EPDM.
Yes...a brake hose can last quite a while as an oil hose....and then mysteriously break.
If it is a brake hose.....I would take the hose down to a hose shop...have the fittings cut off....and have a piece of fuel hose swaged onto them. Ray |
