nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Fri Jul 20, 2018 11:01 am Post subject: Neil's 52 Zwitter |
picked up this crusty crusty zwitter about 5 years ago now maybe? flat towed it home to Detroit from Iowa, no issues. Its a standard, or was. came with an assortment of cable brake and hydraulic brake bits. no interior, total basket case. nice 54ish gas tank, seems to have OG doors and decklid, but crusty. Has all glass. The body is heavily surface rusted all over, and both aprons have been tapped. hesitated to start on this project because it looks like such shit, but the more you stare at it the more manageable it looks. Typical midwest rust, but no botched prior repairs, and almost enough material still there to measure out where the new stuff needs to go.
So, against better judgement, I have officially started this project. Ya, I should probably finish the panel or the bubbletop car or fiat first because they arguably need less work, but the time just seems right. I've picked up some repop heart tail lights and semaphores. I already rebuilt a tunnel case trans w/BD reduction axles (going Kommando!) Have to get back into the trans for an LSD install, but have that on the shelf too. And as of a couple weeks ago, have most of the repair metal to do the lower 8" of metal repairs.
As dragged home (to the old house)
And some new bits (at the new house)
This will be a long term project because work has me travelling about 2 weeks of every month, but I've almost finished running wiring and plumbing to the new garage, so work should start soon. |
Joined: August 31, 2013 Posts: 12916 Location: North Carolina
Posted: Fri Jul 20, 2018 12:28 pm Post subject: Re: neil's 52 zwitter |
Dude, put the blinders on & finish up or off load one of the other projects. You have lots of skill & cool projects, it'd be a shame to let them sit because your ADD got the better of you, ask me how I know. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jul 20, 2018 12:52 pm Post subject: Re: neil's 52 zwitter |
Trust me I know. Blinders are on in a sense. The initial investment is made, and I've dedicated all my free time since the 4th to getting the new garage ready to handle the welding. Should be finishing that up on Sunday. And it looks like no work trips for the next couple weeks so I'm hoping that having the parts and project at the new house will translate into progress.
Haven't been idle. Got the daily driver truck engine rebuilt and installed. Might not seem like it but I really have been focusing on getting the important stuff done first. |
oldovaldriver Samba Member
Joined: March 28, 2003 Posts: 258 Location: Mid-Atlantic
Posted: Fri Jul 20, 2018 9:38 pm Post subject: Re: neil's 52 zwitter |
Was the dashboard modified for a later ashtray? |
splitjunkie Samba Member
Posted: Sat Jul 21, 2018 7:10 pm Post subject: Re: neil's 52 zwitter |
oldovaldriver wrote: |
I was wondering the same thing. _________________ Chris
Posted: Sun Jul 22, 2018 4:57 am Post subject: Re: neil's 52 zwitter |
No clue on ashtray question. I wouldn't be surprised since gas tank is from a later car. Some of the parts that came with are correct and some aren't. Not familiar enough with early cars to know one way or the other and don't really care that much either. This thing is too rough to be picky about stuff like that. |
D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Sun Jul 22, 2018 10:12 am Post subject: Re: neil's 52 zwitter |
I'm thinking that since it has holes for trim, it's not a standard. |
Posted: Sun Jul 22, 2018 1:52 pm Post subject: Re: neil's 52 zwitter |
Checked and ashtray hole is indeed hacked. Trim holes I believe were also added. Can see where inner quarter panel was distorted when drill came through from outside. Alignment seems off for it to be factory. Plus there's the cable brake bits and obvious hacked napoleon hat for hydraulic brakes. |
Jorge R Samba Member
Joined: August 15, 2004 Posts: 146 Location: Portugal-Europe
Posted: Mon Jul 23, 2018 5:50 am Post subject: Re: neil's 52 zwitter |
I guess the ashtray hole is correct.
In fact there should be no ashtray at all on the standard zwitter but only a blanck plate to hide the ashtray hole. |
Posted: Mon Jul 23, 2018 6:12 am Post subject: Re: neil's 52 zwitter |
ashtray hole is hacked. most of the hacks don't look like farmer hacks. probably done at a dealership early in the cars life. only hack that more resembles a home job was the access hole in the tunnel for the clutch cable.
Got shop lights and outlets set up in the garage. Going to get my welder from the other garage tonight after work. Have a bit of reorganizing to do and a few more outlets to run before I get started.
plan of attack starts with lifting up on doors/pulling body together with ratchet straps to get doors back in alignment. will probably tack weld them closed then and start welding in some braces before starting on lower rust repair. |
chrissev2 Samba Member
Posted: Mon Jul 23, 2018 9:50 am Post subject: Re: neil's 52 zwitter |
Get ready to start spending mass $$$$ to buy all the rare zwitter only parts that car is missing. _________________ 1986 westfalia auto 1.9TD
2023 VW Atlas 3.6 VR6 Highline
2019 Golf Wagon 4 motion
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
Posted: Mon Jul 23, 2018 9:56 am Post subject: Re: neil's 52 zwitter |
yea, I'm not doing that. I don't care that much about everything being year correct. I'll do the metal work as correct as possible in case I ever sell the car and someone else wants to pick up where I've left off, but my plan is to build something I can actually have fun driving on a reasonable budget. Not going to waste my time and money just so that I'm afraid to drive the car. |
DDub Samba Member
Joined: January 06, 2005 Posts: 309 Location: central pa.
Posted: Mon Jul 23, 2018 2:16 pm Post subject: Re: neil's 52 zwitter |
Good for you, enjoy it your way. Maybe you can collect parts along the way. |
Posted: Tue Jul 24, 2018 4:31 am Post subject: Re: neil's 52 zwitter |
nshaddox wrote: |
Good plan. That's what I would do with that particular car. _________________ Chris
sled Samba Member
Posted: Tue Jul 24, 2018 7:13 am Post subject: Re: neil's 52 zwitter |
splitjunkie wrote: |
nshaddox wrote: |
Good plan. That's what I would do with that particular car. |
yep, whatever suspension you want, a big nasty engine, three fold sunroof clip, etc.... FUN _________________ drive your split. |
Posted: Tue Jul 24, 2018 9:43 am Post subject: Re: neil's 52 zwitter |
exactly. I've already got the lifted trans built up. gonna probably do a cut and turn beam up front. also have a 1776 motor ready to go for it. should be able to slap it together as a driver soon after metal work is completed. that will of course take some time though.
got a little more wiring done in the garage last night and moved most of my bodyworking tool collection over. getting there. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7056 Location: Lawrenceville, Ga
Posted: Tue Jul 24, 2018 2:10 pm Post subject: Re: neil's 52 zwitter |
going for something like that?
or like that?
both built by friends of mine in the early 90s. _________________ regards
Uli
67ctbug Samba Member
Posted: Tue Jul 24, 2018 9:42 pm Post subject: Re: neil's 52 zwitter |
mandraks wrote: |
both built by friends of mine in the early 90s. |
That is awesome! _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Wed Jul 25, 2018 6:04 am Post subject: Re: neil's 52 zwitter |
closer to #2. maybe not quite so authentic looking, but time will tell. |
parker007 Samba Member
Joined: December 21, 2011 Posts: 132 Location: california
Posted: Fri Jul 27, 2018 6:02 am Post subject: Re: neil's 52 zwitter |
niel where did you get the lsd? what did it come out of? |
