Pat D Samba Member
Posted: Tue Jun 21, 2016 3:08 pm Post subject: Best street head to hit the market in many years |
After 3 years of design and testing, I'm happy to say that the New 044 Panchito head is on the market. No out of the box VW casting head comes close to the performance and cooling efficiency of this cylinder head.
Check it out.
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1671 _________________ Pat, Im too fast slow me downs! |
AlteWagen Troll
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Tue Jun 21, 2016 3:22 pm Post subject: Re: Best street head to hit the market in many years |
How is cooling improved? |
Pat D Samba Member
Posted: Tue Jun 21, 2016 3:25 pm Post subject: Re: Best street head to hit the market in many years |
MConstable wrote: |
Cooling is improved over other VW casting heads. We tried to duplicate the cooling of a stock VW casting. Other than the increased material around the bores, the new Panchito resembles a stock casting very close. _________________ Pat, Im too fast slow me downs! |
AlteWagen Troll
Posted: Tue Jun 21, 2016 3:30 pm Post subject: Re: Best street head to hit the market in many years |
Pat D wrote: |
MConstable wrote: |
Cooling is improved over other VW casting heads. We tried to duplicate the cooling of a stock VW casting. Other than the increased material around the bores, the new Panchito resembles a stock casting very close. |
Thanks Pat! |
Pat D Samba Member
Posted: Tue Jun 21, 2016 3:33 pm Post subject: Re: Best street head to hit the market in many years |
AlteWagen wrote: |
PatD, any flow numbers that I can add to the cylinder head sheet or are they the same as the old Panchitos? |
As cast 85.5mm combustion chamber 54cc
flow at 25"
LIFT CFM
.100-47
.200-90
.300-126
.400-145
.500-155
.600-162
92/94mm CNC combustion chamber 61cc
flow at 25"
LIFT CFM
.100-50
.200-96
.300-138
.400-159
.500-167
.600-172 _________________ Pat, Im too fast slow me downs! |
scotth17 Samba Member
Joined: January 30, 2012 Posts: 335 Location: Bedford Texas
Posted: Tue Jun 21, 2016 3:43 pm Post subject: Re: Best street head to hit the market in many years |
How do they compare to the mini wedge ports? |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Jun 21, 2016 4:22 pm Post subject: Re: Best street head to hit the market in many years |
155cfm @ .500 as cast is nice. Almost 25cfm up from a std 044 head casting. Also 61 cc cnc chambers would support a nice low budget turbo build. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Tue Jun 21, 2016 4:29 pm Post subject: Re: Best street head to hit the market in many years |
can we get a close up of the combustion chambers "out of the box" as purchased?
so far every 044 "out of the box" head I've come across has needed a lot of clean up around the seats from inconsistant machining / seat installation. |
modok Samba Member
Joined: October 30, 2009 Posts: 26809 Location: Colorado Springs
Posted: Tue Jun 21, 2016 5:03 pm Post subject: Re: Best street head to hit the market in many years |
That is AWESOME!
Thank you Pat!
Of course, everybody will want something slightly different ect, ect, but screw em. That's the best street head I've ever seen, and the price is LOW.
i KNOW how much work it is to duplicate that, it's a lot of work, you could not pay me to do it. CB has come a long way in ten years. |
mark tucker Samba Member
Posted: Tue Jun 21, 2016 6:09 pm Post subject: Re: Best street head to hit the market in many years |
this is awesome!!! congrats.they look good from the pics. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3469 Location: Paradise, Ca
Posted: Tue Jun 21, 2016 6:11 pm Post subject: Re: Best street head to hit the market in many years |
Very Nice Job on the Intake Ports, definitely maximized the material available
$570 for a set of heads flowing 167 @ 25 is a great deal. This is about 176CFM @ 28, so if your comparing these to other heads measured @28 you can see they have achieved a monumental landmark here.
All that out of a 40X35.5, I like it! _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77018 Location: Sneaking up behind you
Posted: Tue Jun 21, 2016 6:24 pm Post subject: Re: Best street head to hit the market in many years |
Awesome heads... looking forward to seeing them in person. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jun 21, 2016 7:23 pm Post subject: Re: Best street head to hit the market in many years |
Can't wait to see all the local guys install them on their stock cammed 1600's.
Seriously man this is a great buy!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Pizza Eater Samba Member
Joined: October 10, 2013 Posts: 81 Location: Chico, CA
Posted: Tue Jun 21, 2016 7:59 pm Post subject: Re: Best street head to hit the market in many years |
Woohoo!
sled Samba Member
Posted: Tue Jun 21, 2016 8:05 pm Post subject: Re: Best street head to hit the market in many years |
beautiful
cant wait to see what power some competent engine builders put out with these heads. _________________ drive your split. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6991 Location: Durango, CO
modok Samba Member
Posted: Tue Jun 21, 2016 10:28 pm Post subject: Re: Best street head to hit the market in many years |
Whaaat??
Look at the pictures, it has "panchito 044" cast where the part number usually is |
