`70 squareback
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Oct 31, 2014 7:53 am    Post subject: Reply with quote
Thin gray primer.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwtyp3variant
vwtyp3variant is offline
PostPosted: Wed Nov 05, 2014 1:50 am    Post subject: Reply with quote
well I think i will spray a thin layer of gray primer on it
Thanks guys
VWCOOL
VWCOOL is offline
PostPosted: Wed Nov 05, 2014 3:08 am    Post subject: Reply with quote
You should use high temperature paint, like what is used on stoves
W1K1
W1K1 is offline
PostPosted: Wed Nov 05, 2014 8:48 am    Post subject: Reply with quote
do i paint that NOS muffler or do i leave it as is?
and if yes with what type of paint?
I've used tremclad Hi temp BBQ paint on mine. it usually lasts a couple years before I repaint, not because it peels, the black just turns grey and gets scruffy looking
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
vwtyp3variant
PostPosted: Fri Nov 07, 2014 5:34 pm    Post subject: Reply with quote
i see Smile
one other thing...what color was the muffler on a stock new car?
that might help me decide what is on it
Bobnotch
Bobnotch is offline
PostPosted: Sat Nov 08, 2014 10:23 am    Post subject: Reply with quote
vwtyp3variant wrote:
i see Smile
They were a gray/green gray color. Unfortunately, the paint VW used would burn off, and rust would take it's place. Sad
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Mike Fisher
PostPosted: Sat Nov 08, 2014 10:40 am    Post subject: Reply with quote
Thin gray primer & then gray high temperature paint.
Dlglobal1
Dlglobal1 is offline
PostPosted: Sun Nov 09, 2014 12:37 am    Post subject: Reply with quote
Has anybody tried the Manifold Grey from POR-15? I'm considering for the heat shield parts of the exhaust and curious if it's heat resistant enough for the whole thing.
Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D
eyetzr Premium Member
eyetzr is offline
PostPosted: Mon Nov 10, 2014 6:53 am    Post subject: Reply with quote
If you are using BBQ paint follow the directions on the can & it should last a couple of seasons. I say this because the tendency is to clean & paint, the temperature has to be correct for it to work. My old boss used to use old motor oil. Get the exhaust really hot & wipe the muffler with the oil dampened rag. It smokes a bit but leaves a dark look to the muffler. His 1909 Hudson muffler looks like new all year.
I think he meant "rare", as in "not well-done"
vwtyp3variant
PostPosted: Tue May 03, 2016 2:12 pm    Post subject: Re: `70 squareback Reply with quote
Hi
I have got my enigne out, and rear subframe off the car for overhauling
I want to change the rubber bushes in the trailing arms, however, the new aftermarket bushes seem to have a direction of mounting, and i`m not sure which one is the corect way
I attached some photos of the new bush, please help me with any informations
vwtyp3variant
PostPosted: Fri Jul 22, 2016 11:37 pm    Post subject: Re: `70 squareback Reply with quote
so anyone know how to mount these bushes? where should the empty part be, at the top and bottom or on the sides?
andk5591
andk5591 is offline
PostPosted: Sat Jul 23, 2016 3:18 pm    Post subject: Re: `70 squareback Reply with quote
I have never seen bushings like that....Sorry.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Sat Jul 23, 2016 3:35 pm    Post subject: Re: `70 squareback Reply with quote
Me either.
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
raygreenwood
raygreenwood is offline
PostPosted: Sat Jul 23, 2016 5:18 pm    Post subject: Re: `70 squareback Reply with quote
Skip down to the thread today "type 3 trailing arms the same as type 1 trailing,arms"...and they have pictures of that bushing. Ray
vwtyp3variant
PostPosted: Tue Nov 08, 2016 10:45 am    Post subject: Re: `70 squareback Reply with quote
hello folks
I didn`t post anything in a while, so I thought I would show you some progress on my square
rebuilt heads
putting my engine together
rear suspension, everything was blasted and powder coated, new bearings, bushes, shock absorbers, brakes, bolts
bodywork was also necesary, hope to get her back on the road in april 2017, with a nice new coat of L30A Very Happy
vwtyp3variant
PostPosted: Tue Nov 08, 2016 10:50 am    Post subject: Re: `70 squareback Reply with quote
I have one question.
The return spring from my engine cooling flaps where missing( part # 311 119 759). Does anyone have a picture of it mounted and maybe can take a few measurments?
I can`t seem to find an original spring Sad
trythis
trythis is offline
PostPosted: Tue Nov 08, 2016 1:59 pm    Post subject: Re: `70 squareback Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1875568
Laverne, our Squareback project:
http://www.thesamba.com/vw/forum/viewtopic.php?t=664462
vwtyp3variant
PostPosted: Tue Nov 08, 2016 2:12 pm    Post subject: Re: `70 squareback Reply with quote
thaaanks Very Happy
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Nov 08, 2016 4:36 pm    Post subject: Re: `70 squareback Reply with quote
Damn fine looking parts!
Where did you find rubber for the diagonal arm bushings? I could only find red urethane a few years ago.
glutenfree
glutenfree is offline
PostPosted: Tue Nov 08, 2016 7:41 pm    Post subject: Re: `70 squareback Reply with quote
Where did you get those socket cap (allen head) tin screws? I am digging the color/coating on your manifolds!
1971 Fastback Build
VW/Type 3 Parts for sale
Instagram
my Shapeways store
Page 6 of 10
