Tvättbjörn Samba Member
Posted: Fri Jun 24, 2005 9:50 pm Post subject: squareback pop out rattle´s |
Hi,
I just intall the rear pop out in a squareback and now the windows are more or less loose when closed. What is missing? I bought the car taken apart, so I´m not sure if there is a plastik guide in the hinge area missing or not. Any info will help.
thanks |
EverettB Administrator
Joined: April 11, 2000 Posts: 69894 Location: Phoenix Metro
Posted: Fri Jun 24, 2005 10:00 pm Post subject: Re: squareback pop out rattle´s |
Tvättbjörn wrote: |
Hi,
thanks |
There is normally a plastic or rubber buffer on the hinge to stop rattling. _________________ How to Post Photos
Posted: Sat Jun 25, 2005 5:37 pm Post subject: |
Does anybody have a picture of this part??? |
Posted: Sat Jun 25, 2005 10:03 pm Post subject: |
Thank you!
I did not see those when I used the "search" , but these are the once I need. Does anybody make new once or... |
Posted: Sun Jun 26, 2005 6:01 pm Post subject: |
Thanks for the info. I guess I have to do the some till I find some OE ones. |
volksmike Samba Member
Joined: May 17, 2002 Posts: 64 Location: Macedonia SC
Posted: Mon Jun 27, 2005 6:48 am Post subject: |
what year car do you have, as not all the squares were set up for popouts. The later car that I tried to put them in didn't have the little tab in the holes that help hold the window tight. All the cars have the holes, but not all have the tabs... |
Zarana-X Samba Dreadnok
Joined: September 03, 2004 Posts: 372 Location: How could hell be any worse?
Posted: Mon Jun 27, 2005 6:53 am Post subject: |
I have a 71 and I didn't know about the tab, or the buffer. Which is why I'm selling a set with all new rubber. _________________ "In order to create, you have to destroy." |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Mon Jun 27, 2005 10:07 am Post subject: |
I use black electrical tape to simulate the,,,, whatever it is. Has worked fine for a couple of years, but then, my windows don't get open/shut often. _________________ Everything known to man has been written.
Readers are Leaders! |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Jun 27, 2005 6:29 pm Post subject: |
Air-Cooled Head wrote: |
I use black electrical tape to simulate the,,,, whatever it is. Has worked fine for a couple of years, but then, my windows don't get open/shut often. |
Try heat shrink tubing instead of tape. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
