Big feet / tiny pedals
j_dirge
j_dirge is offline
PostPosted: Mon Jul 25, 2016 9:35 pm    Post subject: Big feet / tiny pedals Reply with quote
Solutions?
I have size 12s.. if using the brake I am either hitting the gas pedal or clutch pedal at the same time.. can make for some exciting times.
when using the clutch.. I am either hitting the brake, too.. or flipping my high beams on/off.
Surely I am not the only one...
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
BL3Manx
BL3Manx is offline
PostPosted: Mon Jul 25, 2016 10:56 pm    Post subject: Re: Big feet / tiny pedals Reply with quote
When you get the extender you should also upgrade your gas pedal
http://www.thesamba.com/vw/classifieds/detail.php?id=1333757
http://www.classicbugparts.com/big-boy-pedal-extender/
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Jul 26, 2016 6:07 am    Post subject: Re: Big feet / tiny pedals Reply with quote
I wear 12 1/2 shoes. I get rid of the flat pedal and use a roller. It is thinner so when I go to the brake pedal, the overlap now misses the gas pedal.
For the clutch, I use the Big Foot pedal extender that moves the clutch to the left 1 inch.
With those two small modifications, I can heel-toe the fuel and brake and be very quick on the pedals.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
j_dirge
j_dirge is offline
PostPosted: Tue Jul 26, 2016 7:12 am    Post subject: Re: Big feet / tiny pedals Reply with quote
Thank you gentlemen.
I'll look into the roller for the gas pedal, too.
These two mods look to be very promising.
.. until then.. I'll be driving only in my skinny shoes. Laughing
Do either of you still have the hi-low beam switch on the forward wall? or did you go to a dash switch or column selector?
andygere
andygere is offline
PostPosted: Tue Jul 26, 2016 8:45 am    Post subject: Re: Big feet / tiny pedals Reply with quote
The PO of my buggy whacked the clutch pedal off the stem, moved it over a bit and welded it back on sideways. It provides a surprising amount of additional room, but looks a little funny. I went with the non-logo pedal pads so the VW wouldn't be lying on it's side.
joescoolcustoms
PostPosted: Tue Jul 26, 2016 8:47 am    Post subject: Re: Big feet / tiny pedals Reply with quote
These tow mods look to e very promising.
I use the floor dimmer switches mounted to the forward firewall, to the left of the clutch pedal. Still plenty of room for my big feet to use it.
slalombuggy
slalombuggy is offline
PostPosted: Tue Jul 26, 2016 9:30 am    Post subject: Re: Big feet / tiny pedals Reply with quote
I have size 13s, still use a flat pedal but bend the clutch pedal over about 1/2" Easy to do on the old style forged pedals, the stamped ones need some heat. I have also cut off the pads and moved them over on others cars.
brad
wythac
wythac is offline
PostPosted: Tue Jul 26, 2016 10:55 am    Post subject: Re: Big feet / tiny pedals Reply with quote
When I was modifying my pedal set for a hydraulic clutch I moved the clutch pedal out by about 3/4". I added a "double leg" roller accelerator pedal at the same time. I don't have big feet but like the extra room between pedals as a safety and comfort improvement.
clonebug
clonebug is online now
PostPosted: Wed Jul 27, 2016 4:28 am    Post subject: Re: Big feet / tiny pedals Reply with quote
The 67 beetle turn signal switch and other newer ones have a dimmer switch button on it. If you get the correct headlight relay it works really well.
I removed my firewall mounted switch and used the column switch a few years ago.
vwracerdave wrote:
Take a good long look in the mirror and report back on what you see.
Paul.H wrote:
That one line on that chart is probably better info than you can get from this place in a month
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
j_dirge
j_dirge is offline
PostPosted: Thu Jul 28, 2016 8:54 am    Post subject: Re: Big feet / tiny pedals Reply with quote
Again.. Thanks all for the input and testimonials.
The extender and roller pedal are on order.. and after a test drive last night, I will be moving my hi/low beam switch.. Will look into that later stock.
Will keep you all posted.
