pemz0r Samba Member
Joined: August 26, 2010 Posts: 126 Location: Huntington Beach
Posted: Sat Mar 27, 2021 9:36 am Post subject: Looking to source a Locking diff carrier |
Does anyone know where I can source or purchase a 094 Locking Diff Carrier?
Weddle is sold out and will not be getting anymore
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17254 Location: Retired South Florida
Posted: Sat Mar 27, 2021 9:53 am Post subject: Re: Looking to source a Locking diff carrier |
This may not help, but I installed a Peloquin TBD that is also a locker in my front differential. It utilizes the syncro servo mechanism. It would be an improvement over a stock open locker. _________________ ☮️ |
pemz0r Samba Member
Posted: Sat Mar 27, 2021 10:29 am Post subject: Re: Looking to source a Locking diff carrier |
Hey Mark, thanks but I am looking to build up a front diff, and having a TBD would be pointless for my front because I have a decoupler, and I will only be locking out the front when in sand.
If I went that route, I would have to drop my rear trans and take out the rear diff carrier and move that one to the front, and then put the TBD in the rear. It's more work and money than I really wanna spend and do..
I appreciate the advice though!! |
Posted: Sat Mar 27, 2021 12:04 pm Post subject: Re: Looking to source a Locking diff carrier |
Here was my logic for the tbd Quaife locker in the front. When the front is locked. The only usable direction is straight. Turning requires slip angles or you snap a cv. Not all trails are ice, sand, and mud. So when coupled, you can drive and have a usable front wheel drive. If the trail deteriorates, you then lock the front.
So, the Quaife gives you both options. My guess is in most conditions you wouldn’t even need to lock the front. But it is there if you need it. And it’s available or was.
I am using my VC and really don’t notice the Quaife in normal driving conditions. _________________ ☮️ |
pemz0r Samba Member
Posted: Sun Mar 28, 2021 9:17 am Post subject: Re: Looking to source a Locking diff carrier |
Mark,
I didn't know Quaife made locking diffs.. I am guessing that will be a special order?
I looked into them to build me an LSD for my 901 trans, because I have been searching for years for a ZF 904 LSD. I haven't pulled the trigger yet because I am also looking at TB units |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9991 Location: Orbiting San Diego
vandroid Banned
Posted: Sun Mar 28, 2021 9:31 am Post subject: Re: Looking to source a Locking diff carrier |
We were talked out of Quaifes for our Syncro rebuilds. We went with Peloquin's and are happy with the outcome. Enough that one of our 2wd 4 speeds is getting the same and the locker. We bought all the locker parts years ago and have been sitting on them. |
Posted: Sun Mar 28, 2021 11:05 am Post subject: Re: Looking to source a Locking diff carrier |
My mistake. I have a Peloquin in my front differential. I ran a Quaife in my road race car. Similar design. Sorry about that. _________________ ☮️ |
pemz0r Samba Member
Posted: Sun Mar 28, 2021 11:32 am Post subject: Re: Looking to source a Locking diff carrier |
That makes more sense. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4876 Location: Bemidji, MN
Posted: Sun Mar 28, 2021 11:44 am Post subject: Re: Looking to source a Locking diff carrier |
i would love just keeping my plain open diff in my 2WD and having a locker. know enough to not break things! even just having separate L-R parking brakes would satisfy me. _________________ -dan
www.thefixitworkshop.com |
pemz0r Samba Member
Posted: Sun May 30, 2021 2:09 pm Post subject: Re: Looking to source a Locking diff carrier |
So after 3 months of searching and talking with people all over the world.. I was finally able to get a locking diff carrier...
Currently, collecting the parts needed for the retro fit but I have some questions.
1. Does anyone know the thread pitch for the locker switch, I will need to purchase a tap.
2. From schematics I have seen it looks like the front lockers only have 2 spider gears, my current locker has 4, can I still use four for the front? See photo below.
3. I want to add the the blinking engage light for the front, but I do not know where I can get the circuit board for that. I also want to add the spring twist knob engage the front locker. From what I can see there's an added tab on the pull switch that needs to be a lined before you can pull the knob, is that correct? Please see photo below.
4. Does anyone have a photo of the vacuum lines connected to the plungers for a triple knob? Trying to figure out where the "Y" connector should go.
Other parts coming in.
Vacuum Servo
Locker Servo Bracket
Locker Knob
Locker Valve
Locker Valve Nut
Locker Dash Bracket
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6834 Location: Fort Lauderdale, Fl.
Posted: Mon May 31, 2021 3:23 am Post subject: Re: Looking to source a Locking diff carrier |
pemz0r wrote: |
The tab is correct, it does need to be lined up to pull the knob out. _________________ This free advice is worth exactly what you paid for it.
Posted: Mon May 31, 2021 3:27 am Post subject: Re: Looking to source a Locking diff carrier |
Take a look at this page on my thread. It has the electrical line schematic & vacuum line routing.
https://www.thesamba.com/vw/forum/viewtopic.php?t=661562&start=20 _________________ This free advice is worth exactly what you paid for it.
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
gears Samba Member
Joined: October 28, 2002 Posts: 4396 Location: Tamarack, Bend, Kailua
Posted: Mon May 31, 2021 7:29 am Post subject: Re: Looking to source a Locking diff carrier |
We've had 904/901 LSDs and TBDs available for almost 20 years ..
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Mon May 31, 2021 8:59 am Post subject: Re: Looking to source a Locking diff carrier |
gears wrote: |
What would be the average service life of one of these before it would need to be rebuilt? What lube are you recommending? Now that the syncro has moved on I’m considering adding an improved differential for our 2wd. Thanks. _________________ ☮️ |
pemz0r Samba Member
Posted: Mon May 31, 2021 9:55 am Post subject: Re: Looking to source a Locking diff carrier |
Steve M. - Thank you! Now I just need to the PCB and the Vacuum sensor, or just have it as a pull out with no twist and no blinking light..
mackaymanx - Super helpful, thank you! This will make it so much easier to machine the case
gears - Yeah I know of GT, I actually emailed Matt back in November 2020. I am looking for an original 904 LSD but I have considered going with an aftermarket LSD/TB, GT, Quaife, etc, that's if I my search wants to end. |
gears Samba Member
Posted: Mon May 31, 2021 9:56 am Post subject: Re: Looking to source a Locking diff carrier |
The latest disc/plate combination reportedly lasts two full years in a pro race car. Two years vs every other race (which was prior longevity). 2 years in a pro car translates to WELL over 100,000 street miles .. probably more like the lifetime of the transaxle.
I'm hoping Syncro LSDs will be available in 2021. These of course can be used in a 2WD Vanagon, but without the fully-locking feature.
https://www.thesamba.com/vw/gallery/pix/2037887.jpg _________________ aka Pablo, Geary
'87 Syncro GL 2.5
