Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Sun Feb 17, 2013 10:07 am Post subject: |
I believe this setup is for testing the pressure in the brake system. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
1500king Samba Member
Joined: January 05, 2007 Posts: 209 Location: Adelaide, Australia
Posted: Sat Jun 01, 2013 5:39 am Post subject: |
Gary wrote: |
I would like to know what this is for. It's some kind of jig. |
It is a heater vent fitting template for an Audi 100 |
Posted: Sat Jun 01, 2013 5:50 am Post subject: |
Gary wrote: |
I believe this setup is for testing the pressure in the brake system. |
Close.....Auto transmission pump and line pressure gauge set starting with 003, 010 trans, also later ones . |
Posted: Fri Jun 14, 2013 6:08 am Post subject: |
1500king wrote: |
Thanks. I updated the descriptions in my Gallery. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
garrett.fell Samba Member
Posted: Mon Jul 29, 2013 10:49 am Post subject: Matra VW 161a fix? |
Anyone have an idea how I might be able to fix these? I just picked them up off ebay for what I thought was a really good price ($36) - I wasn't paying close enough attention in my panic'd "buy it now" frenzy to initially realize they had some issues. That came about 10 seconds later.
I've always wanted a pair of these
Anyway - ideas welcome. I am most concerned about the missing "ears" on the end of the pliers, and less concerned about the accordian part between the handles - I assume there's probably a spring in there to keep the pliers in a closed position?
Anyone have the dimensions of the ears?
Posted: Sun Aug 11, 2013 10:03 am Post subject: |
VW Tool 288c
I had to break out my jeweler's eyeglass and trace the second digit to verify this is VW Tool 654.
Odd that it does not match the following photos: Image 1, Image 2, Image 3.
Can anyone shed light on this? _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76962 Location: Sneaking up behind you
Posted: Tue Aug 13, 2013 8:04 am Post subject: |
3/4" beam torque wrench
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Aug 13, 2013 8:29 am Post subject: |
Interesting observation. I'll see if I can follow up on that. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Press On Samba Member
Joined: December 23, 2013 Posts: 1 Location: Ontario Canada
Posted: Mon Dec 23, 2013 3:37 am Post subject: Matra Part # 385/55 |
I have a Matra part # VW 385/55
A U shaped metal clip that is 1.5" x 2.875;" x .5" thick. The three sides are .375" wide.
It is still in the plastic shipping bag, never used.
Not sure what it was used for or how much it is worth today.
Any information would be helpful.
Robbie |
EverettB Administrator
Joined: April 11, 2000 Posts: 69831 Location: Phoenix Metro
Fishynos72 Samba Member
Posted: Mon Mar 28, 2016 3:50 am Post subject: Re: Matra Tools w/photos |
Hello all.
Long time no post.
Good pickings' this easter, as far as matra tooling goes.
Drove an hour to pick this lot up. (Along with the usual home made scrap and stands that come with them).
Here's the colection after some serious cleaning and removal of yellow paint.
Finally after nearly 3 years of activly searching I have a 313 all of my own.
Post clean up.
While it still retains a lot of it's original paint and red lettering. I will be doing a full resto on this.
Here it is post paint stripper
Here's the 309 front beam adaptor showing the same OG paint scheme
Here's the results of this easters toils. I've chosen to focus on the these tools this week. The gearbox 353 support and 77mm ring tool 123a should be interesting.
They're all primed and ready for paint and machine 'blueing' next weekend. This all may seem a little overboard for some tooling that is going to be knocked around, but I like the idea of factory fresh.
_________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2005 Caddy panel van
2006 Golf R32 |
54 Oval Samba Member
Joined: July 30, 2012 Posts: 91 Location: Alberta, Canada
Posted: Tue Mar 29, 2016 2:13 pm Post subject: Re: Matra Tools w/photos |
Congratulations Fishynos72 I didn't know there were so many alternates to the 313. I had assumed the engine stand was it. What are the others, you implied front beam for 1 I noticed? |
Posted: Tue Mar 29, 2016 3:37 pm Post subject: Re: Matra Tools w/photos |
One is for the front beam, and then a side mount gearbox bracket. The other 2 are not stamped in an obvious way. I have no idea. _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Wed Jun 22, 2016 6:21 am Post subject: Re: Matra Tools w/photos |
Does anyone out there have a photo or two that they can post up of a VW #309 mounted to a #313 stand with the #309a brackets? What I really want to see is a VW front end assembly actually bolted up to the #309/309a and how that happens.
I have a #308 stand, the #313 head, the #309 front end mount. I don't have the two #309a brackets. I'm just curious how it all works together and would love to see a few photos of those parts in action holding a front end. Looks like the #309a brackets are for Transporter front ends, what is used to hold Beetle front ends (a #309c four piece set)?
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Thu Jun 23, 2016 3:20 pm Post subject: Re: Matra Tools w/photos |
For those who don't know what tool he is talking about.
1972 1302
1973 type2a
1957 type11
2006 Golf R32 |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Wed Jun 29, 2016 6:56 am Post subject: Re: Matra Tools w/photos |
I picked up some tools the other day... pretty sure a single 309a was in the bunch. I don't think I have any need for it & will be pushing it out the door in the near future. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
RalphMH Samba Member
Posted: Wed Jun 29, 2016 12:55 pm Post subject: Re: Matra Tools w/photos |
My MATRA W 80.1 hinge pin extracor
Posted: Wed Aug 10, 2016 7:26 am Post subject: Re: Matra Tools w/photos |
Looks like you're getting right into it!!
If you are the 'full 9 yards /compleat nutjob' like me, Matra painted those tools to DIN1843, that means the paint code is RAL7031- Blue-Grey (be sure to specify finish...all my tools are satin finished). I might also have some spare parts for your VW352(early version for 002, there are two types) which is missing the shackle to hold a bus trans.
Happy painting!!
Fishynos72 wrote: |
Hello all.
Long time no post.
Post clean up.
mikeandkirsti Samba Member
Posted: Tue Aug 23, 2016 7:24 am Post subject: Matra 313 paint |
I see the RAL code for Matra 313 grey is RAL7031 but does anyone have the code for the red? Probably same as the general red marking color used in Germany in the 40īs and 50īs, I recall it too has a RAL code. |
