54bugn Samba Member
Joined: April 28, 2005 Posts: 493 Location: Parksville BC, Canada
Posted: Fri Jun 24, 2016 10:43 pm Post subject: Re: My 54 european deluxe from start to finish |
Hello all, you gotta love the oil and gas industry! Let's just say I ended up having to move again, it's gotta be the last time.
Living the left coast style now, and finally have started back on the 54.
Drilling out rusted out bumper mount.
Looks worse underneath.
Drilling out the inside shelf. It was rotten in a number of ways.
With shelf removed. New pieces to go in after clean up.
Thanks for sticking with me.
Cheers, Mike _________________ "Schwing wrote:
You either have to be too cheap to hire a pro or determined to do it yourself, but it helps to be both!"
54 European Sedan deluxe
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=414940 |
54bugn Samba Member
Posted: Sat Jun 25, 2016 10:44 pm Post subject: Re: My 54 european deluxe from start to finish |
Started straightening out and reforming the good metal that is left to repair the area today. Trying to keep as much original as possible.
Stay tuned for the cleanup and repair.
Thanks,
54bugn Samba Member
Posted: Thu Jun 30, 2016 7:52 pm Post subject: Re: My 54 european deluxe from start to finish |
Continuing to fix the left rear bumper mount and frame work.
Fitting mount, measuring multiple spots compared to original right side.
Thanks for watching.
54bugn Samba Member
Posted: Mon Jul 04, 2016 6:50 pm Post subject: Re: My 54 european deluxe from start to finish |
Another update, more progress on the left rear valance/ bumper mount .
Enjoy,
Mike
54bugn Samba Member
Posted: Tue Jul 05, 2016 8:33 pm Post subject: Re: My 54 european deluxe from start to finish |
So I got the left rear shelf replaced with a new one. Nice piece from CIP was advertised as original German quality and it was certainly a nice piece only needed some minor trimming.
Original right shelf installed in August 1954.
New shelf installed July 2016.
Exterior view afte new shelf and new bumper mount installed. Much stronger assembly now.
One more repair required to the left rear valance where someone cut it out to fit a later muffler, and the rear end is done. Stand by for that.
Cheers,
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 880 Location: Lanark County, Ontario, Canada
Posted: Wed Jul 06, 2016 10:28 am Post subject: Re: My 54 european deluxe from start to finish |
Nice work there. Is that blue thing an IKEA kitchen trolley? If so, I had the same idea.... _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
54bugn Samba Member
Posted: Wed Jul 06, 2016 11:13 am Post subject: Re: My 54 european deluxe from start to finish |
Hello Zwitterkafer, thanks for the props. Yes the cart is from Ikea, it has an "almost" look of the old fold up toolboxes, and holds a lot of stuff as well. I highly recommend it.
Cheers,
54bugn Samba Member
Posted: Wed Jul 06, 2016 7:52 pm Post subject: Re: My 54 european deluxe from start to finish |
So I only have a later model replacement valance to steal metal from, so this has to be done in two steps. First step almost complete, now to fill in the hole.
Basketcase Samba Member
Posted: Thu Jul 07, 2016 4:35 pm Post subject: Re: My 54 european deluxe from start to finish |
fantastic job! I dunno how you get anything done between work and moving. _________________ '72 Karmann Ghia Coupe (the Boss's) |
54bugn Samba Member
Posted: Fri Jul 08, 2016 8:05 pm Post subject: Re: My 54 european deluxe from start to finish |
Thanks Basketcase, well now that I have the right job I won't be moving and have more time to work on the 54.
To that end, I made the piece to fit the exhaust cutout that I had to fix. Started out with a thick paper template transferred to flat steel, then massaged it to fit.
Here's the template and early cutout and bend in the flat steel.
Here's the early inside and outside fitting.
Here's the final fitting prior to welding.
And post weld. Stay tuned for the final finished pics.
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Jul 09, 2016 6:03 am Post subject: Re: My 54 european deluxe from start to finish |
54bug'n wrote: |
well now that I have the right job I won't be moving and have more time to work on the 54. |
I think I heard that before...
Nice work - glad to see you back at it! _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
54bugn Samba Member
Posted: Sat Jul 09, 2016 8:19 pm Post subject: Re: My 54 european deluxe from start to finish |
Thanks Joey, it's great to be back at it. I do have much more time to work on it now.
So the car is now repaired From the rear valance to the heater channels. Will keep working my way forward. For now here are the finished back end pics.
54bugn Samba Member
Posted: Fri Jul 15, 2016 8:57 pm Post subject: Re: My 54 european deluxe from start to finish |
Starting repairs on the front of the 54 bug.
First picture shows quite a few holes in the deck behind the fuel tank, as well on the right side where it welds to the skirt.
Repairs in this area complete as well as inside the car on the opposite side, in the following two pics.
Stay tuned more nose repairs to go.
Cheers,
54bugn Samba Member
Posted: Sat Jul 16, 2016 8:19 pm Post subject: Re: My 54 european deluxe from start to finish |
Cutting away more rusty metal. Left front lower section cut away, and spare tire well gone. Next up weld in donor metal.
Stay tuned,
54bugn Samba Member
Posted: Wed Jul 20, 2016 9:34 pm Post subject: Re: My 54 european deluxe from start to finish |
Hello all, more repairs on the left front lower support. Pics attached. Also had to replace a piece of the rubber seal channel on the nose and fill some holes. The results are attached. I had to cut the 55's donor piece to fit in two pieces as it was 1/8 of an inch longer than the 54's. So much for direct replacement. Second piece tomorrow.
Enjoy.
Mike
54bugn Samba Member
Posted: Sun Jul 24, 2016 7:43 pm Post subject: Re: My 54 european deluxe from start to finish |
More progress over the past few days. Got the 2nd part of the 55's replacement piece welded in place, now have a place to attach a new spare tire well. Also repaired some holes in the front left fender well, and repaired a number of holes in the upper hood channel in front of the window, as well as some holes in the lower window channel. Photos below. Also managed to drill out and tap door mount screws that broke off during both door removals. Next up spare tire well.
54bugn Samba Member
Posted: Fri Jul 29, 2016 8:57 pm Post subject: Re: My 54 european deluxe from start to finish |
Next job replacing the spare tire well. Cutting and fitting the replacement piece, pics attached, welding it in is next.
54ovsemi Samba Member
Posted: Sun Jul 31, 2016 12:21 pm Post subject: Re: My 54 european deluxe from start to finish |
Nice!! _________________ 2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval |
54bugn Samba Member
Posted: Mon Aug 01, 2016 9:37 pm Post subject: Re: My 54 european deluxe from start to finish |
Thanks 54ovsemi.
One of the things to watch out for while welding...."do you smell something burning?" (Nothing was hurt in the producing of this picture.....phew!)
Anyway, so much for those shorts.
Sorry, back to welding. More pics to come.
54bugn Samba Member
Posted: Tue Aug 02, 2016 9:59 pm Post subject: Re: My 54 european deluxe from start to finish |
Hey folks back to repairing the nose from rust damage. The lower spare wheel section is now welded in. Need to do a few touch ups but it's strong and looking good. I still need to repair the front apron lower edge where it mates with the wheel well. Enjoy the pics.
Stay tuned for the cleanup of the nose repairs.
Cheers,
