candyflame73 Samba Member
Joined: September 03, 2005 Posts: 430 Location: Texas
Posted: Mon May 30, 2016 8:21 am Post subject: Re: 73 Super project updated pics |
Finally got the 73 back on the floor. Using QA1 coil overs to get the front lowered exactly where I wanted it. The small diameter of the springs allowed me to get the wheels tucked inside the fender like I've dreamed of. The Weld Draglites were my favorite wheels for the car, but they hung outside the front fenders by at least 1/2". Not a big fan on the front wheels sticking outside. The rear doesn't bother me hanging out a bit. Next on the list is putting Fuchs on the rear and changing the running boards to coordinate with the wheels.
Posted: Wed Jun 15, 2016 1:06 pm Post subject: Re: 73 Super project updated pics |
Installed new running boards to go with the new wheels. Now it's time to get the rear wheels installed.
Posted: Sat Jun 18, 2016 1:51 pm Post subject: Re: 73 Super project updated pics |
Rear wheels mounted. Front are tucked inside the factory super beetle fenders with a proper rake. Rear are nice and beefy siting under the rear of the car. The rear tire to fender gap should close a bit after the rear seat and stereo system are installed. In the background is the pan to my 15 year old son's 1960 ragtop.
Posted: Wed Apr 26, 2017 4:08 pm Post subject: Re: 73 Super project updated pics |
It's been too long synced I've posted any updates........mostly do to health reasons. Here are a few update so far. Made a custom mount for my old school Audiocontrol DDC controller. I fiber glassed it into the fuse cover for a seamless look. Also prepping and slowly installing my carpet kit. I included a few shots of my front wheels tucking ever so slightly on my 73 Super.
[/img] |
Posted: Wed Apr 26, 2017 4:10 pm Post subject: Re: 73 Super project updated pics |
[/img] |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Apr 27, 2017 4:40 am Post subject: Re: 73 Super project updated pics |
Are you installing the carpet over bare metal? |
Posted: Thu Apr 27, 2017 5:54 am Post subject: Re: 73 Super project updated pics |
No, that kick panel had a bunch of goo on it. Just using a flap wheel to get everything off that might present a problem. Self etching primer is next in line. Floor pans are covered in POR 15 and Stinger Roadkill Pro sound dampening. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4423 Location: Stuck in Ohio
Posted: Tue May 02, 2017 2:29 pm Post subject: Re: 73 Super project updated pics |
You know, as long as I'm bugging your thread with my nonsense, can I ask you a question? When you shave your front hood handle, do you just use the glove box lever to pop it open when you need to open it? My flat screen Super looks like the little poker with the spring would be enough to hold the hood down. Do you weld it on from underneath? I haven't found anything on shaving the handle and you really know what you're doing. Sorry to bother you with my POS project and would be grateful for a picture or two of how it looks under there. Anyway, the Welds were definitely the right combo for this color if it was a Camaro but I do really think the Fuchs were the right move for the German car. Anyway thank you for sharing your artwork on wheels. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Posted: Wed May 03, 2017 6:58 pm Post subject: Re: 73 Super project updated pics |
Buggeee wrote: |
You know, as long as I'm bugging your thread with my nonsense, can I ask you a question? When you shave your front hood handle, do you just use the glove box lever to pop it open when you need to open it? My flat screen Super looks like the little poker with the spring would be enough to hold the hood down. Do you weld it on from underneath? I haven't found anything on shaving the handle and you really know what you're doing. Sorry to bother you with my POS project and would be grateful for a picture or two of how it looks under there. Anyway, the Welds were definitely the right combo for this color if it was a Camaro but I do really think the Fuchs were the right move for the German car. Anyway thank you for sharing your artwork on wheels. |
No problem. I'm using a shaved door handle kit witch has a trunk release button as well. I have a solenoid that pops it open as well as a back up pull cable under the front passenger fender. And yes, we welded that little "poker" under the hood. I'll see if I can get some good photos of my set up and post then here in hopes it will help you out.
Eric |
Posted: Wed May 03, 2017 7:34 pm Post subject: Re: 73 Super project updated pics |
Buggeee wrote: |
OK, That didn't take very long to snap some photos. Here is a pic of the "pokey" welded under the hood. There's a photo of the solenoid I'm using. The cable from the solenoid goes into a coupler to convert in into a sheathed cable. From there it goes to a three way splitter that runs one cable up, then through to the inside of the passenger fender for a back up pull. Then runs two cable for the release.......one representing the back up pull and the other for the solenoid. I hope that makes sense and helps out.
Posted: Thu May 04, 2017 6:20 pm Post subject: Re: 73 Super project updated pics |
No problem. And thanks for the complement. By the way, I agree on the Fuchs. |
11Bravo Samba Member
Posted: Mon May 08, 2017 4:08 pm Post subject: Re: 73 Super project updated pics |
I really like your build, and your Dad should be commended on the body work and paint. In one of your first pictures, do I see a solenoid on the door? I did a trunk release years ago on a build of mine and I as well had a hidden manual emergency release. Beautiful Work on the car! |
Posted: Wed May 10, 2017 12:04 pm Post subject: Re: 73 Super project updated pics |
Yes, there are solenoids for the doors for the shaved handles. Thanks for the props. My father has actually had two paint jobs unveiled at SEMA.....one for Ford Motor company. The other was at SEMA 2011: Lindsey Bradley’s 1965 Mustang Fastback called "The Silver Fox". He was actually flown to Vegas for the Ford unveil. Very cool for a guy who taught himself as a teenager. |
Posted: Sat Jul 15, 2023 6:27 am Post subject: Re: 73 Super project updated pics |
Been a while since I’ve posted updated pics.
GreeneHoosier Samba Member
Joined: August 16, 2004 Posts: 406 Location: Southern Indiana
Posted: Sat Jul 15, 2023 7:17 am Post subject: Re: 73 Super project updated pics |
Love this build, looks great! It is a real work of art. Enjoy the ride! _________________ 1974 Super Beetle
40 Years VW enthusiast! |
Posted: Sat Jul 15, 2023 11:41 am Post subject: Re: 73 Super project updated pics |
Thanks Brutha!! It’s been a lengthy project do to health reasons. Maybe one day, before I croke, I’ll finish. 🙄 That was originally a $500 purchase in 1991. It looked horrible, but I daily drove it while saving to get my first car with air conditioning. Funny thing is, the bug actually had everything for air conditioning except the compressor. |
