EverettB Administrator
Joined: April 11, 2000 Posts: 69908 Location: Phoenix Metro
Navydave73 Samba Member
Joined: March 09, 2017 Posts: 418 Location: Alta Loma/Los Angeles
Posted: Tue Mar 30, 2021 7:47 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Thanks Everett, i tried zooming in but I couldn’t see it. I love the pie crust, i can find firestone pie crusts but they are too big. On Coker i think its 700-15 or more 670-15 |
Rhodrich Samba Member
Joined: December 27, 2001 Posts: 130 Location: London, UK
Posted: Wed Mar 31, 2021 4:24 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Unlikely they're available now:
monkey knuts wrote: |
These tyres are made by Barum and were made in former Czechoslovakia; so are pre 1993
I remember reading an article in a magazine once about how a huge stash of early VW’s was discovered in the basement of the factory including many split beetles!
These cost me £38 / $61 a piece – you’re looking at about £130 / $200 each now for crossplys!
They measure out at exactly 27” and are a tube type tyre as per OE spec.
There is a NOS Goodyear in there as well which is marginally smaller and a tubeless tyre.
Obviously the gaps are ‘unladen’ here. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7055 Location: Lawrenceville, Ga
Posted: Wed Mar 31, 2021 12:21 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
EverettB wrote: |
It looks like the tire says it's a Barum, size 6.40-15C 6 ply
Zoomed in
Barum appears to be a company in the Czech republic
https://www.barum-tyres.com/
When I did a Google searched Discount Tire came up as a seller but they didn't have that size listed, I wonder if they could order them? |
I used to work for the Barum Dealer for Europe in Germany back in the day. We used to sell the 6.40 15s for a while. My brother and i used to sell them out of the back of our Doka in the 80s and early ninetees.
that is me replacing the flywheel seal on said doka, at the bullikartei meeting, note the tires in the back.
i do not know if Mefo in Roethlein Germany is still a Barum dealer or not. That was 30 years ago.... _________________ regards
Uli
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Tue Apr 20, 2021 10:20 am Post subject: |
iubhounds wrote: |
The only mystery among the four different mechs I talked to online, one in person ... is how the RGBs work with an 1835cc engine. One says no problem. My shop and two in San Diego say they don't work well together and for me to get a smaller engine if I plan on using RGBs.
I've been running RGBs on my '63 DC with a 2110 for over 20k miles, lots of it at freeway speeds. No problems whatsoever. _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
bergfan Samba Member
Joined: March 07, 2007 Posts: 151 Location: NewZealand
Posted: Tue Apr 20, 2021 11:56 am Post subject: |
MrWhoopee wrote: |
iubhounds wrote: |
I've been running RGBs on my '63 DC with a 2110 for over 20k miles, lots of it at freeway speeds. No problems whatsoever. |
What RPM are you maintaining at freeway speed |
Posted: Mon Apr 26, 2021 7:23 am Post subject: |
bergfan wrote: |
MrWhoopee wrote: |
iubhounds wrote: |
I honestly couldn't tell you, I don't have a tach and it's been decades since I did the calculations. My trans is a '64 rebuilt with Super Beetle ring & pinion (and possibly taller 3rd & 4th). I did drive it for a while before the trans upgrade with a 1915cc motor. It was a bit like driving a dragster, hard to shift fast enough. Higher gearing is really the key to drivability with a big motor. _________________ Craig ('51 WASP)
Murt Samba Member
Joined: October 01, 2017 Posts: 314 Location: Kent, England
Posted: Mon Oct 09, 2023 5:47 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Hi Gents
Please don't slaughter me, but I have a question or two ?
I am a bone stock height 67 Kombi. It's been off the road for a few months, and has now been reconfigured as a camper, with R&R bed Fridge pod etc.
I am currently running Porsche Fuchs re-pops that are 5.5J x ET20. Fitted with 195/70/15 tyres all round.
So Tyres are 195/70/15 current – Circumference 2054.6mm Diameter 654mm = 25.748”
I would like to try and get closer to the 27", and would probably go for
215/70/15 tyre – Circumference 2142.6mm Diameter 682 = 26.850”
After doing some math, I believe I'm correct in saying that if I have a stock Gearbox 4.375 x 0.82 x 1.26 x 1000 = 4520.25 then at 3500 revs.
I would be around 3500 x 2142.6 x 0.06 = 449946 / 4520.25 = 99.54 km/h = 61.85 mph ?
The main question is
A. Am I correct ?
B. Due to financial constraints if I were to only replace the rear tyres what effect would having the current 195/70/15's left on the front for a while ?
The tyres I have on at the moment are almost brand new, probably only done 250 miles on them, and can't really shell out more $$$ after all of the recent work, so was thinking replace rears first and the fronts at a later date ?
Are there any other pitfalls to this that I'm missing ?
_________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
