pablovent Samba Member
Posted: Tue Apr 26, 2016 3:28 pm Post subject: Re: stock IRS trailing arms longer work advice? |
cbeck wrote: |
The two washers per side are supposed to go between the bushing and the bolt head. |
sorry, two washers in the bolt head side? |
cbeck Samba Member
Posted: Wed Apr 27, 2016 4:58 am Post subject: Re: stock IRS trailing arms longer work advice? |
The washers fit under the bolt head between the bolt head and the bushing.
Posted: Wed Apr 27, 2016 5:45 am Post subject: Re: stock IRS trailing arms longer work advice? |
like a photo?
cbeck Samba Member
Posted: Wed Apr 27, 2016 4:37 pm Post subject: Re: stock IRS trailing arms longer work advice? |
yes. |
francoangellini Samba Member
Joined: January 10, 2012 Posts: 223 Location: Chile-South America
Posted: Wed Apr 27, 2016 4:56 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Thank you!! |
Posted: Wed Apr 27, 2016 5:00 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Really Apreciate!! |
Posted: Tue Jun 21, 2016 4:17 pm Post subject: Re: stock IRS trailing arms longer work advice? |
pictures 3x3 modified stock trailing arms and 3,5 raised spindles installed... |
dustymojave Samba Member
Posted: Tue Jun 21, 2016 4:47 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Se mira bien mi amigo! Me gusta como parece el frente del cuerpo.
Esos cubos de los faros se inclinan hacia arriba y parece que van a requerir trabajo para corregir el objetivo de las luces.
Pero veo que tienes luces al dentro ya apuntados correctamente. Me gusta!
Looks good friend! I like how the front body looks.
Those headlight buckets are tipped up and will require work to correct the aim of the lights.
But I see that you have other lights in the buckets already aimed correctly. I like it! _________________ Richard
SoCalBajas Member
Posted: Tue Jun 21, 2016 5:48 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Thank you Richard, front body still in process.....finally I can with the correct rear wheels camber/toe .......I just need to turn or rotate the ring of the front classic style wheels (cut stock welded) to improve the offset....Rear wheels wider with so much difference (3x3), with this new offset modification the difference will be less.
Modify the suspension was most important to me, the rest of the work is already an old friend!
Muy buen español! |
Posted: Tue Jun 21, 2016 8:10 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Gracias!
Cuando cambias el desplazamiento de las ruedas delanteras, hace mas difícil el direccion y aumenta el riesgo de danar la suspension delantera cuando aumenta la influencia de un impacto.
When you change the offset of the front wheels, it makes steering more difficult and increases the risk of damaging the front suspension as it increases the leverage of an impact. _________________ Richard
SoCalBajas Member
Posted: Wed Jun 22, 2016 5:03 am Post subject: Re: stock IRS trailing arms longer work advice? |
dustymojave wrote: |
Gracias!
When you change the offset of the front wheels, it makes steering more difficult and increases the risk of damaging the front suspension as it increases the leverage of an impact. |
Thank you Richard, I'll keep that in mind! |
Posted: Wed Jun 22, 2016 5:31 am Post subject: Re: stock IRS trailing arms longer work advice? |
Extended stock IRS trailing arms to 3x3, 3mm flat metal plate. In the pictures pre MIG welded final work. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5369 Location: Lefty, CA
jsturtlebuggy Samba Member
Posted: Mon Jun 27, 2016 3:03 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Yes your trailing arms looks great. Baja looking good too.
I would recommend adding some kind of material (round tubing my prefer) from the inner pivot point to the far end if the trailing arm to keep it from bending. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
72Pstroke Samba Member
Joined: April 04, 2011 Posts: 182 Location: North Idaho
Posted: Thu Jun 30, 2016 7:41 am Post subject: Re: stock IRS trailing arms longer work advice? |
Where can I get a fixture like the one pictured?
Tim |
Posted: Thu Jun 30, 2016 4:27 pm Post subject: Re: stock IRS trailing arms longer work advice? |
After seeing many trailing arms bent from stock bugs to race cars, I going say it again, the arms need more strengthening to hold up to being extended. Even stock arms need reinforcement when used off road. Since I started playing with buggies in the 1970 I seen all kinds of things happen to trailing arms that were not reinforce. I even seen on one race car where the piece that is welded to the trailing arm where the spring plate attaches completely rip off the arm.
This is what I did when I lengthen a set of arms 2in
For stock trailing arms this how I reinforce them. Hi Jumper/Prowlers use to sell kits to do this. Mine are a copy of them.
Elrod Motorsports
Posted: Thu Jun 30, 2016 5:37 pm Post subject: Re: stock IRS trailing arms longer work advice? |
I agree very strongly with Joe. Pablo's arms may look nice, but the gusset ending at the spring plate bracket concentrates bending force right there. Even street use is likely to bend those arms.
Yo pienso fuertamente con Jose. El tiene razon. Los brazos de Pablo pueden tener un aspecto agradable, pero las cartelas que terminan en el soporte de placa de muelle concentran fuerza de flexion alli mismo. Incluso el uso de la calle es probable que se doblen los brazos.
The tubular reinforcement as Joe shows is just what I had in mind. The arms may still be reinforced just like Joe's.
El refuerzo tubular como se muestra Jose es justo lo que tenia en mente. Los brazos todavia se pueden reforzar al igual que los brazos de Jose. _________________ Richard
SoCalBajas Member
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Fri Jul 01, 2016 6:41 am Post subject: Re: stock IRS trailing arms longer work advice? |
Another to agree with the need for additional braces
Mine broke right past where his reinforcement is
