My new 68 Fastback "Desert Rat"
Page: Previous  1, 2, 3, 4, 5 ... 12, 13, 14  Next
Mike Fisher
Mike Fisher is offline
PostPosted: Sun May 22, 2016 10:08 am    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Better test your brakes Soon to see if you need any new rubber flex hoses to the wheels, if you intend to go to the Northwest VW Bug Run,show,swap,drags etc @ www.woodburndragstrip.com in 2 weeks! Twisted Evil
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
stonecoldcars
stonecoldcars is offline
PostPosted: Sun May 22, 2016 8:09 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
I'm not even gonna chance it Mike, I've already purchased them and will replace them.
My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395
stonecoldcars
PostPosted: Tue May 24, 2016 8:05 am    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Last nights achievements were. Injectors re-installed, all new fuel hoses, Installed a mechanical fuel pressure gauge so I can monitor pressure at any time, re-installed MPS with new mounts, installed fuel pump with new mounts, new master cyl installed, and than ran out of fuel hose to plumb the rest. Also thanks to Jim Adney for the heads up on the fuel neck overflow hose. it was destroyed rotten. so I have one of those coming for replacement too. So progress is progress..
stonecoldcars
PostPosted: Tue May 24, 2016 9:44 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
So guys, were is the chassis ground junction for the computer?
stonecoldcars
PostPosted: Wed May 25, 2016 1:10 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Getting pretty excited, I'm down to hooking up the two hoses to the bottom of the fuel tank, pour some gas in and than I get to see if this project will run.. While I had the tank still out I thought I would see if the fuel pump would run with key cycle since accessibility at this point is much better than with the tank installed. Well by no surprise...Turned the key and Nothing.. Checked the plug at the pump, Nothing.. So started with main relay.. Found no wire at terminal 30, so that = no +battery voltage supplied to relay. Made up a wire to battery and bingo, relay kicked over that allowed current to be sent to the fuel pump relay. Moved onto fuel pump relay and found that I had battery voltage, had ignition voltage, but had poor ground from computer. Cleaned the grounds... BAM relay works and fuel pump kicks on.. SWEET... Than I ran out of play time and quit for the night.. Sad
inzel
inzel is offline
PostPosted: Thu May 26, 2016 6:43 am    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Vid of it firing up?
--inzel--
66 Bug
69 Fasty
Old school Sandrail
stonecoldcars
PostPosted: Thu May 26, 2016 8:05 am    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
YES! That will be the plan my friend. This weekend hopefully will be a successful weekend on the desert rat. Goal is to get it running, and hopefully well. Than hit the brakes. I've already installed a new master cyl, new front soft hoses. Checked front caliper operation using compressed air. They seem to work. Still need to remove rear drums, check shoes and hardware, replace rear soft hoses, inspect and/or replace wheel cyl's.. So we'll see how far I get.. I will post progress and pics.. Down to a week and a couple of days for Woodburn show.. If that falls apart I'll shoot for the Fathers day show here in Eugene.
t-royR
t-royR is offline
PostPosted: Thu May 26, 2016 12:25 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
when you checked the injectors with the 9 volt batter, were they still in the car, or had you removed them?
T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv
stonecoldcars
PostPosted: Thu May 26, 2016 12:26 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Removed, check out my you tube video.
t-royR
t-royR is offline
PostPosted: Thu May 26, 2016 12:28 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
did you pull the injectors while the engine was in the car? Wondering how difficult that is. I should have done so when I had the engine out.
T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv
stonecoldcars
PostPosted: Thu May 26, 2016 12:43 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
yes I did, its not hard. 1/4" drive rachet , small extension, 10mm socket.
stonecoldcars
PostPosted: Sat May 28, 2016 9:35 am    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Well today after work is the big day to see if we have success in this desert rat starting.. I received in the mail yesterday from Jim Adney my improved fuel tank overflow/vent hose to install. Than just need to hook up the two hoses to the bottom of the tank add some gas and give it a go.. I'll let ya all know and a video..
stonecoldcars
PostPosted: Sat May 28, 2016 12:50 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Sitting here at work thinking about any possible problems I may run into this afternoon. I've replaced every rubber hose except the 4 connecting ones at the intake plenum. they look to be in good shape, however they can be turned by hand. I was going to just put clamps on them, but thought maybe they were a flex joint as such? how concerned should I be on these as a substantial vacuum leak source? BTW this pic is not current.
Donnie strickland
Donnie strickland is offline
PostPosted: Sat May 28, 2016 12:56 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Yes, clamp them.
71 Elm Green FI A/T Squareback
stonecoldcars
PostPosted: Sat May 28, 2016 1:21 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Donnie strickland wrote:
Yes, clamp them.
Cool , Thanks!
stonecoldcars
PostPosted: Sat May 28, 2016 5:51 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Well that was short lived. Og pump leaks like crazy. Off to the parts house for a airtex I go
stonecoldcars
PostPosted: Sat May 28, 2016 9:56 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Found a new delphi pump. A cross referenced one from the airtex E2000. Got it installed kind of a pain to figure out how to and where to mount it. But it's done. Videos are uploading now for the attempted starting, stay tuned..
stonecoldcars
PostPosted: Sat May 28, 2016 10:29 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
stonecoldcars
PostPosted: Sat May 28, 2016 10:30 pm    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
stonecoldcars
PostPosted: Sun May 29, 2016 7:51 am    Post subject: Re: My new 68 Fastback "Desert Rat" Reply with quote
Page 4 of 14
