Yeti cooler?
SoonerDave
SoonerDave is offline
PostPosted: Wed May 25, 2016 10:04 am    Post subject: Yeti cooler? Reply with quote
Friends:
Looking to buy a Yeti cooler, will sit on floor behind my passenger seat (I have an 86 weekender).
Questions:
-What model/size have people used that fits best in that spot?
-If you have a Yeti cooler, are you happy with it?
-What do you use to tie down?
THANKS IN ADVANCE!!!!!!!!
-David
-2018 Ford Transit Sportsmobile, 3.5 Ecoboost, mid-length, low roof with pop-top.
-1998 Toyota 4Runner everyday driver
FORMERLY:
-'86 Wolfsburg Westy Weekender original 2.1 Waterboxer - "Buster". Like the moe. song - Pig can fly!! Not named after it's tendency to have things on it bust. Smile
View user's profile Send private message Facebook Classifieds Feedback
yellowjacket
yellowjacket is offline
PostPosted: Wed May 25, 2016 10:22 am    Post subject: Re: Yeti cooler? Reply with quote
I use a Yeti 65 qt size cooler, its heavy when fully loaded for two. So heavy it takes both of us to move it in and out of the vanagon. Take that into consideration.
I use dry ice with water ice and usually lasts 8 - 9 days with daytime temps in the 80's to low 90's and not draining the water.
Yeti has a strap tie down system worth consideration. Not going to comment on how I tie it down as I don't want this thread going sideways.
Dan
86 Syncro Westy - Bostig RG11
71 Squareback
Altoona
Altoona is offline
Check out RTIC. Half the price and great reviews, tend to have trouble keeping them in stock however. The 45Q versions of either brand would fit well.
Robw_z
Robw_z is offline
PostPosted: Wed May 25, 2016 10:31 am    Post subject: Re: Yeti cooler? Reply with quote
I got the Yeti roadie 20. It's a little small, but looks cool which is why they're called coolers.
The roadie 20 is for small trips for two. The same principals of room vs bulk apply as with all other coolers. I'd wait for an REI 20% off sale and get one.
-Rob
benandmj
benandmj is offline
PostPosted: Wed May 25, 2016 10:35 am    Post subject: Re: Yeti cooler? Reply with quote
Save up just a little bit longer for a proper fridge (ARB). You won't regret it.
85 Westfalia Weekender
91 Syncro Westy
nacradriver
nacradriver is offline
Pardon my question, other than being critter proof, what makes either of these or the Pelecan cooler better than the Coleman steel that I have been using for years....
Ask because I am due for a new one shortly...
Thanks
Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985
SCM
SCM is offline
PostPosted: Wed May 25, 2016 11:08 am    Post subject: Re: Yeti cooler? Reply with quote
Thanks
They have far thicker insulation so they keep ice frozen longer. The flip side is that they have much less room inside compared to a cooler with similar outside dimensions.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
vegpedlr
vegpedlr is offline
PostPosted: Wed May 25, 2016 11:30 am    Post subject: Re: Yeti cooler? Reply with quote
I looked at Yeti etc. but settled for the much cheaper Coleman Extreme 28Q. Works great, a good size for me as a solo traveler, no need to tie down, strong enough to use as a step up to the top bunk.
dprendergast
dprendergast is offline
PostPosted: Wed May 25, 2016 11:31 am    Post subject: Re: Yeti cooler? Reply with quote
Check out the Pelican coolers. Mine was $100 cheaper for the same size (45 QT)
http://www.pelican.com/coolers/?gclid=CIzQ__vt9cwCFZQjgQodbtsPSQ
David Prendergast
Greensboro, NC
16CVs Premium Member
16CVs is offline
PostPosted: Wed May 25, 2016 12:00 pm    Post subject: Re: Yeti cooler? Reply with quote
Tried the Yeti Equivalent (Engel) Used it on one trip and stepped up and bought an Engel 45Qt Refrigerator. It only hurts once. The amount of space you loose for the ice to be efficient Is not worth it in my mind. That Yeti/Engel cooler is huge in a confined space. If you had a full sized Van or truck or setting them out side at camp, yea their great but in a van where space is tight it is not worth it.
I bought a GW tie down kit. This is no brainer to me, if you were in an accident or just regular driving you want that thing staying still. They use the seat belt boltholes with eyelets and turn buckles.
The biggest down side of a frig is adding Batteries to keep it going. I started with one and I think 2 will be more then twice better.
Stacy
Samba member # 14980
digthemlows
digthemlows is offline
PostPosted: Wed May 25, 2016 2:58 pm    Post subject: Re: Yeti cooler? Reply with quote
We're a family of 4 and we had a yeti 45 for a little bit. It wasn't nearly big enough. We went with the 65 and love it. There's a great "test" article on Overlander.com that's worth reading. We're strapping the Yeti to Eye Bolts in the seatbelt straps. We have hardwood flooring with a non-slip rubber mat and the cooler never moves when it's not strapped, we're just strapping so we don't worry about the kids in the back getting a cooler to the head if god forbid we ever get in an accident.
20lbs of Ice lasted us 5 days with frequent opening and closing during camping..... they are amazing coolers!
buildyourown
buildyourown is offline
PostPosted: Wed May 25, 2016 3:09 pm    Post subject: Re: Yeti cooler? Reply with quote
I would strongly recommend a real fridge for that kind of money. They are very nice. I wish I bought one years ago.
If you are trying to go cheap, get a cheap cooler.
kalispell365
kalispell365 is offline
PostPosted: Wed May 25, 2016 3:31 pm    Post subject: Re: Yeti cooler? Reply with quote
The Tundra 35 fits correctly behind the passenger seat, just the right width and height. We used the GoWesty seat belt loop bolts and two NRS 3 foot raft straps and it locks in place perfect.
A great addition.
1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
WestyKlaus
WestyKlaus is offline
PostPosted: Wed May 25, 2016 5:49 pm    Post subject: Re: Yeti cooler? Reply with quote
Go with the Pelican 65 qt - $340 shipped compared to $450 for the Yeti. There are minor advantages to either but you'll have more money left over if you buy the Pelican.
regis101
regis101 is offline
PostPosted: Wed May 25, 2016 6:21 pm    Post subject: Re: Yeti cooler? Reply with quote
Grab a tasty beverage and watch this.
https://www.youtube.com/watch?v=zu-V0ZqfYHg
Peace, Regis
tarandusVDub
tarandusVDub is offline
PostPosted: Wed May 25, 2016 7:36 pm    Post subject: Re: Yeti cooler? Reply with quote
This is what we got and it has been fantastic. We do have a decent aux battery system but in my opinion worth it. With solar, you can have cold beer until the cows come home.
http://www.compactappliance.com/FP430-Compact-EdgeStar-Portable-Refrigerator-Freezer/FP430.html
PS: you can get these on scratch and dent sales too, but have to wait and be quick on the draw. Some excellent threads on these too.
1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD.
Chuckarlie
Chuckarlie is offline
PostPosted: Wed May 25, 2016 8:15 pm    Post subject: Re: Yeti cooler? Reply with quote
This is the correct answer...
We run a TF65 permanently in our westy and an extra yeti 65 when not traveling light or we're out for a while. It's a big, heavy ass cooler and cheaper than fridge, batteries and solar in a weekender but it takes a ton of space.
connorsvw2
connorsvw2 is offline
PostPosted: Wed May 25, 2016 10:26 pm    Post subject: Re: Yeti cooler? Reply with quote
Yeti 50qt was the perfect compromise in my weekender-footprint is the same as the 45 but now seat height for an extra seating position while camping. Kept ice cold all thru Syncro Solstice. Pricy, not sure it's worth the asking price but will last a lifetime. Fridges are awesome but the real cost is much higher than the Yeti when you factor in batteries, solar, overall weight and in my case, loss of ability to store under a custom car cover.
'85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car)
landkholdings
landkholdings is offline
PostPosted: Thu May 26, 2016 4:53 am    Post subject: Re: Yeti cooler? Reply with quote
I have the yeti 20 for food and the 50 for beer and extra ice. I use the 20 for day trips, and both for longer trips. I stack them behind the passenger's seat. When I set up camp, the 50 goes outside and the 20 goes up top. I like to have one inside so I don't have to go out in the morning to get breakfast started.
I bought mine years ago before there were many competitors. Now, I would probably go with Orca because a friend is a dealer, and they're pretty cheap at dealer prices. I recently spent two days on the Gulf with my yetis and my friends and their orcas and they preformed basically the same. The only difference I see between a yeti and an orca is the handle. The handles on the orca are shaped like whale tails and are softer to the touch.
I also have a friend with Pelican 90. That thing is pretty awesome as well, but it is a 2-man job to move. It's tall instead of long, so the footprint is small considering the volume.
Kevin
joetiger Premium Member
joetiger is offline
PostPosted: Thu May 26, 2016 6:12 am    Post subject: Re: Yeti cooler? Reply with quote
http://yeticoolers.com/official-oklahoma-coolers/
Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
