rbm2 Samba Member
Joined: September 19, 2006 Posts: 15 Location: Sarasota
Posted: Wed Jul 20, 2016 6:38 pm Post subject: Prototype full flow hydraulic lifter motors from VW |
Trying to find documentation or any information on motors like this one. I have had this motor since 1999 and have been told that a few of these motors were sent to dealerships. I have never seen another one. Closest thing I have seen is the CT and CZ cases in 72 and up 1600 kombis. Information came second hand from traveling VWofA mechanic. The case is full flowed similar to a type 4 case. Any information would be greatly appreciated.
Thanks
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51163 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 20, 2016 7:35 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
Hmmmm....., I've got an AE in my bus but it doesn't have that, want to trade? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2389 Location: Seekonk,Massachusetts USA
Rome Samba Member
Joined: June 02, 2004 Posts: 9655 Location: Pearl River, NY
Posted: Wed Jul 20, 2016 8:00 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
rbm2, I can add some evidence, though I never saw an actual engine. About 20 yrs ago an older German VW friend who retired from VWoA's HQ in Englewood Cliffs NJ gave me a set of such hydraulic lifters. He told me that VWoA had experimented with them for the Type 1 engine but the tests never went to production. Unfortunately I don't remember the reason for stopping the test, though I do remember he told me the lifters worked well. Possibly difficult to justify the additional cost of the lifters (and the full-flow system) on an engine which was supposed to stay inexpensive. The lifter set was made by the German Febi/Bilstein company.
My friend was in the Service/Equipment Test department for at least 15 years. When VWoA relocated to Troy MI around 1983 he left and found employment with another German auto manufacturer in northern NJ. He is actually depicted in the blue Bentley manual a few times, in the Brakes section, changing a tire on a manual machine. Black hair and overcoat.
He also told me about the time in the early '70's when VWoA ordered a full set of hi-perf parts from EMPI, and he built up a type 1 engine with the parts! After the test/evaluation, he was told to tear down the engine, and sold the parts. Unfortunately he passed a few years ago. |
rbm2 Samba Member
Posted: Thu Jul 21, 2016 3:33 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
Rome,
Thank you for sharing the information from your friend. Hopefully there is more out there. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu Jul 21, 2016 5:58 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
I used to have a dealer drawing saved somewhere. Can't find it. I stumbled across a post here about this same engine. Yeah, it's a Brazilian Bus engine. The engine compartment looked like a late Bus, and the engine tins were made differently to cover up that big opening. |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1298 Location: south san francisco
Posted: Fri Jul 22, 2016 4:57 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
i thought it might be a 93 and newer mexican motor. they came with hydros and a spin on filter. i think they used type 4 lifters. and fuel injection. but seems to be a 72 motor? brazilian like the other guy said.? _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
mark tucker Samba Member
Posted: Fri Jul 22, 2016 8:18 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
Ive seen them in aircraft usage.I wondered if they were made for that.but the briazilla bus soulds like possiably a good place to start. wonder why it never made it to all engines & world. kinda a no brainer...... like me |
rbm2 Samba Member
Posted: Fri Jul 22, 2016 11:06 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
Thank you bugguy1967 I appreciate the information but i believe the AE's were only made in Germany for the US Market. At one time I though that maybe someone used half of a case from a Mexican motor and half of another but both case pieces match. I have never seen a Brazilian case in person with full flow but have seen a Mexican one that was full flow. That particular motor had push rod tubes similar to a type 4 and could be changed without taking off the head but my motor has tubes like a standard type 1 motor. |
timvw7476 Samba Member
Posted: Fri Jul 22, 2016 7:28 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
mark tucker wrote: |
They already knew the cost, going hydro in the TIV,
it must of been the turn to water-cooled engineering, FWD Rabbit platform that left this stuff "stillborn". |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Jul 22, 2016 8:12 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
The only problem will be getting anything other than a stock cam for it. |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Fri Jul 22, 2016 10:25 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
And there are performance cams not made for hydrauilc lifters that work beautifully with them anyway. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
ps2375 Samba Member
Posted: Sat Jul 23, 2016 6:52 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
Max Welton wrote: |
Why? There are performance cams made for hydraulic lifters.
Max |
Who makes them, I've looked around and haven't found any and the company that made the one I have has no idea what it's specs are anymore.
Boolean wrote: |
And there are performance cams not made for hydrauilc lifters that work beautifully with them anyway. |
Can you elaborate on this? |
Posted: Sat Jul 23, 2016 9:27 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
cb&mofoco have them as does some others.I wouldent hesitate using just about any grind I wanted to use
that pic also shows a oil pressure adjuster in the relief plug.I wonder if it's oe or not and if it's a single relief case or duel? it would be real nice if the autolina guys would see this and....add a few ounces to the new cases&3 more maching ops..... although it might be in the way of somethen or just plane look weird so better not do it.I would hate to see a bunch of weird looking bubble top aluminum stroker cases with 1/2" thicker lifter bosses on clearance for $132.53, they wood never sell |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Jul 23, 2016 11:12 am Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
_________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Sat Jul 23, 2016 2:11 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
ps2375 wrote: |
Max Welton wrote: |
Max |
Who makes them, I've looked around and haven't found any and the company that made the one I have has no idea what it's specs are anymore. |
I'm using an EXV264HYD on 106º lobe centers from Steve Long Racing (SLR). My friend Steve Hollingsworth referred me to them.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
ps2375 Samba Member
Posted: Mon Jul 25, 2016 1:03 pm Post subject: Re: Prototype full flow hydraulic lifter motors from VW |
Max Welton wrote: |
ps2375 wrote: |
Max Welton wrote: |
Max |
Max |
After a short talk with Steve, I know what I'll be doing this winter when the car is off the road and the motor is pulled! Thanks for the tip! |
