Carpet question
Max Welton
Max Welton is offline
PostPosted: Sun Jul 24, 2016 8:42 pm    Post subject: Carpet question Reply with quote
So the 67 came with a new carpet kit. Not sure who it's from, but it does not have openings for heater vents or for where the seat belts will connect to the tunnel and B pillars.
I can't just hack holes in the carpet.
Thoughts?
Max
1967 Type-3 Fastback
ibjack
ibjack is offline
PostPosted: Mon Jul 25, 2016 7:08 am    Post subject: Re: Carpet question Reply with quote
Take it to an upholstery shop or have someone else hack the holes for you
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jul 25, 2016 7:55 am    Post subject: Re: Carpet question Reply with quote
Not sure of your year, but most seem to have a rubber collar/surround melted into the carpet. Hard to add now. But you could have it cut and add sewn-in binding like on the other perimeter edges, and it would look pretty sharp.
raygreenwood
raygreenwood is offline
PostPosted: Mon Jul 25, 2016 8:13 am    Post subject: Re: Carpet question Reply with quote
Yes....its actually vinyl. Its hot melted on.
You can do a really nice version of that yourself.
Carefully cut the holes, mark/draw the ring or surrounding area you want. With a razor blade....or you can even do this with a soldering iron.....carefully shave or meld the carpet down to just fuzz that sticks out in a thin matt above the heat sealed backing.
Mask the area off carefully. Spread on a layer of stiff RTV.....or you can use Flexane casting urethane. Let dry.....remask if necessary and eepeat until you have a uniform layer thickness.
I did this twice years back on another 411 I had ro replace the carpet mat over the center tunnel.
Depending in how clean you are.....from 2 feet away this can look professionally done....though it will look slightly different from what came from the factory. Ray
Multi69s
Multi69s is online now
PostPosted: Mon Jul 25, 2016 9:30 am    Post subject: Re: Carpet question Reply with quote
What I do is use an ice pick to find the outline of the hole. Then mark where I want to cut with a sharpie. If the hole is round get a piece of pipe the size you want, grip with vice grips and heat it with a torch and press it through the carpet. For irregular shapes use a soldering iron to cut it out.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Brent
Brent is offline
PostPosted: Mon Jul 25, 2016 9:48 am    Post subject: Re: Carpet question Reply with quote
My TMI kit did not have the molding and I had to cut the holes myself.
69 Fastback Build
Berg5 Build
raygreenwood
PostPosted: Mon Jul 25, 2016 10:06 am    Post subject: Re: Carpet question Reply with quote
Thats a great method as well if you are crafty. I have worked with a lot of companies that did plastic bending so we had hot wires and coils.
I have done some panel and carpet seams ...straight lines mainly....with hot wire tools.
If one has some spare carpet to practice with you can actually make world class seams and bindings similar to many that were done stock. Its just heat and melting. Ray
Max Welton
PostPosted: Mon Jul 25, 2016 4:25 pm    Post subject: Re: Carpet question Reply with quote
Good ideas. Thanks!
I'll share whatever I come up with. Unless it's really ugly. Laughing
Max
